Old 04-08-2014, 07:37 PM   #26
stomper
Junior Member
stomper's Avatar
Re: Don Pedro - 83 Sierra Classic brown stepper
Oh the catalytic converter? Yea this one's been on there for 30 years. It's got to be plugged up solid - hahaha. It's a wonder it even ran and drove. When I connect the LS to the existing exhaust it will be after that fo sho.
"I was patina when patina wasn't cool."
1973 Cheyenne SWB Sunset Gold / Frost White / Saddle
stomper is offline   Reply With Quote
Old 04-10-2014, 02:12 PM   #27
stomper
Junior Member
stomper's Avatar
The 4.8 and trans is waiting to be picked up!
Old 04-12-2014, 03:09 AM   #28
stomper
Junior Member
stomper's Avatar
Unloaded it tonight
Old 04-13-2014, 01:07 PM   #29
tip
Awesome, great motor choice!
tip is offline   Reply With Quote
Old 04-13-2014, 05:57 PM   #30
rip2174
nice looking truck
rip2174 is offline   Reply With Quote
Old 04-14-2014, 08:12 AM   #31
burb1085
burb1085's Avatar
Subscribed. Nice choice.
burb1085 is offline   Reply With Quote
Old 04-14-2014, 08:29 AM   #32
stomper
Junior Member
stomper's Avatar
Worked on the engine harness today. I referred to instructions on LT1swap.com
Old 04-17-2014, 02:27 PM   #33
stomper
Junior Member
stomper's Avatar
Fitted the mounts to the engine. I can drop it in for a test fit now. Looks like the A/C will HAVE to be moved to take advantage of any of the slot.
Went with these: http://dirtydingo.com/store/product_...oducts_id=1308
Old 04-17-2014, 02:33 PM   #34
stomper
Junior Member
stomper's Avatar
Got a plan for the fuel system. Using existing dual tanks. Adding '87 sender assemblies with '96 pumps. Found a high pressure tank switch valve and '87 dash switch to maintain the dual tank set up. Plan on using high pressure fuel injection hoses and as much of the existing steel line as I can. Still need to figure out the dual fuel pump relay switching plan. I got the WIX 33737 Fuel Filter $ 32.79 also but not sure exactly if I need this or how I will plumb it. The truck has return and vent lines (3 lines) from the valve forward and 2 lines coming off the motor. I assume one is fuel return but dunno if there's a regulator up there yet.
1996 CHEVROLET C1500 PICKUP 5.7L V8
PERFORMANCE ELECTRIC P240KC Fuel Pump $ 20.79
1987 CHEVROLET R10 PICKUP 5.7L 350cid V8
ACDELCO D7089C Fuel Tank Selector Switch $ 11.95
SPECTRA PREMIUM / COOLING DEPOT FG05M Fuel Tank Sending Unit $ 62.79
SPECTRA PREMIUM / COOLING DEPOT FG05N Fuel Tank Sending Unit $ 68.79
Pollak FSV2A 6-port Dual Fuel Tank Gas Select Valve W/ Toggle Switch 65 PSI Max $79.95
