#26 |
Re: Carb disassembled, cleaned, still runs poor please help!
I have a rubber line running from the brake booster to the intake manifold. It's a very sturdy line, would be surprised if it collapses but I'll check it out this afternoon.
So I've heard one response for and one against the idea that covering the carburetor with my hands with unveil a vacuum leak.. Seems to make sense to me, and it definitely increases RPM and runs smoother when I do this. I would think if there weren't a vacuum leak, covering the air would choke out the engine and it would struggle not run better With the truck off, when I pump and hold the brake pedal, it holds tight and I hear no hissing or any type of sound that would indicate the booster is leaking... Man I hope I don't have to get into the intake manifold... Sounds like fun |
#27 |
![]() Join Date: Jan 2011
Reading back through the posts, and I should have read a bit better .. I agree about the vacuum leak. Have you replaced the gasket underneath the carb to the intake?
I had an Edelbrock carb issue a while back and ended up replacing the engine yes .. the entire engine for a crate swap, .. put it back together with the same intake and carb.. and the bog, hesitation, vacuum leak symtoms you described just moved over to the new engine. The end all fix was the gasket under the carb. The edge of it had kinda burned through a little and created a huge vacuum leak. Do you have a carb spacer under the Edelbrock (ex. Intake, gasket, spacer, gasket, then the carb) Could one of those gaskets be leaking?
Chad 1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway* 1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy 1986 Silverado Short Fleet - Scarlet *Sold* 1985 Silverado Short Fleet *Sold* 2022 Jeep Gladiator Mojave 2001 Jeep Cherokee XJ 4x4 - Lifted, Built 1992 Jeep Cherokee XJ 4x4 - Lifted 2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride) |
#28 |
Sweet relief!
Thank you all so much for the help. CCRat's last post got me to thinking. So as I was getting ready to take the intake manifold off, I looked closer at the gasket and sure enough there was a tiny hair line fracture on the corner... I cannot believe this is responsible for completely upsetting the idle.. I replaced it and she's back to running normal. Idle speed screw has a normal impact on rpm with a fraction of a turn, idle mixture screws affect idle, does not want to stumble off the line.. Learned a lot through the troubleshooting process but I still can't believe how much of an effect that tiny fracture had.. Thanks again for all your effort |
#29 |
Glad ya got it figured out! man its difficult to diagnose a problem when your behind a keyboard a couple thousand miles away LOL!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
#30 |
This board rocks!! You guys are awesome..
'72 Chevrolet Step Side 350/TH350, '63 C10 Step V8 '74 Trans Am 400, '80 Trans Am Indy Pace Car Mercedes AMG S55, SLK230 Kompressor, GL450 '96 Dodge Indy Ram Official Indy Truck '99 Porsche 911 Carrera |
#31 |
Great job! Some times you just got to be more stubborn than the d%$#%# truck.
70SBC10BOB
1970 C 10 A work in progress!! ![]() |
#32 |
That's the truth! It was driving me nuts, especially how it came out of no where...my equilibrium has been restored
#33 |
![]() I live in Arizona where it was really dry kept drying up accelerator pump and getting a flat spot in the carb. |
#34 |
![]() Glad you got it worked out ! I take Visa, MasterCard and Discover. ![]() It must be something about the way those Edelbrocks are made(?). The base might be shaped a little different in that area or whatever.. that gasket just looked a little thin. We replaced it and it fixed the problem. Only cost me about $3k.. ![]() Later..
#35 |
Who Changed This?
![]() Join Date: Jan 2013
While I realize that the original problem has been solved, I'd like to offer a suggestion that can help isolate carburetor problems. I had a problem with my 600 CFM Edelbrock carb awhile back, and rebuilt it. During the process, I noticed that the throttle valves could move quite a bit in the throttle body. I took the thing to a carb shop and had bushings put in. The throttle body wears, and you can get a vacuum leak, or it will not return to a nice idle due to the mispositioning of the throttle blades. A simple check is to spray carb cleaner on the throttle shaft on either side of the primaries. Any variation in engine speed indicates a leak, and the necessity of this repair.o the
Generally, problems with a bad running engine are related to the ignition. Electronic ignition systems have pretty much eliminated that.
~Steven '70 Chevy 3/4T Longhorn CST 402/400/3.56 Custom Camper Simi Valley, CA Last edited by Steeveedee; 03-14-2014 at 10:09 PM. Reason: Norton creamed me while I was writing the post! |
#36 | |
Who Changed This?
#37 |
Great job CC69Rat and Black70c10 for the follow-through. I think it was/is a carb issue and not a vacuum system issue. Granted they are intertwined, vacuum system leak and carb issues aren't the same imho Holding your hand over the carb - you were manually choking it, it ran better and from that conclusion, isolated to the carb itself.
project: "my happy mess" |
