#26 |
![]() Join Date: Apr 2005
Re: Ball joint and spindle spreading much easier
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#27 |
Nice tool, most of my work is now front or all wheel drive now and that won't won't work. If using a hammer on the spindle I find holding a second hammer against the backside very help full. It focuses the impact instead of bouncing the bushings.
#28 | |
#29 |
Nothing wrong with the bang the crap out of it method. It has been used for years. However, right now. Im heading to get my parts for my very own ball joint/spindle press lol. Great share man!
1965 C10 Project |
#30 |
Im back.... and looky what I have to add to my tools.
1965 C10 Project |
#31 |
Never Ending Projects
Put your washers between the nut and the center pipe piece. This way when you tighten the nuts, you don't gouge into the end of the pipe.
. 1965 C10 Panel, ![]() 1968 Chevy C10, Long, Fleetside, Hot Rod Hauler http://67-72chevytrucks.com/vboard/s...d.php?t=313233 SOLD 1965 Chevy C10, Long, Fleetside, Hot Rod C10 http://67-72chevytrucks.com/vboard/s...d.php?t=415702 SOLD We were given two ears and one mouth for a reason... listen twice as much and speak half as often... |
#32 |
Roger that.
1965 C10 Project |
#33 |
Sort of a Rube Goldberg way to do it but whatever works I guess. If you need more force/easier turning you could use fine thread bolts and a dab of grease on the threads and under the washer.
Daily Driver '66 C10 Fleetside Short Bed - LS swap - 4L80E - Accuair eLevel |
#34 |
I used a small bottle jack to get mine off the burb, but I like this idea too. Great write up and pictures BTW! Threads like this are what make this forum so great.
"It ain't as easy as Chip Foose makes it look" |
#35 |
![]() Join Date: Apr 2013
this is some damn good info...will use this idea soon..
1966 C10 "Mary" 1972 C10 Cheyenne "Betty" https://67-72chevytrucks.com/vboard/...d.php?t=847364 1976 C35 Sierra Grande "Mr. Harvey" 1979 C10 Silverado "The BIG TEN" https://67-72chevytrucks.com/vboard/...d.php?t=841339 1982 C10 Silverado "Lucy" C10 Club Texas -HMIC |
#36 |
I was just getting ready to same the same thing but you "treed me".
Great write up and I really appreciate the info. Every time you find something like this I feel I add another little tool to my tool kit of knowledge. ![]()
"Life is too short to drive a boring vehicle". Later, Wayne ![]() |
#37 |
Just used this method to remove my old spindles, worked great!! Thanks!!
#38 |
...while we were replying,, again after several months, I noticed those pretty Craftsman wrenches--you just gotta love them! Would you believe I have several(several meaning 2 or more)combination "CRAFTSMAN" wrenches stamped "Made In Japan"? Surely surprised me!
![]() Sam |
#39 |
Thanks for the instructions, great write up. Used it today and worked great!
#40 |
Used a slightly modified version of this technique this past weekend on the passenger side, and it worked much better than all the pounding it took to free the driver side spindle.
The second bolt is hidden in the socket and pipe; it's keeping them aligned. I removed the upper cotter pin so the socket could fit over the castle nut. Otherwise, the upper tool bolt would start to spin off the upper nut when tightening the lower nut. That second one is for for the overly cautious, first-time spring removing task. I lowered the jack from behind that tire.
1964 C10 LWB->SWB, 283->454, SM420->200-4R MECHANIC: "ME" |
#41 |
I just used a 1/2 in drive deepwell impact socket and a 2" long 1/2" bolt
#42 |
But Found Her 25yrs Later!
![]() Join Date: Oct 2010
Going to use this method in a few months..
I've become a fair weather hobbyist.
I lost my 65 - Found it 25 years later: http://67-72chevytrucks.com/vboard/s...d.php?t=426650 66 C20 Service Truck: http://67-72chevytrucks.com/vboard/s...d.php?t=428035 |
#43 |
Thanks great pics.Although im asking reassemble procedure
#44 |
Sorry everybody I'm kind of still new to using these forums. Am I supposed to click on some of them things that are highlighted in blue to find out my answers
