Old 10-12-2014, 12:06 PM   #26
MTCK
MTCK's Avatar
Re: Ol' Brown - 1985 K3500 SRW slow build
Check out ORD's zero rate add a leaf. That could give you an inch on either end.
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 10-12-2014, 02:29 PM   #27
tip
That's kinda what I'm thinking, or their 1" body lift. Probably will get the zero rates though, along with some other goodies.
So stoked as I had budgeted quite a bit for a complete ORD 3/4" suspension. Going to be saving some serious money this way. Money I can put into other areas of the truck.
tip is offline   Reply With Quote
Old 10-12-2014, 02:51 PM   #28
hardcore4life
hardcore4life's Avatar
You're making me reconsider a lift on my truck. I wanted to do the same lift to my 86 one ton, but now I'm not so sure.
68 C10 lwb, 406 sbc, 700R4
86 K30 srw, 454 bbc, TH400
11 Camaro RS, 217 V6, 6M
hardcore4life is offline   Reply With Quote
Old 10-12-2014, 03:20 PM   #29
y5mgisi
Second Chance Program
y5mgisi's Avatar
That sure seems taller than stockbut eieither way, it looks amazing! So the tires are smooth on the highway with the dyna beads? How much did it cost to do theset of 4 tires with tthem
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 10-14-2014, 12:18 AM   #30
tip
Thanks! I haven't had it on the highway yet, but 40-45 on the back roads the tires ride smooth. The rest of my suspension and steering is another story
It was about $100 after shipping. Their chart calls for 8 oz beads but I went with 10 oz. I also got the larger "off road" ceramic beads that are made for meatier tires and large enough that they won't get stuck in the valve core.
Here is their website: http://www.innovativebalancing.com/index.php
I've also heard of guys dumping copper BB's into their tires too, FWIW
Old 10-14-2014, 12:38 AM   #31
y5mgisi
y5mgisi's Avatar
I have been doing extensive research on them and the centramtic balancers. I really want to do both. I really hate vibrations.
Old 10-14-2014, 01:03 AM   #32
tip
Yeah centramatics are really cool, just couldn't swing the extra $ for them. There is a guy on another forum with a F350 and bead-locked 37's and he says they work great.
Having both would be awesome!
Old 10-14-2014, 01:38 AM   #33
farmall
farmall's Avatar
I checked on having my front springs rearched and they said they could not do tapered springs at Benz in Portland.
1955 GMC 250 8 Flatbed
1971 C30 157" 350 4spd 10' Flatbed
81 GMC K30 CnC 9' Flatbed 454 T400
89 GMC Jimmy Stock https://67-72chevytrucks.com/vboard/...d.php?t=810958
71 LT1 Convertible, 72 Coupe
69 CJ5, 75 CJ6, 67 M715, 72 M35A2 Bobbed, 95 XLC2
farmall is offline   Reply With Quote
Old 10-14-2014, 02:35 AM   #34
y5mgisi
y5mgisi's Avatar
What about Oregon spring in Portland?
Old 10-20-2014, 10:09 PM   #35
400/400
Have you started tackling the floors yet?
1979 K25 350/SM465/205/44HD/14FF
1985 K20 400/400/208/10/14
1987 V10 TBI350/700R4/208/10/10
'85 Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=643968
400/400 is offline   Reply With Quote
Old 10-21-2014, 05:22 PM   #36
tip
Unfortunately it will be a while before I get started on the floors. I don't have access to a shop and we just started the 'rainy season' here in the PNW (so rain 'til June).
On a side note, we just welcomed our first child in the family, a healthy little boy. So as if my progress wasn't slow already, it will be moving at a glacial pace now.
I did run the truck into town this morning for some errands. Last week, I had sprayed some PB Blaster on the throttle shafts and choke linkage in hopes to free up the sticking throttle and fast idle cam.
Fired her up this morning and ran it on fast idle. Gave it a good blip of throttle and it returned to idle just like it should... hopefully that takes care of it for now while I figure out whether or not I wanna mess with rebuilding it. It was getting annoying opening the hood and flicking the cam off every time I started it.
Old 10-21-2014, 07:14 PM   #37
400/400
Congrats!
Did you put something on the floors to stop the rust till you can address it?
Old 10-23-2014, 07:22 PM   #38
tip
Yeah, I had some Eastwood Rust Encapsulator laying around so that should keep the rust at bay for a little while.
Old 10-23-2014, 07:51 PM   #39
y5mgisi
y5mgisi's Avatar
Had the tires on the hiway yet with the dyna beads? My truck is good up to 55. Beyond that it gets crazy bad vibes until it's completely out of hand by 70. I think my tires might be messed up but I really want to try the beads before I buy a new set of tires.
Old 11-16-2014, 09:46 PM   #40
tip
Sorry for the late reply. I haven't had a chance to run it on the highway until today. I took a 100 mile roundtrip drive today and had it up to 60 on the freeway. Tires felt great, no vibrations at all. I was impressed.
I took the trip to pick up an ARE DCU canopy that I found on craigslist. The guy said it came off an '86 Crew Cab Dually (which was on the property) but it wouldn't fit my truck. Pretty bummed...
Old 11-16-2014, 10:28 PM   #41
400/400
Noticed in your signature you've got a 400 under the hood as well. How's she run? Any under hood pics?
Old 11-17-2014, 01:16 PM   #42
tip
Yep, the original owner had a 400 swapped in during the 90's. Not sure why, but the receipts where included.
It runs pretty good, needs some carb work. Here is the only picture I have, when I first picked it up. I've since removed the rats nest of wiring.
Old 11-17-2014, 06:51 PM   #43
Got Smoke?
Got Smoke?'s Avatar
Cheaper solution to Dynabeads that work just the same. I got a little over 60,000 miles out of a set of Mastercraft Courser ATR's on my 97 F350 hooked to a 43' car trailer everyday.
www.checkeredflagtires.com
97 Dodge 2500 12V NV4500... way to much to list.
79 Chevy K20 4" RC/37" GY OZ's 350/465/205.... restoration somewhere in the futue....
NEW: Project 88 Chevy R3500 3+3 / 88 V3500 3+3 combing two to make one....
Got Smoke? is offline   Reply With Quote
Old 01-31-2016, 12:58 PM   #44
y5mgisi
y5mgisi's Avatar
Anything new?
Old 02-02-2016, 02:00 PM   #45
Matt Man
Matt Man's Avatar
Love this truck, would like to see more updates on it. The regular cab SWR k30's are getting difficult to find.
86 c30 crew cab dually 454/400 4/6 drop SOLD 1-8-11
1981 chevy K10 short Bed Scottsdale SOLD 10-26-2020
67 GMC Stepside Straight six/3 on the tree "The Peach"
2020 Silverado Double Cab LT Z71 5.3 8 speed Daily Driver
K10 build http://67-72chevytrucks.com/vboard/s...d.php?t=671934
The Peach build http://67-72chevytrucks.com/vboard/s...d.php?t=733903
Matt Man is offline   Reply With Quote
