Old 03-27-2014, 06:53 AM   #26
Andy4639
Old member
Andy4639's Avatar
Talking Re: Old School to New Look
Originally Posted by engineer_gregh View Post
Thanks for all the comments folks. It will be the weekend before I can spend any time getting the front wheels on unfortunately. I'm still trying to decide on spacers or grinding. Andy your truck is sharp, its very obvious that you've put in a lot of work to get it that nice.
Thanks, I have tried to make it a looker and a driver both. I'm fixing to start on the dash again to prepare for the Power Tour again this year. I have the delay windsheild wiper mod to install and some small issues on the dash it self. Thanks.
The truck will look just fine with either set of wheels. That's the orignal color combo of my truck when I bought it.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 03-27-2014, 07:35 AM   #27
19GM71
19GM71's Avatar
Originally Posted by mgkgmc View Post
19GM71 What width wheels are you running in the front and back? What offset are you running too? Thats a nice stepper you have.
My wheels are all the same. 20x8.5 with 5.25 backspace and 245/45/20 tires. Thank you for nice comments!
19GM71 is offline   Reply With Quote
Old 03-27-2014, 08:11 AM   #28
jjzepplin
jjzepplin's Avatar
How would 275/55/20 look? Any one running that size?
70 swb 4x4 406sbc 700r4 203/205 d60/14blt locker yadda yadda http://67-72chevytrucks.com/vboard/s...88#post6935688 Yeller
72 Blazer 2wd conversion project "No Daggum Money" http://67-72chevytrucks.com/vboard/s...d.php?t=550804 LS1-T56 3.73 LSD super budget build
Blanco-2014 Sierra SWB https://67-72chevytrucks.com/vboard/...d.php?t=810350
jjzepplin is offline   Reply With Quote
Old 03-27-2014, 08:21 AM   #29
CC69Rat
CC69Rat's Avatar
275/25.4*.55*2+20
5.95" sidewall - 31.9" overall. That's a big tire. Not lowered or anything I'd be curious to see it though. I'd say it would look good.
Chad
1967 C10 SWB - Project Savannah - 6.0/4L80 *Currently underway*
1968 C10 SWB - TOTY 2018, 50th Anniversary Tribute Project * Sold * Pride and Joy
1986 Silverado Short Fleet - Scarlet *Sold*
1985 Silverado Short Fleet *Sold*
2022 Jeep Gladiator Mojave
2001 Jeep Cherokee XJ 4x4 - Lifted, Built
1992 Jeep Cherokee XJ 4x4 - Lifted
2013 Honda Accord EX-L v6 Coupe 6spd (wife's ride)
CC69Rat is offline   Reply With Quote
Old 03-27-2014, 09:26 PM   #30
engineer_gregh
engineer_gregh's Avatar
I did buy spacers as a temporary solution. I picked them up at Auto Zone, 5/16". Here are a few pictures.
engineer_gregh is offline   Reply With Quote
Old 03-28-2014, 09:21 AM   #31
Cape Codder
Cape Codder's Avatar
How much tread do you actually have in the nut after the wheel thickness is subtracted? I don't like spacers for that reason. I would think about longer studs.
Cape Codder is offline   Reply With Quote
Old 03-28-2014, 11:16 AM   #32
Andy4639
Old member
Andy4639's Avatar
Wink Re: Old School to New Look
Longer studs are extended thread lug nuts that go down through the spacer. That's what I bought.
Old 03-28-2014, 11:42 AM   #33
engineer_gregh
In my case the spacers are temporary. I don't intend on keeping them as I will not take any chances of losing a wheel at highway speeds. You'll have to decide for yourself if they are safe or not. Here is are a couple of links I came across when researching the topic. "Make sure you have a minimum thread engagement of the diameter of the vehicle stud (as recommended by SAE). An example is, if the stud size of your vehicle is ½" then you will need a minimum of ½" of threads into the lug nut."
http://www.performanceplustire.com/t...rs-and-Spacers
http://www.performanceplustire.com/t...about-lug-nuts
