Old 04-18-2014, 12:34 AM   #26
First c10
First c10's Avatar
Re: New LS swap/install questions
Page 5
1956 Chevy Bel Air 2 door
1956 Chevy 210 4 Door
1970 K20 LWB project the Hulk build w/Supercharged 4.8L-ly2/4L60E HULK BUILD
1970 C10 Yellow/White Deluxe LWB w/ 5.3L-LC9/6L80E
1968 K10 LWB Dark green my son calls it "THE HULK Jr"HULK JR *SOLD*
GO GO!!!
First c10 is offline   Reply With Quote
Old 04-18-2014, 12:35 AM   #27
First c10
First c10's Avatar
Page 6
GO GO!!!
Old 04-18-2014, 12:37 AM   #28
First c10
First c10's Avatar
Page 7 and last one
GO GO!!!
Old 04-18-2014, 01:12 AM   #29
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
You shouldn't have a bank 3 and bank 4, that means your rear 02's are still on.
The LTFT is pretty high at 30, are you sure there aren't any glaring mechanical leaks in the exhaust or vacuum system. No burned wires on the header etc?
Need to figure out if the lean condition is in the tune, caused by a mechanical leak, or a problem like an injector.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 04-18-2014, 02:21 AM   #30
First c10
First c10's Avatar
Br3w
I didn't see any exhaust leaks. No burning wires the only vacuum leak I had was the heater control valve line that I had not hooked up so I put a plug in it after I seen the codes. What tells you the rear o2 sensors are on? Also. When I re worked the harness it only had 3 o2's Not 4. What do I look at next?
GO GO!!!
Old 04-18-2014, 11:53 AM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Originally Posted by First c10 View Post
Br3w
It should only have 2.
I see "bank 3" and "bank4" . Bank 1 and 2 are FRONT driver and passenger, 3 and 4 correspond to the rear set (post-cat) 02 sensors. If they are still enabled in the tune, then the truck will make some attempt to use the information they provide. Your getting lean codes, but the part that surprises me is that your NOT getting catalyst efficiency codes (which you would with the rear 02). Its hard to tell exactly whats happening there, but for the life of me I don't know why you would have 3 02 sensors on the harness.
I see that your in Cali; is this an emission-legal swap, with cats and such? I just noticed the CATTEMP readings.
With any lead code, its never a bad idea to check; fuel pressure,dirty MAF, leaks on injector, fuel pump voltage. Some of those items are related obviously, but many are easy checks.
Old 04-18-2014, 12:16 PM   #32
First c10
First c10's Avatar
Is bank 3 and 4 O2B2S1 and O2B2S2?
no emissions they should all be removed. I think I have connected a vacuum line to the valve cover vent so that maybe it. You think?
Why would I have a cat temp reading? I dont have a cat.... I am guessing they should be turned off???
vehicle package came from ohio
GO GO!!!
Old 04-18-2014, 01:05 PM   #33
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
02 bank 2 sensor 1 and bank 2 sensor 2. That Bank2Sensor2 is what I keep calling "4" sorry to confuse you. Its the 4th sensor. The "sensor 2" is the rear set of sensors, which should be off.
BUT
CATEMP is a catalyst temp monitor as far as I know, so why you have a reading there is beyond me. And it still doesn't explain why you had 3 o2 sensors on your harness.
I feel like I'm missing the big picture here.
Old 04-18-2014, 01:10 PM   #34
First c10
First c10's Avatar
ok so my 08 gmc 3500 has a duramax but when i replaced the cat back system i seen 1 sensor on each bank and another single after the Particulate filter. so thought that maybe the gas rigs were close since the factory exhaust on a gas rig is 2 into 1...
do i need to send my ecm back ls1swap and have him turn that stuff off?
GO GO!!!
Old 04-18-2014, 05:17 PM   #35
First c10
First c10's Avatar
I have a question since both banks show ltft's at 29.7 could the o2 sensors be incorrect?
GO GO!!!
Old 04-18-2014, 05:49 PM   #36
First c10
First c10's Avatar
This is pretty good info!
GO GO!!!
Old 04-18-2014, 06:13 PM   #37
First c10
First c10's Avatar
ok so I have another question on my scan tool it gives me the info of
"scan tool reads"
O2B1S1(v) = O2 bank 1 sensor 1 volts .060 volts
O2B2S1(v) = O2 bank 2 sensor 1 volts .835 volts
O2B2S2(v) = O2 bank 2 sensor 2 volts .450 volts
How can this be? if I dont have a "O2 bank 2 sensor 2" ????
this maybe the issue with the lean problem since everything works off the O2....
GO GO!!!
Old 04-18-2014, 09:43 PM   #38
First c10
First c10's Avatar
Ok so I disconnected the MAF and the StFT dropped to between -3.1 to +.8 at idle? What does that mean? Bad MAF sensor? But MAF code popped up.
GO GO!!!
Old 04-18-2014, 10:01 PM   #39
dayj1
"scan tool reads"
The Bank 2 sensor 2 is showing .450 which is the value for stoich combustion. I've seen that before even with the rear sensors tuned out. In other words the "tuned out" sensors are read by the scanner as stoich.
What stands out to me is that Bank 1 is extremely lean and Bank 2 is rich. Make sure that you don't have your O2 sensors connectors in your harness swapped from side to side because that's the exact symptom you'd have. It happens to people more than you'd think.
dayj1 is offline   Reply With Quote
Old 04-18-2014, 10:09 PM   #40
First c10
First c10's Avatar
If you look at the 4 wires going to the o2 sensor connector, the wires for
the DRIVERS side, BANK 1, will have a white stripe on the PURPLE wire. The
wiring going to the PASSANGER side, BANK 2, will be solid purple, without a
stripe. Is this correct? I will double check I have it this way. Yes I do have it this way !!!
GO GO!!!
Old 04-18-2014, 10:20 PM   #41
First c10
First c10's Avatar
This is with no MAF connected. Idle is smooth about 600
GO GO!!!
Old 04-18-2014, 10:21 PM   #42
First c10
First c10's Avatar
Looks better?
GO GO!!!
Old 04-18-2014, 10:23 PM   #43
First c10
First c10's Avatar
O2 sensor data
GO GO!!!
Old 04-19-2014, 12:40 AM   #44
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
I don't know much about the oil-burners, but on any obdII car with a 2-bank engine (so v-anything), you'll have a minimum of 4 oxygen sensors. 2 upstream and 2 downstream. The rear 02's main job is to monitor catalyst function/heat/efficiency...hence why we tune them out. If they are still wired in or left "on" in the tune, there is an issue. When under cold start, or at WOT these sensors are ingored.
Old 04-19-2014, 12:44 AM   #45
First c10
First c10's Avatar
Makes sense. I read somewhere on here about someone disconnecting the MAF. When I did the numbers came back inline and the idle mellowed. Bad MAF?
GO GO!!!
Old 04-19-2014, 12:07 PM   #46
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
unplugging the MAF forces it just to use the tables. That usually boils down to bad maf, bad maf wiring, vacuum leak, or something wacky in the tune.
Have you tried driving it at all with the maf unplugged? It should drive, it just may set MAF codes and the trans may feel sticky/harsh. You can clean the maf, reset the ecm (pull battery) and let it cold start idle again. It may re-learn the maf if it was dirty. If its physically broken (element broke etc), this wont' help. I'd pickup one from the parts store, troubleshoot the above issues, then try swapping it out.
Old 04-19-2014, 03:17 PM   #47
First c10
First c10's Avatar
Hey br3w
I checked the power at the MAF it is correct not sure about signal wires but the only thing I did was power and ground. I drove the truck and yes runs fine but did throw MAF code and temp code. The MAF was a brand new one but I guess I could get another. I have been all over the manifold trying to find a leak. Even plugging everything coming out of the manifold.
Thanks for all your help.
GO GO!!!
Old 04-19-2014, 03:19 PM   #48
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
Which temp code, the one for the IAT?
I tried to look at your picture and see where the maf was mounted but it was too hard to tell.
How far from the TB is the MAF, is it on a straight section of pipe, and how is it oriented (which way does it face, and what clocking does it sit at)?
Old 04-19-2014, 09:05 PM   #49
dayj1
First C10,
Back in post 21, you said you got P0171 and P0172 codes and went on to say that those are for lean AFR on banks 1 and 2. If that's not a typo on the codes, that's incorrect. P0171 is lean bank 1, but P0172 is actually rich on bank 1. So you're getting rich and lean codes on the same bank.
Old 04-19-2014, 10:01 PM   #50
First c10
First c10's Avatar
Originally Posted by dayj1 View Post
First C10,
Both lean codes sorry. P0174 I think it was.
To many numbers!!!!
I will post a picture of where my MAF is located.
GO GO!!!
