Old 03-02-2014, 03:30 PM   #26
niper0108
niper0108's Avatar
Re: My 54 Chev pickup - Contradiction
Dakota Digital gauges & billet steering wheel
GM wiring harness kit and motorized cowl vent
My 54 Chevy p/u build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=618513
My people skills are fine. Its my tolerance for idiots that needs work.
niper0108 is offline   Reply With Quote
Old 03-02-2014, 03:32 PM   #27
niper0108
niper0108's Avatar
Installing Bear Claw latches.
Old 03-02-2014, 03:36 PM   #28
niper0108
niper0108's Avatar
Trying to decide whether to make them bolt-in or weld in
Old 03-02-2014, 03:38 PM   #29
niper0108
niper0108's Avatar
Early on, it had a Nova 10 bolt with parallel leaf kit. Here Im mocking up the boxing plates. Eventually I would scrap this whole set up & go a different route.
Old 03-02-2014, 03:39 PM   #30
niper0108
niper0108's Avatar
Decided to have one of my spare hoods louvered
Old 03-02-2014, 03:49 PM   #31
54 CHEVY LR
I am just about to start My Bear claw install. I see you shaved the handles, Electric Besr Claws? I am trying to keep the outside handles also inside. Any Ideas on how you will setting up the Interior linkage? I am thinking of using Microswitches to activate the latch.
Thoughts?
54 CHEVY LR is offline   Reply With Quote
Old 03-03-2014, 12:52 AM   #32
niper0108
niper0108's Avatar
Thoughts?
I will use solenoids to activate them by remote, but also I have some Phipps interior handles with cables.
Old 03-03-2014, 12:59 AM   #33
niper0108
niper0108's Avatar
Parts, parts & more parts...
Bags & bags of screws, clips, hardware, etc. Mostly from Classic Parts of America. It was still Chevy Duty when I started the whole project...
More boxes of parts... Those old school billets & raised white letters are from the previous owners vision. Gives an idea of how long this truck has been under construction...
Old 03-03-2014, 01:02 AM   #34
niper0108
niper0108's Avatar
Getting my son involved...
Another project I gave my son to tackle. Installing the blue dos in the taillights
Old 03-03-2014, 01:05 AM   #35
niper0108
niper0108's Avatar
Wide whites replaced the old school billets some time ago. They were also painted red at one time. I plan to also purchase a set of 20" Boss 338's to switch it up from time to time.
Old 03-03-2014, 01:08 AM   #36
niper0108
niper0108's Avatar
This past summer, I brought the truck to my house & really tore into it. Here I've gutted the old rear end set up & am installing the 4 link & disc brake rear
Old 03-03-2014, 01:21 AM   #37
niper0108
niper0108's Avatar
Mocking up the 8" step notch. I went with 6"
Starting to mock up the 4 link here.
Step notch is tacked in
Made and added boxing plates to mount the 4 link front mounts
mocking up bag mounts here
Upper & lower 4 link arms tacked in place
Bag mounts tacked in
Old frame section has been cut out between the notch
Now its finally as low as I wanted!
Old 03-03-2014, 01:26 AM   #38
oldman3
oldman3's Avatar
Looks good...Jim
oldman3 is offline   Reply With Quote
Old 03-03-2014, 01:26 AM   #39
niper0108
niper0108's Avatar
Stainless Rock Island fuel tank going in...
Another one of my sons projects - cut & fit the fuel gauge sending unit assy to the tank...
Old 03-03-2014, 01:32 AM   #40
niper0108
niper0108's Avatar
I also raised the upper front shock mounts on the Mustang II front end to get another inch of drop up front...
The token visual aid... And possibly a bit of irony with the Throwback can...
Old 03-03-2014, 03:03 PM   #41
xpickup
xpickup's Avatar
niper0108, looks great setting on the boards. Great job.
Shannon
xpickup is offline   Reply With Quote
Old 03-03-2014, 03:11 PM   #42
niper0108
niper0108's Avatar
Old 03-03-2014, 03:13 PM   #43
niper0108
niper0108's Avatar
Bed back on. With the Step notch, had to move all the bed braces & mounting points and raise the bed floor 6"
Old 03-03-2014, 03:14 PM   #44
niper0108
niper0108's Avatar
Starting to get the braces moved and mounted
Old 03-03-2014, 03:20 PM   #45
niper0108
niper0108's Avatar
Had to install some mini tubs. These are trailer fenders cut down to 2" wide. Also added cross drilled rotors
Old 03-03-2014, 03:23 PM   #46
niper0108
niper0108's Avatar
Building a frame for the raised bed floor. Want to make it hinged and possibly motorize it
Old 03-03-2014, 03:29 PM   #47
niper0108
niper0108's Avatar
Got wood?
Old 03-03-2014, 03:32 PM   #48
niper0108
niper0108's Avatar
Getting ready to cap off the bed rails & eliminate the tailgate chains. Installing the slide bolt kit inside the tailgate.
These pics are up to date as of Feb 2014.
Old 03-03-2014, 05:11 PM   #49
Bubba54
Alot of nice work, Trucks looking great.
Shawn
My build thread - http://67-72chevytrucks.com/vboard/s...d.php?t=582647
Bubba54 is offline   Reply With Quote
Old 03-03-2014, 09:52 PM   #50
STOCKISH
Formerly- 1972SuperCheyenne
STOCKISH's Avatar
Your truck is looking amazing. Cant wait until Im that far along.
--Josh
