03-19-2014, 11:04 AM | #26 | |
Enjoying left field
Re: Bertha
03-25-2014, 01:54 AM | #27 |
Enjoying left field
Re: Bertha
So I have a little progress to report. I took apart the 04 fuel lines and started mock up. I mounted the front section to the engine/tranny.
From there it'll have a short piece of flex, and then hardline down the frame. I think thats how the factory did it. I've also been working on the motor mounts. I set the engine and tranny in so I don't have to move the tranny crossmember, or modify the driveline. Originally I swapped the BB towers from side to side and moved them back about 1 1/2". The position was good, but the angle on them was wrong. I tried leaving them on their original side, but the leg is off the back of the crossmember. So, I cut them in half, and just swapped the down leg from side to side. I still need to clean them up, paint them and drill lower holes. And, whats this? Its not on any of my other trucks, and I need to mount my clutch master there. |
03-25-2014, 02:41 AM | #28 |
Re: Bertha
The three spring looking things are resistors from an old trailer brake set up.
My '72 short bed build. http://www.ls1tech.com/forums/conver...6-0-4l80e.html 5.3 swap into my RUSTY '71 C10 http://ls1tech.com/forums/conversion...71-c-10-a.html |
03-25-2014, 10:22 AM | #29 |
Enjoying left field
Re: Bertha
Thanks. I figured it was a resistor, but I wasn't sure what for.
07-01-2014, 01:34 AM | #30 |
Enjoying left field
Re: Bertha
I keep forgetting to take pics, but she's getting close.
-Motor and tranny are in for good -The fuel system is done except for a new factory sending unit for the gas guage -I reworked the harness, and its installed except for the PCM mount and I need to hook it into the stock wiring but I gotta put the nose back on first -I modified the steering column to delete the auto shifter -New pressure plate and clutch is all in and working I'll try to get some pics soon. |
02-05-2015, 11:14 PM | #31 |
Enjoying left field
Re: Bertha
Please note that you must be a supporting member to post classified items. This includes but is not limited to What Its Worth, Want To Buy, Want To Trade, and For Sale. Please consider supporting the forum by subscribing. Further information on the subscription levels available are located here
If you need any further assistance with that please contact any Admin for help. Last edited by truckdude239; 02-06-2015 at 09:49 AM. |
