03-21-2014, 08:20 PM | #26 |
Re: HELP..Easiest way to raise a low truck?
That's something I will look into after the weekend. I'll get better pictures of the rear and confirm the b.s. of the fronts. Any front spring suggestions? Thanks
03-21-2014, 10:02 PM | #27 | |
Moog # 6542 842 lbs/in std v-8 Moog # 6102 1015 lbs/in bigblock, longbed c.s. Moog # 6104 1016 lbs/in 3/4 ton, sits 1/2" higher than #6102 Moog # 6454 1060 lbs/in 3/4t bbc, c.s, 1ton I would opt for the 6542 or the 6102 & trim them to work.
03-22-2014, 11:04 AM | #28 |
Cool I'll look into that for the front... and I have to c now what to d do for the back
