Old 04-17-2014, 09:58 PM   #26
jammer3096
Re: steering wheel wont rotate back to center on its own
is it possible that maybe the 3 inch drop spindles are on the wrong side
jammer3096 is offline   Reply With Quote
Old 04-17-2014, 10:03 PM   #27
BMERDOC
BMERDOC's Avatar
You can't mix up the spindles. Would you describe it as binding or just doesn't return to center without some help?
Nick Carter
1967 C10 Short bed Fleetside
Project Cheap Thrills!
2WD C10 Modern/Performance Alignments
Easiest Alignment Ever!
BMERDOC is offline   Reply With Quote
Old 04-17-2014, 11:09 PM   #28
jammer3096
I came to the conclusion the left spindle is defective. Summit racing is sending me a new set and warrantying them. Ill let everyone know if it was the problem. Thanks for everyone's help.
Old 04-18-2014, 06:27 AM   #29
PGSigns
PGSigns's Avatar
So what was wrong with the spindle?
Jimmy
60 to 66 Chevy and GMC window decals
http://67-72chevytrucks.com/vboard/s...d.php?t=661131
Good friends, good food and a hotrod what else do you need?
1966 BBW long fleet Daily driver
1965 BBW short fleet Sold and going to a good home
1965 Suburban
2003 3500 Duramax
2005 Ultra Classic
PGSigns is offline   Reply With Quote
Old 04-18-2014, 08:47 AM   #30
GEARBOXGARAGE
Just a thought, are you sure the ball joints are correct? I've purchased ball joints before, same part number, different ball joint when I opened the packaging.
GEARBOXGARAGE is offline   Reply With Quote
