Old 03-29-2014, 06:10 AM   #26
Sloan66
Re: Help! Engine troubles
Checked manifold with starting fluid, no leaks.
Sloan66 is offline   Reply With Quote
Old 03-29-2014, 07:15 AM   #27
71K20chevy
71K20chevy's Avatar
It could also be leaking from the lifter valley into the intake, and that won't show up with starting fluid. I wouldn't pull the intake just yet..
71 K20
64 GMC mud truck
71K20chevy is offline   Reply With Quote
Old 03-29-2014, 11:01 PM   #28
Legolas894
Chemist under the hood...
Legolas894's Avatar
I'm still thinking vacuum. Did it run any different with the vacuum advance off? Can't remember if an HEI has a vacuum advance...I'm still a points man. What about the choke? Does the same thing happen after it's warmed up?
There's a reason people went fuel injected...No the least was the fiddling with carb mixtures, timing, choke etc
Current fleet:
2013 GMC Sierra, 5.3L, 4x4
1988 GMC Sierra, 305, Auto
1984 Jeep Grand Wagoneer, 360 V8
1997 VW Cabrio, 2.0L
2017 Toyota Rav4, 2.5L
Stuff I wish I still had:
2013 Toyota Matrix [RIP]
1967 GMC 910 Fleetside, 283 V8 [1st Love-SOLD]
1987 Jeep Cherokee Laredo 4X4, 4.0 I-6 [SOLD}
1994 Chevrolet Caprice Classic, 5.7LV8 [SOLD]
1995 Chevrolet Astro AWD, 4.3L V6 (RIP)
1998 Chevrolet Suburban 4x4, 5.7L V8 [SOLD]
Legolas894 is offline   Reply With Quote
Old 03-30-2014, 12:02 AM   #29
knomadd
knomadd's Avatar
Did you try the carb to intake? I've had two vehicles where the gasket either developed a vacuum leak or had one from the beginning and caused all sorts of headaches before it was discovered.
-Duane
C/10 Club Texas member
1971 Chevy C10 "Brutus" SWB Fleetside 2016 6.0L (L96) 6L90E (driver/project)
1965 Pontiac GTO "Royal Goat" 400/TH400 w/AC (my baby)
knomadd is offline   Reply With Quote
Old 03-30-2014, 12:17 AM   #30
BMERDOC
BMERDOC's Avatar
Did you get around to verifying the condition of the plug wires? I think East Tx was pointing you in a good direction. Sounds like an ignition misfire to me. Bad wires will "leak" under load and cause a misfire.
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 03-30-2014, 12:21 AM   #31
BMERDOC
BMERDOC's Avatar
I pointed you out to this guy so I'll point him out to you too. You guys are both having similar problems.
http://67-72chevytrucks.com/vboard/s...d.php?t=622906
Nick Carter
Old 03-30-2014, 12:25 AM   #32
70SBC10BOB
70SBC10BOB's Avatar
What is the manifold vacuum at idle? If it is north of 17" of vacuum, I don't think you would have a manifold leak. If it is less, it could be internal leak.
If the vacuum is less, put the vacuum guage on the dipstick tube and plug all other vacuum sources (ie pcv, brake booster etc.). If you have vacuum at the dipstick, chances are you have an internal leak.
Good luck.
1970 C 10 A work in progress!!
70SBC10BOB is offline   Reply With Quote
Old 03-30-2014, 01:25 AM   #33
litew8
litew8's Avatar
Reiterating my previous comments - if you removed the carb and reassembled with an old base gasket, I'd replace with new. You'll find the source, keep looking.
project: "my happy mess"
litew8 is offline   Reply With Quote
Old 03-30-2014, 07:11 AM   #34
Sloan66
Thanks men, it rained all day yesterday so I was un able to do anything. I will check vacuum, and other ideas today. Internal vacuum leak? where would that come from? Just never heard of such before.
Old 03-30-2014, 06:07 PM   #35
70SBC10BOB
70SBC10BOB's Avatar
Internal vacuum leak would be caused by a bad gasket seal on the intake. Instead of leaking on the outside where you could locate it with carb spray along the intake/head joint, it would leak inside or at the bottom of the same joint. The leak would be into the engine valley creating vacuum in the crankcase. Sometimes this type of leak will cause blue exhaust smoke because oil is sucked in.
Keep swingin' at it.
Old 03-31-2014, 08:19 AM   #36
Sloan66
Worked on it yesterday.
Moe info: Vacuum was 20, plugged all the ports did not get an vacuum at dip stick.
I did not get to replace carb gasket yet as no one had one, will pick one up today. Researched further still think I might have a small vacuum leak internally. When you first start motor in morning it sound slike it has a mild cam, then as it warms up it smooths out. Thoughts? If I end up pulling the manifold how can I assure that I it get it to seal. I have been using felpro gaskets, fyi.
Old 03-31-2014, 10:46 AM   #37
engineer_gregh
engineer_gregh's Avatar
Hi Sloan66. I live in Smyrna and have a 71 with a 307 two barrel. You're more than welcome to stop by and compare the two. I have some extra plug wires, and a freshly built 2 barrel carb. Let me know.
engineer_gregh is offline   Reply With Quote
Old 03-31-2014, 11:03 AM   #38
70SBC10BOB
70SBC10BOB's Avatar
With 20" of vacuum, I don't think you have any leaks. That is a great vacuum reading.
Don't we just love working on trucks?!?
Old 03-31-2014, 11:13 AM   #39
70SBC10BOB
70SBC10BOB's Avatar
Before you pull the manifold. Have you checked the float level of your carb?
With engine [U]not running[U] can you see if the accelerator jets are spraying out of both squirters when you operate the throttle?
The spray should pretty much start and stop with the throttle movement. There should be no delay at the beginning and no stopping until movement stops. (You would only work the throttle a couple of times before you have to start the truck to refill the accelerator bowl.)
We are havin' fun now!
Old 04-01-2014, 01:44 PM   #40
Sloan66
Greg, Thanks for the offer, may take you up on it will PM you.
Old 04-07-2014, 10:04 AM   #41
Sloan66
Re: Help! Engine troubles-Solved!!
Thanks for everyones help. Wanted to update, figured out the issue. After replacing intake gaskets, checking carb, fuel pump, it was a bad plug in #5!!!
I swear I thought I checked them all earluy on, but apparently I missed #5. It was fouled pretty good. I checked compression and for an old motor all cylinders were good, averaged 130, so that plug must have been bad out of the box.
Again, thanks for all the help! Forum is awesome.
Old 04-07-2014, 10:52 AM   #42
litew8
litew8's Avatar
How does a bad plug act like a vacuum leak?
Old 04-07-2014, 11:21 AM   #43
70SBC10BOB
70SBC10BOB's Avatar
Glad you killed the dragon!!!!
Just remember to do ALL of the basics first. You can not short cut the basics or you get bit in the butt!!
Good job at not giving up.
