#26 |
Re: How many of you guys are running 700r4's
So I got a quote today from a local shop that has a good rep. All said and done $2,300 that is take out old trans, move cross member, build trans w/ upgraded parts, 2400 stall
, shorten drive shaft, all linkage and wiring ex.......... drop of on Monday and get it back road worthy Friday. It sounds high to me. What do you guys think. |
#27 |
It actually sounds pretty reasonable for a complete turn key job.
"Negative people always seem to have a problem for every solution" |
#28 |
Sounds like a good deal,you'll be gald you did it.
84 step side 87 swb |
#29 |
A day late and $1 short...
Sounds like a good deal to me.
Buck Instagram: C10_ustacould 1963 SWB Fleet Side 528 Desert Beige Milly 1967 SWB Step Side 506 Medium Blue The Old Girl 1968 SWB Fleet Side 503 Light Green Ellie SOLD 1965 SWB Fleet Side 507 Light Blue Prescription Strength SOLD 1971 SWB Fleet Side 521 White Shiro SOLD 1968 SWB Step Side 503 Light Green My Old Farm Truck SOLD |
#30 |
![]() ![]() Join Date: Sep 2008
One of my buddies got a quote to do the same job in his 70 442 last week, and that's what they priced his at. $2,300.
other Larry Build thread, Arkansas K10 https://67-72chevytrucks.com/vboard/...=755797&page=5 The ability to speak several languages is an asset, but the ability to keep your mouth shut in any language is priceless. |
#31 |
Just heard this today but do you have to use a caprice or impala ss tail shaft housing to make the 700r4 work?
#32 |
I doubt that. Just use whatever housing is on it, shorten or lengthen driveshaft accordingly.
Daniel 68 C10 Build http://67-72chevytrucks.com/vboard/s...d.php?t=503594 Romans 10:13 Everyone who calls on the name of the Lord will be saved. |
#33 |
![]() Join Date: Nov 2012
I used to have one in my 81, but I accidentally burned up the 3 and 4 clutch packs by towing a trailer behind it on the interstate. Until that happened that was the best transmission that I ever owned. My 350C turbo does not even come close.
FRANKENTRUCK 1981 Chevrolet C10 Shortbed Stepside GRANDTRUCK 1968 Chevrolet C10 Stepside Longbed http://67-72chevytrucks.com/vboard/s...d.php?t=584617 PROJECT JIGSAW 1967 GMC C3500 GREAT WHITE 1986 Blazer M1009 |
#34 |
What is the best TV cable and bracket kit for this job.
#35 |
So I got everything ordered yesterday. The trans is being built this week and I will drop of the shift parts and tv made ez when they come in. Then then the truck will be dropped of and the transplant will begin. What end of the drive shaft did you guys shorten? The front half or rear? Or should I go with a single driveshaft ? What are the pros and cons of single drive shaft?
#36 |
In my opinion the BTO one is an awesome product. They have them for most carbs and look nice also. Ask for Jenn if you call them, the girl knows her tranny's and service is top notch , they are an easy install and adjustment.
#37 |
That the one I got. I figured you don't want to get crap when you spend all that money on a built 700r4. Thank you though for the info.
#38 |
![]() Join Date: May 2012
where do I find a shift linkage for a 68 column shift for the 700R4?
1968 Stepper |
#39 |
![]() Join Date: Dec 2012
Lokar is your friend.
1970 Longhorn, Front Disc, 350/4 bolt, 882 heads, HEI, Edelbrock, 700R4, HO-52/4.11. 1996 Corvette, Collector Roadster, LT4, 396, 450RWHP, 6sp, 4.11/Dana44/posi 5 point roll bar And let us not grow weary of doing good, for in due season we will reap, if we do not give up. Gal 6:9 |
#40 |
Great product ! You won't be disappointed, and made in the USA !!
#41 |
Roto Reuter thats the name...
![]() Join Date: Feb 2010
Not looking to start a debate, but when I bought my TH350 torque converter from Hughes Performance, they suggested a 200-4R over the 700R4 as a future upgrade. At the time I wasn't interested in spending the money to change to an overdrive transmission because my truck is mainly a weekend driver. If it was a daily driver (or driven more often) I might consider it. For my situation it just doesn't make sense to spend the extra money. Maybe some day though. If/when that day comes, I will seriously look into both transmissions.
~ Dan ![]() My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232 My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394 1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt 1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project "Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977 |
#42 |
i will be running one when I start my build.
I paid $300.00 for a tranny out of a 91 caprice with 100,000 miles and still works good. Paid about $700.00 for a good rebuild kit with trans-go shift kit, alto racing cluthes and extra clutch packs. All this will be going behind a 454 with 500hp/500+tq. The rebuild will be done by me as I have access to all the tools and books. Will probably run a ECE cross member for looks and the ease of removing tranny pan. |
#43 |
Parts and more parts
With that engine consider upgrading the planetary, sonex valve, hardened valve body separator plate, oil pump (Pump definite weak spot)
Frank |
#44 | |
Thanks for the advice. |
#45 |
![]() Join Date: Oct 2012
with that lumpy cam your going to need more than 1800 factory stall, even the corvette 2200 stall isn't going to be enough, going to suk if you have to do it twice....
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#46 |
#47 | |
Frank |
#48 |
