Old 04-10-2014, 04:33 PM   #26
aerotruk63
Check The Champ, Demonstrator
aerotruk63's Avatar
Re: motor mounts & perches for 348 in a 63 c10-
I don't remember, but it must have been.
Old 04-10-2014, 06:12 PM   #27
1Bad62Pro/Street
"Where were you in '62?"
1Bad62Pro/Street's Avatar
Thumbs up Re: motor mounts & perches for 348 in a 63 c10-
Tee hee..
http://www.348-409.com/general.html
http://www.superchevy.com/features/p...409_w_engines/
PROJECT: "FULL METAL YELLOW JACKET"
1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck
PROJECT: "FULL METAL YELLOW JACKET Build Thread
What Are You Workin' On? - 1Bad62ChevyPickup
PROJECT: "TYRANNORAMBLER REX"
1969 AMC Rambler American Nostalgia Pro/Street
Youtube Channel: Father Son Projects
Youtube Channel: 2TIMOTHY2FITHTEEN
"North and South Carolina Folks Click Here!"
(((( ~ I have Parts For Sale & Miscellaneous Stuff ~ ))))
"Well being as there's no other place around the place,
I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D.
1Bad62Pro/Street is offline   Reply With Quote
Old 04-10-2014, 06:44 PM   #28
1963c-10
1963c-10's Avatar
I rember that episode....love it...run of the mill truck engine. hahaha.... don't think 325-350 hp will be any issue. Only problem is that a 427 gen IV is going in the stepside...might have to make the 325-350hp goal more like 350-375hp. Be interesting to see how it'll run against the 427. One will be auto and one manual, both same rear ends and tires.
1963 Short bed step side SBW 427 big block and borg warner T-16 HD 3 speed manual
http://67-72chevytrucks.com/vboard/s...d.php?t=519869
1963 Short bed fleetside BBW 348 1st gen big block w/Powerglide
http://67-72chevytrucks.com/vboard/s...d.php?t=619024
1964 Short bed trailer
1963c-10 is offline   Reply With Quote
Old 04-11-2014, 08:56 AM   #29
1963c-10
1963c-10's Avatar
Anyone any help on the engine mount bolt sizes? I think the engine/mount bolts are 3/8" x 1" coarse and the perch/frame bolts are 7/16" x 1 1/4" coarse. What about the mount to perch center bolt?
Old 04-11-2014, 09:19 AM   #30
1963c-10
1963c-10's Avatar
I think they are 7/16" also....maybe 1" or 1 1/4" length coarse?
Old 04-11-2014, 09:36 AM   #31
1963c-10
1963c-10's Avatar
And one more question for the pros....I have a manual trans driveshaft....can the front yoke be swapped for the powerglide trans....and will it need to be shortened? Looks to me that auto trans will be longer than the manual....I don't pick up the engine/trans until tomorrow, so no way to measure the overall length.
Old 04-11-2014, 12:01 PM   #32
61K10
61K10's Avatar
Is the trans a 58 also? I would find a 62 up alum one insted of the cast iron 58
1961 chevy K10
my build is------------61K10 build
61K10 is offline   Reply With Quote
Old 04-11-2014, 01:01 PM   #33
1963c-10
1963c-10's Avatar
Hmmm....won't know until tomorrow. Man says it was all pulled from the same car, but won't know for sure until tomorrow.
Old 04-11-2014, 01:21 PM   #34
1963c-10
1963c-10's Avatar
Heres a pic of what I'm picking up. He has the alternator mounts also....
And a few pics of the 63 auto column I picked up
Old 04-11-2014, 11:55 PM   #35
Captainfab
60-66 Nut
I've always used 3/8-16 x 1" or 1.25" bolts for the brackets (Perches) to the frame and crossmember. The bolt from the bracket (perch) to the engine mount is 7/16-14 x ~1.25". There is supposed to be a heavy large washer between the head and the bracket.
Old 04-12-2014, 07:05 PM   #36
1963c-10
1963c-10's Avatar
Thanks. I got the engine picked up today and will get some pics up on the build tread.
Old 04-12-2014, 07:39 PM   #37
1963c-10
1963c-10's Avatar
A few pics for here too. And super clean under the covers so far. I put all the casting #'s and date codes, specs up on the build thread for the fleetside if anyone wants to see them.
