12-13-2014, 05:34 PM | #26 |
Re: Baby Gets Back..... Tubbing a stepside.
Last Pic before paint. Stainless is cut, bedboards trimmed and drilled, bedsides cut and drilled and both tubs are in! Now comes a big buy...M&H 18 x345's and a pair of SLC-65's to match.
12-15-2014, 04:15 PM | #27 | |
Did you cut the wood to be flush with the frame? Great job. |
12-15-2014, 11:09 PM | #28 |
Yes. The frame steps out at the spring perch but the wood and stainless strips have been trimmed so the frame is the limiting factor on tire width. That opening now supports a 20 inch section width tire....but no one makes a tire that big!
12-16-2014, 01:20 AM | #29 |
So is that about the same as the dodge pic? I think its gonna look sweet!
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's Last edited by swamp rat; 01-10-2015 at 11:55 PM. |
12-16-2014, 07:29 AM | #30 |
Dodge? What Dodge?
12-16-2014, 01:14 PM | #31 |
The pic in post 20 post says its a dodge. ether way wondering if your new wheels will be that wide. I like it!
http://67-72chevytrucks.com/vboard/s...9&postcount=20
Mike. Swamp Rat build thread : http://67-72chevytrucks.com/vboard/s...d.php?t=595019 72 3/4T 4X4 4" BDS Lift 33" BFG's |
12-16-2014, 06:06 PM | #32 | |
12-16-2014, 08:19 PM | #33 |
Ok i get the dodge part, Just a term usage i have not ever heard of before. The pic post in 20 sure looked like a chevy to me anyway looking at the side conture of the doors.
That still brings up my question, are your wheels and tires gonna be that wide? "M&H 18 x345's and a pair of SLC-65's to match" Guess i can google it..
12-16-2014, 10:02 PM | #34 | |
M&H345's are Tread Width: 12.3" • Section Width: 13.8" • Diameter: 28.0" • Circumference: 88.0" So they are a bit narrower than the ones in that pic. Those are Mickey Thompson 31X18.00R15LT with an 18 inch section width but they need a 14 inch rim which billet Specialties does not make and I want to match the fronts. Those tubs will accommodate a 20 inch section width tire. |
12-17-2014, 10:01 AM | #35 | |
And I googled that and couldn't find much. Glad I'm not the only dummy. Truck is looking good! Now I'm looking more in to widening the bed like mentioned earlier by adding width in the middle of the bed. |
12-17-2014, 12:47 PM | #36 |
Yeah baby!
This is the image that explains how I widened the bed but kept the stock tailgate.
First you have to cut off the vertical seamed panel that the tailgate hinges on and weld it up smooth. Then add an angled steel piece that shifts the side panel out an inch and a quarter. Sorry the truck is dusty as lots of work going on at the moment.
11.37 @116 |
12-17-2014, 01:44 PM | #37 | |
12-17-2014, 04:01 PM | #38 |
Yeah baby!
I agree, I run 285/55 18 tires with a 3 and a quarter back space on the street. These would not need a tub but my 15 x 12 wheels for my slicks mean I run an inch and a half minitub.
11.37 @116 |
01-10-2015, 08:06 AM | #39 |
All Right! Tubs are finished so now it's time to get to the reason the truck was tubbed in the first place. It takes a large tire to get 650 HP to the street and get it to hook up in a light truck. The Stepside fenders will now take a tire with an 18 inch section width and it's time to narrow up the axle so I can get a wheel in those tubs with a 'reasonable' backspace.
Here's what you need. A 6 foot (yes, 72 inches) finish ground steel round bar 1.5 inches in diameter, inner alignment blocks that mount where the differential carrier Bearings would normally go, Outer alignment blocks that fit into the housing ends and, if you're going to get rid of those pesky 'C' clip axles which none of the drag strips will allow you to run, new Ford housing ends, bearing seals and bearings and a set of shorter axles splined for the 12 bolt carrier on one end and with the ford big bearing bearing seats on the other and a pinion centering plate for determining the length of the new axles for the shortened housing. So, here's pictures of the tools and the new axle ends. Now all I've got to do is get the truck in the air, drop the rear axle, disassemble it, and (GAK) cut it! Don't try this at home, kids, if you don't have a good saw, a welder you know how to use and a pair big brass ones. Mess this one up and you will need to find about $3000.00 to fix the mess you made! If the housing is cut straight the alignment bar will keep the new axle ends perfectly aligned with the carrier so when you reassemble there will be no binding IF you don't put too much heat on one side of the housing as you weld. I will tack in four places 90 degrees apart, let it cool and do the same but the second time the four tacks will be rotated 45 degrees placing them between the first four. Continue until boredom sets in and make two welding passes, not one. You'll get a stronger joint. Last edited by Fitz; 01-10-2015 at 08:15 AM. |
01-10-2015, 08:40 AM | #40 |
Where did you get the skills to do this? Are you a Mechaical Engineer?
1970 C10 Short Stepper with 71/72 front clip. |
01-10-2015, 12:17 PM | #41 |
01-10-2015, 03:17 PM | #42 | |
I cannot fathom a better way to do it. Can I borrow that tool at O'Reilly's? LOL |
01-10-2015, 04:08 PM | #43 | |
OK now you got me to thinking. I have a nice metal bed bottom with factory tubs (out of a 92 SWB fleetside that had a bedliner all it's life) that I was thinking of using as a floor on my 68 SWB stepside. Looks kinda tough to extend the front of the bed and to modify the tailgait area as shown. Might be outa my league on fabrication skills. The stepside rear fenders do look to be narrower in total than the front fenders though. |
01-10-2015, 08:18 PM | #44 | |
motor exploder
Lookin' good Fitz!
Adam 1969 Chevy CST/10 stepside, DART Big M/TREMEC Magnum Extreme/3.73's w/Detroit Truetrac 1965 Chevy Bel Air Wagon (daily driver), 327/TH350,10 bolt w/3.08's 1961 Chevy Bel Air Sport Coupe, ZZ454/M21/9" rear w/3.50's & Detroit Truetrac 2005 GMC 1500 ccsb 2wd, 6.0L/4L65e/3.73 G80 2006 GMC 2500HD ccsb 4x4, DMax LBZ/Allison 6spd/4.56's w/Detroit TrueTrac Use the SEARCH function on this forum - it is your friend!! |
01-10-2015, 08:50 PM | #45 |
BlahBlahBlah
Fitz you do great work. Love reading your build posts!
01-11-2015, 12:37 AM | #46 |
I'm getting in here to watch and appreciate this build
01-11-2015, 08:00 AM | #47 | |
http://www.mittlerbros.com/mittler-b...wing-kits.html Expensive if you go for a set of tools for Ford, Dana and GM but less than half for GM only. The Mark Williams tooling is a bit less expensive, but they use a 39 inch bar to do one side at a time. http://www.markwilliams.com/detail.aspx?ID=163 I thought everyone did it this way. Go figure! Last edited by Fitz; 01-11-2015 at 08:14 AM. |
01-11-2015, 08:13 AM | #48 |
:lol
Duplicate post. How did that happen? |
01-11-2015, 08:16 AM | #49 |
01-11-2015, 08:27 AM | #50 |
Two shots after final paint. Kudos to the guys at Finish Master in Tucson. They mixed up a perfect match for that gunmetal metallic gray, and if you have ever tried to match a metallic you know what a PITA that can be.
