Re: LMC digital dash cluster????
I was just informed yesterday, that it will be 5 weeks before it will be shipped. at first they said one week, now 5. I guess they are on backorder !
![]() Join Date: Jan 2014
Yep me to. They have the version with the green display in stock but that's all. I want the white display though.
yes, I opted for the blue gauges, to match the color of the truck !
the same with the Doug Thorley 324 headers. I ordered them, only to find that they had to be made, and were 3 weeks out.They just shipped today! |
Just called to check order status. I placed my order on March 29 and opted for the white color. Was told then that it would be on back order for 5 weeks. Today when I called I was told it would be an additional 5 weeks from today's date. Very frustrated!!! You would think they would at least notify you if a back order date doubles.....
Wow! I was told that it would be two more weeks when I talk to them last Friday! I ordered a blue dash set.
#6 | |
Scott |
Has anyone hooked up the original water temp gauge to a new sending unit made for a cheap checker auto gauge?? If I leave it on the checker auto gauge it reads 190 degrees, the original gauge it reads hot..I'd much rather have the original.
I tried calling intellatronics, the people who make these for LMC, the same day I called LMC to ask a couple of tech questions and also inquire about an approximate delivery date. I had to leave a voicemail, it's now been 3 days with no response. Not impressed nor happy with the customer service from either place. Decided to cancel my order and go back with a restored factory cluster. Good luck to all of you who stick this out and go with the digital set up. Hope it is everything you expect and more!!!!!
Well sduckworth13 was correct. I just call to check on my order, and they said another 5 weeks WTF !!!!
Sorry to hear about all the delays. I ran into the same problem when the Lokar Throttle pedal came out for the 67-72's. It was delayed just enough and I heard some stories so I gave up and moved on. Perseverance has it's rewards though!
I put the lmc digital dash in my 70 model I am not happy at all the speedo stops working the clock resets on the tach the ribbon part of it will peg out at idle. Lmc said they are all on back order. I'm going to try and get a refund and put the Dakota digital dash in it.
![]() Join Date: Apr 2006
I personally would not support any part maker that is using Chinese slave labor to save money. If Dakota Digital is still U.S. made I would go with them. Yes you get a cheaper product from Chinese made parts but there will never be the quality and craftsmanship from buying U.S. made. In the long run you will pay more but it will save you money in headaches and having to replace the item when it dies. I have noticed a drop in quality of Craftsman tools ever since they sold out to make their items overseas. Just not the same tools anymore.
Kirk 72 Blazer CST 4wd highlander |
#13 |
The lmc dash is made in the USA I was hoping it would of been a good one
#14 |
Could it be a grounding issue? Everything you mention sounds like grounding problems commonly associated with any poorly ground digital gauges. Just a thought.
#15 |
I thought that to so I run a ground off the battery and a hot still doing the same thing all the wires soldered too.
#16 |
My Spoon Is Too Big
I have nothing to go off of but the pictures online, my question is not about function but looks? why for 800 bucks does Dakota Digital faces have to look cheaper than my microwave?
1972 C20, 03-14-10 Build Thread 2000 Silverado 4.8L, 11-04-13 (Currently Parting) 1999 Silverado 5.3L, 07-07-14. (Engine Donor) 2015 Ram 05-20-15 (Daily Driver) |
#17 |
Well I looked and did not find any Chinese knock-off money in my wallet so LMC is lookin good 2 me!!!
#18 |
For what it's worth, I own my own part time business doing mainly electrical work on classic cars and trucks. I can tell you this for a fact....Dakota Digital, in my opinion, is the best product out there for modernizing a cluster on any vehicle. Their systems are expandable to be able to add new features it seems they are constantly developing and their VHX line is very clean, looks fantastic at night and all their stuff is a breeze to set up. I know they cost more, but my customers I've done installs on are extremely satisfied and have had NO problems in over 3 years of installations. Not to mention, their staff is easy to work with! This LMC unit may be ok, but I like to stick with what I know.
Steve McMillen ASE and GM certified Master Technician 25 years+ experience ![]() No, I do not know it all, that's why I attend tons of training. |
#19 |
I wish I could find 4" square LCD panels, I'd make something cool. But everything I can find it wide aspect (like for a NAV system). I know a lot of people like these, but the Dakota Digital and these remind me of the early 80s Lincoln and Corvette dashes.
7-segment LEDs are actually as old as these trucks!
#20 |
At night.and you can dim or bright with your dimmer switch.
#21 |
Thanks for sharing that information, the dash looks great.
#22 |
Has any one had any problems with this unit. I installed mine and everything worked great for about a week then the speedo stopped working. I ran all new wires for everything. Now the speedo is pegged out and so is the fuel. The clock is no longer there either. All the other gauges tach, temp, oil and voltage work fine. I tried running a direct ground to the fuel and speedometer but nothing changes.
#23 |
LMC sells cheap Chinese crap, you get what you pay for. I will not give them one dime and encourage my customers to shop elsewhere. In my opinion when a company becomes as large as LMC they lose all customer service/appreciation.
#24 | |
Its a Truck Thing......
I also have a DD set up and it's ok. I cannot get the dimmer to work, one day I will trouble shoot it more, speedo jumps around and I have grounded the system to death and even twisted the wires for the sending unit just like they asked. Maybe it would work better with a LS set up. Smitty
71 C10 283/3SPD Full Resto 70 C10 Suburban Former military GSA truck. 72 Chevy Blazer 4X4, Sloppy Jo, Mountain Climber. Wife says no more trucks. http://67-72chevytrucks.com/vboard/s...d.php?t=707378 72 GMC 1 Ton Motor Home, wife said no more trucks until she saw this one. Gen 3 6.0/4L80E 4.10 http://67-72chevytrucks.com/vboard/s...d.php?t=761110 68 GMC Suburban was 3/4 ton, now 1/2.Wife shook her head 71 C30 Wrecker 71 C20 Scott-Bilt As weird as it gets..BB Cheyenne AC Truck 68 GMC Long Stepside. They keep following me https://67-72chevytrucks.com/vboard/...d.php?t=841215 69 C30 Former Motor Home, Flat Bed time 70 G20 Red-E-Kamp Conversion "I'm your Boogy Van" |
#25 | |
| Bookmarks |
