Old 03-17-2014, 02:11 PM   #26
Katrina/10
Katrina/10's Avatar
Re: Ethanol Gas cause issues?
That should be the right one. But replacing it will not fix the problems you have mentioned.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Katrina/10 is offline   Reply With Quote
Old 03-17-2014, 05:58 PM   #27
SCHRUMGMC
SCHRUMGMC's Avatar
Then what will??? assuming a Carb rebuild right? but the Vacuum advance looks like it hasn't been replaced at all? also found out the exhaust manifold was cracked when they first saw the truck sitting at the car place.....but its been filled up and looks good next time it is running i'll see about putting my hand over it and see if the exhaust manifold is leaking
1971 GMC Sierra
1959 GMC 100
SCHRUMGMC is offline   Reply With Quote
Old 03-17-2014, 11:33 PM   #28
SCHRUMGMC
SCHRUMGMC's Avatar
I am guessing to go to Carquest and get a new Rochester 1 bbl Carb rebuild kit ? How much does a rebuild typically cost
Lean mixture signs are:
Backfires as the throttle is closed (primarily during coast-downs)
Lurching acceleration
White or light grey spark plugs
Requires excessive amounts of choke to run/start
White or light grey muffler end pipes
Bluing (on chrome systems) of the exhaust header down-pipes
I am starting to think its that up there ^^^ because the truck requires excessive Choke for it to run
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 10:03 AM   #29
Katrina/10
Katrina/10's Avatar
I think you're on the right track now.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 03-18-2014, 10:25 AM   #30
SCHRUMGMC
SCHRUMGMC's Avatar
How much does a rebuild typically cost?
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 01:27 PM   #31
OrrieG
OrrieG's Avatar
My take on the situation:
Backfires as the throttle is closed (primarily during coast-downs)<<TIMING
Lurching acceleration<<BAD ACCEL PUMP, TIMING
White or light grey spark plugs<<NOT BAD MEANS GOOD COMBUSTION WITH NO OIL FOWLING.
Requires excessive amounts of choke to run/start<<BAD ACCEL PUM
White or light grey muffler end pipes<<NOT BAD MEANS WHAT EVER GAS YOU ARE GETTING IS BEING BURNED, NOT OVER JETTED.
Bluing (on chrome systems) of the exhaust header down-pipes<<YOU HAVE CHROME HEADERS???
OrrieG is offline   Reply With Quote
Old 03-18-2014, 01:56 PM   #32
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks Orrie.I believe the Accelerator pump is just bad
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 03:09 PM   #33
SCHRUMGMC
SCHRUMGMC's Avatar
Dadgum it is $120 just to rebuild my Carb
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 04:40 PM   #34
OrrieG
OrrieG's Avatar
Classic has the kit on sale less than $30
http://www.classicpartsusa.com/produ...rburetor_Items
Old 03-18-2014, 06:35 PM   #35
SCHRUMGMC
SCHRUMGMC's Avatar
I can get a kit for 32.99 and a rebuild for $50
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 10:55 PM   #36
SCHRUMGMC
SCHRUMGMC's Avatar
Just got a really good deal, if I can buy the Rebuild kit he will rebuild it for Free.
My temp gauge isn't working like it should, the Oil gauge works but I've noticed the Temp gauge doesn't move at at all..Could it be that the Thermostat is broken and old(Very likely) or is the Temp sending unit broke?(doubt it)
1971 GMC Sierra
1959 GMC 100
Old 03-18-2014, 11:22 PM   #37
imjeff
imjeff's Avatar
To dispel a few ethanol myths...most premium has ethanol in it. If it doesn't, they will advertise it. Ethanol is a solvent so it will clean your tank of 40 years of varnish and gunk clogging your fuel filters. Ethanol absorbs water and phases out (separates from the gas) resulting in a leftover low octane gasoline. No additive will prevent phase out. Save your money on the additives. If you don't drive your truck enough to prevent phase out, find a source for clear gas. It's worth the extra money and yields you better mileage as a side benefit. I run E10 in my DD K20 and clear in my Chevelles and Harley (it's 40 years old, too).
I know a guy who's addicted to brake fluid. He says he can stop any time.
72 K10 396
75 Cj5 MPI 350 Chev
67 Chevelle 396, 4 speed
74 FXE
08 Tahoe
imjeff is offline   Reply With Quote
Old 03-18-2014, 11:42 PM   #38
SCHRUMGMC
SCHRUMGMC's Avatar
Great to know !! Thanks bud
1971 GMC Sierra
1959 GMC 100
Old 03-19-2014, 05:27 PM   #39
SCHRUMGMC
SCHRUMGMC's Avatar
1971 GMC Sierra
1959 GMC 100
Old 03-19-2014, 07:26 PM   #40
OrrieG
OrrieG's Avatar
to test the sender and gauge
http://www.americanautowire.com/view...oubleshooting/
to test the tstat, put it in a pan of water, borrow your mom's candy thermometer, when it hits the listed temp it should open. If not, its bad.
Old 03-19-2014, 09:03 PM   #41
SCHRUMGMC
SCHRUMGMC's Avatar
Coming to think of it, it could be a fuse...Orrie is there a Fuse diagram?
My truck has a small little fuse holder under the Dash
1971 GMC Sierra
1959 GMC 100
Old 03-20-2014, 06:50 AM   #42
Old Truck Man
Old Truck Man's Avatar
The worst thing about ethanol and all the new gas is its unleaded. On older engines the lead is the lubricant needed for the valve seats. Keep running unleaded in a older engine and the valve seats get pounded out and the valves sink. You need hard valves or hard seats to prevent valve erosion. I add a quart of diesel fuel to every tank full of gas.
Old Truck Man is offline   Reply With Quote
Old 03-20-2014, 08:30 AM   #43
Katrina/10
Katrina/10's Avatar
Glad this is on topic.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 03-20-2014, 11:16 AM   #44
SCHRUMGMC
SCHRUMGMC's Avatar
Well Katrina, I didn't want to keep making threads
You added that to a Non-Diesel engine??? Sounds like it'd blow the motor
1971 GMC Sierra
1959 GMC 100
Old 03-20-2014, 12:56 PM   #45
Katrina/10
Katrina/10's Avatar
More people will be able to help you if the title reflects the discussion.
I hope you can get your carb fixed.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 03-20-2014, 01:03 PM   #46
SCHRUMGMC
SCHRUMGMC's Avatar
True..
Getting it rebuilt here soon for FREE
Trying to re-connect the Vacuum advance line but it won't screw in the right way
1971 GMC Sierra
1959 GMC 100
Old 03-20-2014, 01:07 PM   #47
Katrina/10
Katrina/10's Avatar
You may have to twist the line a bit to get the nut to thread back in.
Gary
1971 Chevrolet C/10
1951 GMC 100
1977 GMC C15
1955 Chevrolet 3100
Old 03-20-2014, 01:14 PM   #48
SCHRUMGMC
SCHRUMGMC's Avatar
Thanks, on my way out the Door now..Pulled the truck down here and it was popping and carrying on driving me insane...Hopefully this rebuild will fix all of the issues
1971 GMC Sierra
1959 GMC 100
Old 03-20-2014, 01:19 PM   #49
OrrieG
OrrieG's Avatar
Use and save the link in my signature. Scroll down to the year index and change to your year. It manual has a wiring diagram.
Old 03-21-2014, 12:40 AM   #50
SCHRUMGMC
SCHRUMGMC's Avatar
How was the Brake lights originally grounded and where was it located ?
I'm thinking on going with a ground strap
1971 GMC Sierra
1959 GMC 100
