Old 04-13-2014, 12:06 AM   #26
whitedog76
Re: what would it take to get 100mph
I'm a straight axle guy, but you're not going to catch me going 100MPH, unless it's in a straight line.
Brakes and suspension are the AD trucks downfall. They were meant for hauling hay on a dirt road at 35MPH.
An upgrade to discs is almost mandatory.
If you stick with front leafs, do yourself a favor and do the C10 power steering upgrade. The biggest reason is because your oem steering column and gear box are bolted to your frame. A wreck at 100MPH and the stock steering column/steering wheel will spear you. They'll be sucking up your gray matter with a shop vac to give to your mom.
For power I recommend this.
Stock horsepower from 260-290. With a tune and uncorked exhaust, expect well over 300.
You can buy a running engine with harness from a salvage yard for $1000.
Vortec 4200 baby!!
whitedog76 is offline   Reply With Quote
Old 04-13-2014, 03:02 AM   #27
OrrieG
OrrieG's Avatar
Originally Posted by MARTINSR View Post
But let's also say that you of course shouldn't be driving 100 mph anywhere but a drag strip. And YES if you plan on doing anything like that on the road you should be thinking about suspension and brake upgrades. If THAT is what you expectations are, you should be upgrading it.
Brian
There are legal high speed venues in the US, Silver State Classic, Big Bend Open Road Race, and Sun Valley Road Rally in Idaho. They do tech the cars to make sure that the suspension, brakes, etc. are up to the task. I am toying with the idea of setting my 64 Chevelle up for Sun Valley to add some variety to the Euro iron. Minimum upgrades will be modern front suspension parts with disc brakes, engine up to the task, OD manual trans and disc quick change rearend. Probably fuel cell and roll cage "just in case".
OrrieG is offline   Reply With Quote
Old 04-13-2014, 10:44 AM   #28
MARTINSR
MARTINSR's Avatar
It's no different than seat belts, "just in case".
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
Old 04-13-2014, 12:56 PM   #29
_Ogre
_Ogre's Avatar
That is SOOOOO cool to be able to drive on Indy, even at 10 mph, that is sooooo cool!
Brian
it was cool to ride the track a lap
we spent the day on the infield on the 12 hot rod power tour
what amazed me was how flat the turns were
i've been to charlotte speedway with the high banked turns that you can barely walk up
also quite impressed with the crash barriers that surround the track
we didn't try them out
shop air compressor timer
Old 04-13-2014, 01:10 PM   #30
MARTINSR
MARTINSR's Avatar
DAAAAAAAMN that's cool! I love the shot next to the wall.
Brian
1948 Chevy pickup
