Old 06-09-2014, 10:30 AM   #26
markeb01
Senior Enthusiast
markeb01's Avatar
Re: Fools Gold. my new 66 c10
Nice truck and great progress. Welcome!
My Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=444502
Old 06-15-2014, 12:33 AM   #27
Bigd426
Got some more stuff banged out on the truck today. Finished up the rear brakes, got the front brakes done, got new lines ran, mounted new wheels on the rear, final fitment of the steering column mount done. Hoping tomorrow to pull the column back out and paint it. Progress is progress though
Bigd426 is offline   Reply With Quote
Old 06-15-2014, 08:28 AM   #28
bj383ss
bj383ss's Avatar
Great progess! I notice you are running an electric fan. Are you using the stock radiator and what fan did you use? I'm researching this for mine right now. But I don't want to pay astronomical price for the electric fan and would like to keep the stock radiator.
Bret
64' Build Thread http://67-72chevytrucks.com/vboard/s...d.php?t=586955
bj383ss is offline   Reply With Quote
Old 06-15-2014, 02:25 PM   #29
Bigd426
I think its a hayden, got it from summit. Just measured the biggest on that would fit with the most cfm. Ill double check when i get home though
Old 06-15-2014, 06:06 PM   #30
C@rnut001
Your truck is looking great. Keep up the great job and keep sending us the updates as you work on it. Your engine looks great too.
C@rnut001 is offline   Reply With Quote
Old 06-15-2014, 11:15 PM   #31
Bigd426
Bret
I lied its a proform 16in fan, i dont know how its going to do without a shroud though.
Old 06-15-2014, 11:16 PM   #32
Bigd426
Thanks everyone for the compliments. This has been one the better forums ive been on. Lot of great people, info, and trucks.
Old 06-18-2014, 12:11 PM   #33
SCOTI
SCOTI's Avatar
The caps pop nicely against the black wheels. Looks good....
67SWB-B.B.RetroRod
64SWB-Recycle
89CCDually-Driver/Tow Truck
99CCSWB Driver
All Fleetsides
@rattlecankustoms in IG
Old 06-29-2014, 05:13 PM   #34
Bigd426
Get a bit of time to work on the truck this weekend. Brakes are all done, new brake hoses and lines. Bled them and no leaks now! Finally.... Hooked the power steering back up with new hoses as well. Got the front wheels painted and on. Now its back on the ground. Waiting on my shifter to come back from the machine shop to install it and it should be ready to make it around the block, fingers crossed
Old 06-29-2014, 05:54 PM   #35
C@rnut001
Looking great, keep up the hard work on your truck. Thanks for updating us.
Old 06-29-2014, 06:13 PM   #36
Nice job so far. Liking it a lot!
Old 08-23-2014, 06:24 PM   #37
Bigd426
Been awhile since I have had a chance to work on it but finally got out today and got some stuff done. I have been working on a shifter idea since I have had the truck. The trans is a full manual reversed valve body. Which is cool but I didnt like any truck shifters and the lokars only have detents no gates in their shifter. So ended up using a old B&m quick silver and a hurst 4spd shifter handle. The final product is a ratcheting shifter that fits a truck and looks the part I think. Also got the rear end fluid changed, finished the battery relocate and rebuilt the carb. Its been baby steps but they are still steps
Old 08-23-2014, 08:07 PM   #38
Nice job on the shifter bigd.... I had to look twice at it. If I ever go to an automatic, I may borrow (steal ) your idea.
Old 09-06-2014, 03:32 PM   #39
Bigd426
Got a new windshield put in this morning!
Need a gas tank now, but not sure what I want.
Old 10-14-2014, 03:21 PM   #40
Bigd426
Ordered my gas tank, sending unit, filler neck, and new fuel pump
I think my pick up tube was the cause for not getting gas to the carb. New fuel pump just for good measure, lot of trash was in the filter. Im hoping that this weekend to get it in and drive it around the block. Wish me luck and the next up date it is moving under its own power.
Old 10-14-2014, 06:22 PM   #41
NEWFISHER
NEWFISHER's Avatar
We need burn out pics too
GOD BLESS AMERICA!
NEWFISHER is offline   Reply With Quote
Old 10-14-2014, 10:58 PM   #42
Bigd426
Thats the plan. I have three goal for this truck. 1 look good. 2 sound good. 3 do donuts. Its really a simple plan
Old 10-15-2014, 10:26 PM   #43
ChrisDollins
ChrisDollins's Avatar
That's my kind of plan! Truck looks good. I like the black wheels with the hubcaps. Has a cool look to it.
Chris
ChrisDollins is offline   Reply With Quote
Old 10-15-2014, 11:07 PM   #44
TJ's Chevy
TJ's Chevy's Avatar
Very nice!!!!
1966 Chevy C10 "Project Two Tone" http://67-72chevytrucks.com/vboard/s...d.php?t=596643
1964 GMC "Crustine" semi-build:http://67-72chevytrucks.com/vboard/s...d.php?t=665056
My youtube channel. Username "Military Chevy": https://www.youtube.com/channel/UC_h...fzpcUXyK_5-uiw
TJ's Chevy is offline   Reply With Quote
Old 10-19-2014, 10:17 PM   #45
Bigd426
Well I got the new gas tank, sender, filler neck and fuel pump installed yesterday. Took a bit of coaxing but it finally started and ran. I think my carb has a bad plunger so it wont squirt fuel right away, ive already rebuilt it so im thinking just to buyba new one and be done with it. Anyways, today I went checked everything, fluids, wheels were tight, brakes still working, ect... Started it up and drove it out of the driveway! First time its moved under its own power in close to 25 years! So I figured what the hell and drove it down the street. Runs great, trans operated flawless, drum brakes sucked! But got down to the end of the road ( 3/4 miles ish) turned and bleh... It died... I didnt bring my carb cleaner to pop it back off. So I pumped and pumped and it finally squirted so I jumped back in fired right back up. Eased back up the road closer to the house, stopped and did a burn out. Roaded threw 2nd gear like champ, pulled back in the driveway and realized i didnt film it or take pictures or anything. Still the best update yet! New carb, disc brakes, suspension are next on the list. Oh and tires, any ideas on skinny whitewalls? 235/70r 15 and 275/60 r15?
Old 12-15-2014, 05:59 PM   #46
Bigd426
More baby steps..... After months of jacking with the old carb I had i bought a new one. Finally cut the spark plug wires and put them on and set the timing. Runs like a top! Did some burns outs and drove it around the block a few times, it didnt miss a beat! I installed some rear lowering springs, waiting on the front for disc conversion and spindles. Hopefully right after the new year. Maybe by this summer it will be on the road. A year late lol
Have pics to will post up
Old 02-18-2015, 12:03 PM   #47
Bigd426
Finally back at it. Have disc brakes, spindles, springs, master cylinder, booster and while front end rebuild to go it. The back has been lowered also now time to do the front. Hope to get started on it this weekend.
Old 02-18-2015, 01:09 PM   #48
SCOTI
SCOTI's Avatar
Just in time for spring outings.....
67SWB-B.B.RetroRod
64SWB-Recycle
99CCSWB Driver
All Fleetsides
Old 02-18-2015, 02:55 PM   #49
Bigd426
That is the plan for sure. Need to get on it!
Old 04-29-2015, 11:23 PM   #50
zipper
Did you use a mcgaughys 13' disc brake kit? If so, issue with clearing your 15' wheels?
zipper is offline   Reply With Quote
