04-18-2014, 10:09 PM | #26 |
Re: 292 Engine specs
So I actually figured out something...I think(Its dangerous when I do ;-)...Anyhow! 10:0:1 compression is 240 pounds I believe..so..7:6:1 or 8:0:1 would be at least 150-170 pounds of compression right? If so...MAN!!! My 292, which is down to 95 pounds mind you, only has like...5:0:1 or even less.
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643 1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056 My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw |
04-19-2014, 11:19 AM | #27 |
Yikes that sounds like trouble, well at least you have a spare engine in your parts truck.
04-19-2014, 12:03 PM | #28 |
You have a longer duration hot-rod cam in there, don't you TJ? That lowers the dynamic (or "cranking" or whatever) compression, because the intake valves are still open longer while the piston is coming back up. As a result, you effectively shorten the available stroke/cylinder volume you are compressing.
The gauge itself may also be reading a little low, and you do have some loss from advertised even in stock form from the pistons being down in the bores from spec (and from valve timing to some extent). Here's an example of a dynamic comp. calculator: http://www.wallaceracing.com/dynamic-cr.php |
04-19-2014, 01:53 PM | #29 | |
04-19-2014, 02:04 PM | #30 |
It appears the compression is down to about 5:7:1- 6:0:1..somewhere in there is 95 pounds. The 292 in my 64 shows 120 pounds in all cylinders..and it runs perfectly fine..as does my 66's. Both are stock internally...course...someone may have done something to the 292 in my 66 later on before I got a hold of it. Maybe new pistons or something that ended up lowering the compression..maybe I have a blown head gasket...not sure. On the calculator I used the correct 3.875 bore and 4.120 stroke..connecting rod length of 6.700 and what the heck is "Static compression"? Anyhow..I put that as the stock 8:0:1 ratio and it came out as 184 pounds(If I'm remembering correctly). Well...getting to be time for a rebuild! LOL!
04-19-2014, 09:08 PM | #31 |
You may want to try dumping a small amount of oil down each cylinder are retesting the compression. This will help you determine if it is head or block issue causing low compression.
04-19-2014, 09:12 PM | #32 |
Thanks..yeah I'll have to figure out something. lol
04-19-2014, 09:21 PM | #33 |
Good luck hope it's nothing seriously wrong with it. My back up motor is a 327 although it is worst off than the 292
04-19-2014, 09:29 PM | #34 |
Huh--interesting then. BTW, "static compression" is just that; the volume of the bore/stroke divided by the volume of the combustion chamber, etc.
04-19-2014, 09:37 PM | #35 |
By the way you make these 292 engines sound, I don't think I will even need to keep the 327 around as a spare. The 327 is actually a marine engine that I was thinking about converting over to road use, but now I may as well leave it alone.
04-20-2014, 08:50 PM | #36 |
"Where were you in '62?"
Chevy Six Cylinder Casting Numbers
http://67-72chevytrucks.com/vboard/s...d.php?t=356268 Langdon's Stovebolt Engine Co. - Specializing in GM 6 Cylinder Engines http://www.stoveboltengineco.com/ Hot Sixes - Chevy inline 6 http://www.hotsixes.com/chevy-inline-6/ Inliners International http://www.inliners.org/ http://www.inliners.org/casting/numbers.html http://www.inliners.org/tech/info.html Clifford Performance :: Make 6 = 8 www.cliffordperformance.net/ http://www.cliffordperformance.net/M...gory_Code=C250 CHEVY 292 ENGINE 63-66 COMP ENGINE http://www.powertrainproducts.net/CH...Fc1j7Aodt10AeA Chevrolet Inline 6 Cylinder Power Manual 194 215 230 250 292 Engines 2nd Edition http://www.faxonautoliterature.com/C...on-P24594.aspx
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. Last edited by 1Bad62Pro/Street; 04-20-2014 at 08:57 PM. |
04-20-2014, 08:54 PM | #37 |
Just attempted removing 49 years of grease of of the 292 engine and 3 speed transmission today. I used an engine degreaser made by spray nine and then powerwashed it all off, I did this multiple times and there is still grease on the block. Anyone have any ideas of how to get this stuff off in one try.
04-20-2014, 08:59 PM | #38 | |
PROJECT: "FULL METAL YELLOW JACKET" 1962 Chevy C-10 Stepside Shortbed Nostalgia Pro/Street Pickup Truck PROJECT: "FULL METAL YELLOW JACKET Build Thread What Are You Workin' On? - 1Bad62ChevyPickup PROJECT: "TYRANNORAMBLER REX" 1969 AMC Rambler American Nostalgia Pro/Street Youtube Channel: Father Son Projects Youtube Channel: 2TIMOTHY2FITHTEEN "North and South Carolina Folks Click Here!" (((( ~ I have Parts For Sale & Miscellaneous Stuff ~ )))) "Well being as there's no other place around the place, I reckon this must be the place, I reckon...Nyuk Nyuk Nyuk" -Curly Howard Ph.D. |
04-20-2014, 09:04 PM | #39 |
I was thinking varsol, but gasoline would work too I guess.
04-20-2014, 09:10 PM | #40 |
Kerosene is good as well bud.
05-05-2014, 09:44 PM | #41 |
I think I may be missing a piece of my bell housing between my 3 speed tranny and the 292 on the bottom by the oil pan, the rest of the engine seems weathered except there. There are bolts holes and the steel is still shiny. Anyone have a picture of this area so I can compare it to mine?
05-05-2014, 10:05 PM | #42 |
Sounds like you are missing the dust cover for the clutch; I'd guess probably something like 5% of these trucks today have that piece still attached.
I wouldn't (and don't) think twice about the lack of that cover, personally. Others may chime in, but it seems to more or less have been a solution to a problem that doesn't exist IME/IMO. |
05-05-2014, 10:09 PM | #43 |
I thought I was missing a part, I'll look for one and if I find one I'll bolt it on
05-06-2014, 05:33 PM | #44 |
How we drive my 292. Not bad for being 48 years old huh?
https://www.youtube.com/watch?v=YoiM0nIA_7c
05-06-2014, 09:16 PM | #45 |
Sounds good TJ. Are those his and her ratchets on the dash?
05-06-2014, 09:23 PM | #46 |
Sweet truck, sounds good
05-07-2014, 01:10 AM | #47 |
I just read the whole thread so far and I saw you guys getting exited about a 292 with 105k on it and I just picked mine up with 28k on it I'm pretty exited
05-07-2014, 11:17 AM | #48 |
Nope..those are mine...Dad was driving and I was recording. I forgot what I was using them for at the time. lol The smaller one was used to hook up the battery cable..and the bigger one I don't remember anymore. lol
Thanks! Mince has 140k. lol Yours isn't even broke in yet!
