Old 04-09-2014, 06:48 PM   #26
Andy4639
Old member
Andy4639's Avatar
Wink Re: Hid headlights?
Here are mine.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver
Seeing the USA in a 71
Upstate SC GM Truck Club
2013,14 and 2016 Hot Rod Pour Tour
http://upstategmtrucks.com/
Get out and drive the truck this summer and have some fun!
It sucks not being able to hear!
LWB trucks rule, if you don't think so measure your SWB!
After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs.
Andy4639 is offline   Reply With Quote
Old 04-09-2014, 08:00 PM   #27
WH0DAMAN
Re: Hid headlights?
Originally Posted by custom 68 View Post
i just did a quick search so if you do that you will find tons of information. It is here http://67-72chevytrucks.com/vboard/s...d.php?t=507368
basically tho is continue to use a "conventional" non hid bulb setup there are several to choose from but then put the relays close to the front of the truck by the head lights, this will give you a full 12-14 volts this makes a huge difference in light output from where you are now. The balist is used in the hid conversions. You will get lots of negative input on a cheap conversion as they are not made correct and usually end up blinding the other drivers and not giving you any additional light since it is not in teh correct housing. Do a couple searches and you will find it is best to do the relays and better newer sealed beams.
x2
Silver Creek Auto Body & Detailing
My 70 Chevy Suburban build:
http://67-72chevytrucks.com/vboard/s...=574056&page=3
WH0DAMAN is offline   Reply With Quote
Old 04-10-2014, 12:51 PM   #28
907lukeman
Re: Hid headlights?
Originally Posted by SS Tim View Post
Since Classic is so sparse on details and pictures, what are you getting for $35. Is it a quality heavy gauge harness? Are the relay feeds fused? Is the instruction sheet any good or real basic?
good quality. and they have a instruction sheet that is step by step. its pretty basic.
907lukeman is offline   Reply With Quote
Old 04-21-2014, 10:57 AM   #29
TDH1989
Re: Hid headlights?
Originally Posted by Cris.sanchez3 View Post
This is were I got mine they have lifetime warranty and work well
http://www.ebay.com/itm/121071715666?redirect=mobile
He has all the info you need on the color and if I'm not mistaken once you get the other non-sealed headlights the bulb you will need is h4
Your headlights are exactly what I've been searching for for my 67. What headlights did you have to go with to get this look. I know everyone has been talking about these jeep headlights
TDH1989 is offline   Reply With Quote
Old 04-21-2014, 11:42 AM   #30
skorpioskorpio
Re: Hid headlights?
Just so you know, HID is not a focused beam and requires a completely different reflector design. HID conversions (using a reflector intended for a prefocus halogen capsule) are specifically illegal at federal and many state levels and several companies selling these exact products have been fined heavily already.
Additionally you can search my posts, I've posted many times on the subject HID headlights in a huge 7" reflector is just dumb, HID exists to put a cooler light source in a smaller more aerodynamic (and typically plastic) package. It is not a better light source, quite the opposite, they create night blindness. HID will be entirely replaced by high output LED in less than 10 years and is already starting to be phased out. HID is to automotive lighting what plasma is to flat screen TVs, an inferior impractical technology to address a packaging problem (that we don't have), nothing more.
skorpioskorpio is offline   Reply With Quote
Old 04-21-2014, 11:47 AM   #31
TDH1989
Re: Hid headlights?
Ok so do you have the complete set up I would need to change my factory 67 c10 pickup headlights to the led setup?
Old 04-21-2014, 01:08 PM   #32
skorpioskorpio
Re: Hid headlights?
There is (or was) a setup that is a 7" replacement offered by Harley for the bikes, don't know the status on it, but easy enough to search for.
Um here it is:
http://www.harley-davidson.com/store...-11-7339010--1
Not cheap, you'd need 2.
Old 04-21-2014, 02:13 PM   #33
TDH1989
Re: Hid headlights?
Um here it is:
I think I'll go with the cheaper "blinding" lights
Old 04-21-2014, 02:28 PM   #34
SS Tim
SS Tim's Avatar
Re: Hid headlights?
A close friend of mine is happily running these on his Jeep JK.
http://www.truck-lite.com/webapp/wcs...roductId=92025
SS Tim is offline   Reply With Quote
Old 04-21-2014, 08:48 PM   #35
jrigheimer
jrigheimer's Avatar
Re: Hid headlights?
I think i have ruled out HIDs because of the comments. I have came up with this for my solution. This is souly based on reviews and recommendations from friends does anyone have any suggestions of product they have tried. Also is a 100w/55w to powerful I would light bright high beams.
Harness
http://www.classicparts.com/Headlamp.../#.U1W7fq1dXMM
Lights
Amazon.com: HELLA 002395991 7" H4 Type... Amazon.com: HELLA 002395991 7" H4 Type...
Bulbs
Amazon.com: HELLA HLA-H83140141 H4 12V 100/55W... Amazon.com: HELLA HLA-H83140141 H4 12V 100/55W...
jrigheimer is offline   Reply With Quote
Old 04-21-2014, 08:49 PM   #36
jrigheimer
jrigheimer's Avatar
Re: Hid headlights?
I also heard sylvannia silverstars are nice but seem expensive
Old 04-21-2014, 09:05 PM   #37
leddzepp
Moderator
leddzepp's Avatar
Re: Hid headlights?
They aren't $500 each
1972 C/10 Cheyenne Super SWB. Restored, loaded, slammed.
1968 C/10 50th Anniversary LWB. Unrestored, stock, daily driver/work truck.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
leddzepp is offline   Reply With Quote
Old 04-21-2014, 09:07 PM   #38
jrigheimer
jrigheimer's Avatar
Re: Hid headlights?
they $40 and the hella ones a $10. I just want to know is it worth it
Old 04-21-2014, 09:07 PM   #39
DreamRyder1963
DreamRyder1963's Avatar
Re: Hid headlights?
The are $40 for the pair. They are a lot cheaper than HIDs
1971 Chevy C10 Cheyenne (sold for Mazda)
1963 Chevy Corvair Pro-Touring Project
2012 Mazda 3 i Sport sedan
http://www.dracoautodesigns.com/
DreamRyder1963 is offline   Reply With Quote
Old 04-21-2014, 09:10 PM   #40
DreamRyder1963
Re: Hid headlights?
The bulbs alone are $40. You still need a housing to put them in which is $30 for a pair. I have Sylvania ZXE bulbs in my truck and I can't really ask for more light.
Old 04-21-2014, 09:11 PM   #41
leddzepp
Moderator
leddzepp's Avatar
Re: Hid headlights?
I have them and they are worth every penny IMO. With the relay upgrade they work even better. This is the combo I will use again and again if I continue to build these trucks.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-21-2014, 09:13 PM   #42
jrigheimer
jrigheimer's Avatar
Re: Hid headlights?
what wattage do you have 60w/55w
Old 04-21-2014, 09:17 PM   #43
leddzepp
Moderator
leddzepp's Avatar
Re: Hid headlights?
I don't know. I will have to check them when I get home late tonight.
RIP ElJay
RIP 67ChevyRedneck
RIP Grumpy Old Man
RIP FleetsidePaul
Old 04-21-2014, 10:41 PM   #44
TDH1989
Re: Hid headlights?
Which bulb in yalls opinion will give the brightest white look with the least amount of blue. Sylvania ZXE or Sylvania Silverstars? I have an Infiniti g35 with HID s in them and love them so I would like to get the brightest white without going to HID s in my 67.
Old 04-21-2014, 10:48 PM   #45
TDH1989
Re: Hid headlights?
And does it really matter what globe or housing you put the bulbs in as long as it's a 7 in. Unsealed housing?
Old 04-21-2014, 11:33 PM   #46
DreamRyder1963
Re: Hid headlights?
Zxe are brighter. They look blue when they are not turned on but they are pure white light.
Old 04-22-2014, 01:43 AM   #47
skorpioskorpio
Re: Hid headlights?
55/100s should be fine, use ceramic sockets and make sure you have good ventilation around the reflectors, oh and don't drive around with your high beams on all the time when you are doing stopped or doing 10 MPH, you should be fine. Hellas are very good reflectors, a better beam than any sealed beam. There are a handfull better (and a lot more expensive) and dozens and dozens worse.
Old 04-22-2014, 01:47 AM   #48
skorpioskorpio
Re: Hid headlights?
The purpose of a headlight is to project light in a usefull way in front of you, so yes the reflector is important otherwise you are strapping two lamps with 60 watt bulbs to the front of your truck.
Old 04-22-2014, 01:57 AM   #49
skorpioskorpio
Re: Hid headlights?
The lighting that will be going on the front of my Jimmy project, all NOS Marchal:
...and a mock up rendering of what it should look like:
Name:  JimmyGT Concept Nose.jpg
(Sorry MixerMike, I needed a dead on donor photo with a slant nose and a roll pan)
All on, it should project a precisely focused beam a mile and a half, no HID or LED lighting will that.
Old 04-22-2014, 03:17 AM   #50
BigMike
BigMike's Avatar
Re: Hid headlights?
Relay upgrade and Sylvania Silverstars. Done. If you still can't see with this combo you should not be driving at night.
That's what I am running. Hella H4 housings with Silverstars and it's bright as hella!
BigMike is offline   Reply With Quote
