Old 04-12-2014, 10:28 AM   #26
slow-1
slow-1's Avatar
Re: Can't tell if I'm hearing lifter or rocker rattle.
Originally Posted by jhwkns View Post
Are You positive that it's not an exhaust leak?
Thats the first thing I thought of when I saw headers in the pic if the motor.
The other thought I had was a ground off cam lobe.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 04-12-2014, 10:38 AM   #27
Black70c10
Black70c10's Avatar
Yeah I'm pretty sure. It is very clearly a tapping that's been isolated to the #8 intake valve. I've tightened the nut until the point the engine bogs down and it will improve slightly then after about 5 seconds it will revert back to an obnoxious ticking.. Oh well, I'll just replace all the lifters and hope that it's good to go from there. Hopefully the cam is good as well
Black70c10 is offline   Reply With Quote
Old 04-12-2014, 01:01 PM   #28
slow-1
slow-1's Avatar
I think you are on the right track.
While you have the valve cover off, pour some Marvels Mystery Oil down the pushrod, let it soak a couple hours, then see if whatever is not working starts working again...worth a try.
Old 04-12-2014, 03:26 PM   #29
jhwkns
Registered Cruiser
jhwkns's Avatar
If the lifter is bad like you say, the chances of your cam not being damaged are very slim. Sorry.
I intend to live forever. So far, so good.
jhwkns is offline   Reply With Quote
