#26 |
![]() Join Date: Sep 2013
Re: Truck is done
Nice looking truck! good luck with gas mileage and with a 700r4 it should be better than that!
#27 |
![]() Join Date: Sep 2011
Re: Truck is done
Sweet truck, good job!
Past Master Triluminar Lodge #117 GL of WVa My 1963 4x4 Suburban build; http://67-72chevytrucks.com/vboard/s...d.php?t=531274 My Gallery, now with pics of my 1966 C30 motorhome. http://67-72chevytrucks.com/gallery/...&ppuser=103447 |
#28 |
1965 Chevy C10, 2005 4.8L/4l60
![]() Join Date: Aug 2004
Re: Truck is done
I would second some of the ideas here. I think the rear is too low, if you have a 12 bolt, then you can only go to a 3.73 ( 4 series rear), which may only help a little. Beak in on the motor wont help but a little also, I am not sure the stall would or could be an issue.
I really like you truck, you did a fantastic job on her!!!
Clyde65 Rebuild of Clyde http://67-72chevytrucks.com/vboard/s...84#post8338184 69 Aristocrat Lo Liner build http://67-72chevytrucks.com/vboard/s...84#post7561684 ![]() ![]() ![]() support our troops! |
#29 |
It's alsways something.....
![]() Join Date: Nov 2008
Re: Truck is done
Like Clyde said, 3:73 is the gear for 700R4. make sure your converter lock up is working correctly. IMO you should be seeing around 12 mpg
1968 RS Camaro 'Vert Matching number 327 and M21 Muncie 1968 C10 Black with red interior and orig paint. 5.3 / 4l60e,3:73 POSI 17" Torq Thrusts 1968 CST 514 Red with black interior. Buddy Buckets, Factory A/C, PS, PB- 20" AR custom shop TT, 5.3 and 4l60e |
#30 |
![]() Join Date: Jul 2013
Re: Truck is done
Thank you, I think I will go with the 3.73 gears it is 10 bolt rear end. Do you guys have an idea what the cost would be if I do the work myself
#31 | |
Re: Truck is done
1. 350/quadro jet----? hp ? 2. transmission 700r4 3. current rear axle ratio 4:10 4. tire diameter ? what is the height of the rear tires from the ground to the top of the rear tire ? after determining this diameter you can go to this link and see how your truck should perform......the key is torque within a usable range of speeds we want to make sure your truck will pull taller gearing and that the truck is cruising at around 2000rpm at 65-68 mph with at least 460 ft lbs of torque... Here is a link to spreadsheets that show you that information: go to post 6 or 7 there are file names with diameters in their name , click on the closest diameter and you can see which rear axle ratio you need. http://6066gmcclub.com/forum/showthread.php?t=48090 |
#32 |
Re: Truck is done
Kieth,
the link wont let me in those PDF's without logging in...do I have to register and do all that??
#33 |
Re: Truck is done
Very Nice !!!
#34 |
Re: Truck is done
first off if you really do run a 2500 stall converter and go to a taller rear gear you will be in trouble. It works like this.
the R4 has an Overdrive and a taller gear, (3.73 to 1) will net a 60 MPH cruise RPM under the stall "lock" point on the converter. What this does is generate more heat and wear in the Transmission. R4's really prefer electrically locked converters for this very reason. I would also self calibrate the actual speedometer error. Easily done then you will have a better level of accuracy to determine your true MPG. Around town stop and go with a low gear and short tire with a Quadrajet can easily keep you under 8 MPG. However driving style has a huge effect on it. |
#35 |
Re: Truck is done
Ambros,
1 way to check exactly what your gear ratio is while running a certain height tire is to jack the rear of the truck up, with ignition off, put a mark at 12:00 on your rear tire, the n go under the truck and put a mark at dead bottom center of your drive shaft. then have someone slowly turn the tire exactly one rotation while you are under the truck counting how many revolutions the drive shaft makes. ex: if the tire is turned exactly one rotation and your drive shaft turns, say a little more than 4 times, I would equate that to roughly a 4:11 gear ratio. I believe this to be quite accurate but someone correct me if this isnt. I didnt read through all the posts, maybe someone else has suggested this?....Bullett |
#36 |
Re: Truck is done
Tires are 29 inch high I will talk to the guy who helped me with the transmission exactly what the stall converter is
#37 |
Re: Truck is done
Nice ride!!!!
#38 |
Re: Truck is done
Looks great.
#39 |
![]() Join Date: Oct 2011
Re: Truck is done
Beautiful truck.....
1960 Chevy Stepside 2wd 1966 Chevy Fleetside 2wd 1965 Chevy Suburban 2wd 1965 Chevy Fleetside 4X4 1960 Chevy Fleetside BBW 2wd |
#40 |
![]() Join Date: Sep 2009
Re: Truck is done
very nice truck. the motor is new so mileage may vary.lol my 64 gmc with 350 --2004r tranny 3:54 gears and a mild 1800 stall converter gets 14. mpgs at 72 mph turning 2100 rpms.
#41 |
Re: Truck is done
Thank you, I think we may have gotten it solved it does have an 1800 stall we had a problem with the cable and it was in overdrive just driving around town. I just drove it around and seems like a different truck.I will see on the next tank of gas where we stand
#42 |
Re: Truck is done
Nice truck, give yourself a pat on the back!
C/10 Rene 1966 Short Fleet "The Hag" 1967 CST Short Fleet "Dark Poly" 1971 Short Fleet 1970 Jimmy Custom 2 WD "Golden Ticket" 1972 Blazer 2 WD "Retro Blaze" |
#43 |
Re: Truck is done
I will try to make it it is real close to me
