Old 02-27-2016, 01:30 PM   #26
cagodinez
cagodinez's Avatar
Re: LQ4 with NV3500
Absolutely, I will.
cagodinez is offline   Reply With Quote
Old 02-27-2016, 04:30 PM   #27
cagodinez
cagodinez's Avatar
Re: LQ4 with NV3500
I wonder if a different brand slave would make a difference.
Old 02-27-2016, 04:32 PM   #28
cagodinez
cagodinez's Avatar
Re: LQ4 with NV3500
Auto zone duralast slave cylinder
Old 02-27-2016, 04:47 PM   #29
cagodinez
cagodinez's Avatar
Re: LQ4 with NV3500
Does anybody know what this hole is for? It seems like it's threaded.
Old 02-27-2016, 04:59 PM   #30
cagodinez
cagodinez's Avatar
Re: LQ4 with NV3500
Grinded as much as I could, still no go.
Old 02-29-2016, 03:14 PM   #31
elf w/capital T
Re: LQ4 with NV3500
check out novak website, lots of information there, or even ls1tech.com I wish I could help
elf w/capital T is offline   Reply With Quote
Old 03-01-2016, 02:10 PM   #32
elf w/capital T
Re: LQ4 with NV3500
What throwout bearing did you use? Use an extended one for the proper release... i cant find my part number
Old 03-03-2016, 11:57 AM   #33
downeyballz
Re: LQ4 with NV3500
use the internal slave version on a nv3500. I got mine out of a 1998 s-10 and it worked without any problems
downeyballz is offline   Reply With Quote
Old 04-02-2016, 09:31 PM   #34
TypeSL2
Re: LQ4 with NV3500
I ended up bailing on that style transmission, after I had a friend weld up an oil pan for me. I have this oil pan on the truck that does not leak a drop, but now I didn't even need to run it because I went with the internal slave transmission. There is just no grinding enough to make that transmission work. Has to be a difference between the S10 and 1500 transmission. If the pan was easily removed and I had a replacement, I would definitely get rid of it, just because I hate having such a useful part on here that unfortunately serves no purpose now.
James
TypeSL2 is offline   Reply With Quote
Old 04-03-2016, 11:56 AM   #35
Clyde65
1965 Chevy C10, 2005 4.8L/4l60
Clyde65's Avatar
Re: LQ4 with NV3500
Just a thought here but isnt the 3500 only rated at 350 lbft of torque? Also the lq4 torqueis higher than that factory.
Im just spewing what i have read so take it for what its worth.
Clyde65
Rebuild of Clyde
http://67-72chevytrucks.com/vboard/s...84#post8338184
69 Aristocrat Lo Liner build
http://67-72chevytrucks.com/vboard/s...84#post7561684
support our troops!
Clyde65 is offline   Reply With Quote
