Old 05-08-2014, 07:55 PM   #26
96Indyram
96Indyram's Avatar
Re: You shouldn't have but it worked
Heard of a old guy off-roading in his truck, and busted a connecting rod while playing out in the middle of nowhere many miles from home...but has tools in his toolbox. so The dude dropped the oilpan, removed the broke rod and piston then noticed the rod broke the cylinder wall into the water jacket.
So after some thought he gets a idea. He cuts a treelimb around the same size as his cylinder dia. Wittles it down with his knife for a good fit, then he hammers the "wooden piston" plug up into the cylinder hole covering the crack in the wall. wood swells when it gets wet and will keep it from leaking was his thinking.
He puts the oilpan back on, and fills the radiator back up with what water he had. Starts it up. It ran like total crap but he drove it out and back home on 7 cylinders.
66 c10 Panel (Wife's)
http://67-72chevytrucks.com/vboard/s...d.php?t=595684
68 c10 LWB
96Indyram is offline   Reply With Quote
Old 05-08-2014, 07:57 PM   #27
BC10
BC10's Avatar
My dad tried to use old fuel that was in a gas tank he bought from a yard. He pumped it into his C20 after trying to convince me that I should put it into my tank. His truck froze and stopped running the next day...
BC10 is offline   Reply With Quote
Old 05-08-2014, 08:04 PM   #28
96Indyram
96Indyram's Avatar
The throttle cable broke off the back of the pedal on my 72 superbeetle.
I yanked some speaker wire going to the rear speakers from the radio.
tied the speakerwire to the cable end and had to pull on it to operate the throttle.
So shifter in right hand, steering wheel and "hand throttle" in left hand. Was kinda tricky to operate and steer and shift..but it got me home.
68 c10 LWB
Old 05-08-2014, 08:40 PM   #29
cleanfreak
cleanfreak's Avatar
Way to many to list.... I've been real lucky thru the years. Just one to start with.. Big block chevy ,3 different pistons , 2 different connecting rods , 2 different heads , 2 types of spark plugs , miss-matched rockers---you get the point. Engine went 10.30's in a 2800lb car for years , 1000+ passes. Couldn't kill that poor thing - Bob
cleanfreak is offline   Reply With Quote
Old 05-08-2014, 10:05 PM   #30
70jnktrk
70jnktrk's Avatar
Had a broken motor mount on a 62 Chev SS...to young to know about such things...motor would rise up and fan would hit fan shroud...yup...ripped out the shroud.....
70jnktrk is offline   Reply With Quote
Old 05-08-2014, 10:45 PM   #31
DUD2STUD
DUD2STUD's Avatar
Went camping with a bunch of buddies a few years ago. About midnight and after a few beers we decide to load up and go wheeling. An hour into it and about 3 miles up the Mountin my buddy puts a stick threw the side wall of his tire. Of course it's way to dark to walk back and almost done with all our beer I decide I'm going to fix the tire. All we had in the truck was a tube repair kit for a bike. Using the tactical light on my 9mm and 2 screw drivers I get the tire partly of the rim use my pocket knife to ruff up the tire and put said tube patch on. I used an egg to lube up the bead to get it back on and aired it up. We made back to camp wheeled the next day then drove 60 miles back to the house. We back in the driveway got out and boom tire blows. That's how I got the nickname McGiver.
DUD2STUD is offline   Reply With Quote
Old 05-08-2014, 11:37 PM   #32
Twiz
Not my story but someone I work with. Not sure if I beleive him but here gos.
He said he was replacing his intake manifold but didn't have a gasket. To late at night to go to a parts store and buy one. So he uses JB Weld to "create" a gasket and put the manifold on. Said it ran great with no leaks. And when he needed to take the manifold off the JB Weld just chipped off real easy because of the heat of the motor.
Twiz is offline   Reply With Quote
Old 05-09-2014, 04:35 AM   #33
franken
Originally Posted by Fatherof3 View Post
They had an arc welder, an oxy acetylene set with cutting torch, a bench grinder and a whole lot of bailing wire.
I resemble that remark... No stick welder (light MIG), but an O/A torch is sort of like nuclear weapons...
Once I was talked into being weight on the back of a reddish Mopar that was parked in a ditch in an NE Ohio winter. The car was at a 45 degee angle.
With me lying on the deck lid, zero hand/teethholds; just the friction of my frozen fingetips as he drove that car back and forth in the snowy ditch. After some speed he'd try to steer up and out.
Soon the sheriff deputies arrived to watch. We lived so far out they drove 1-ton Chevy trucks w/ ambulance bodies. They said they take use (me) to the hospital later.
After quite a while and a few hundred feet of road made in that ditch my friend did drive that car out, with me lying on the deck lid, and the police laughing.
Ah, the old days when everything wasn't illegal
That's just scratching the surface...
franken is offline   Reply With Quote
Old 05-09-2014, 06:14 AM   #34
darush01
Not sure where to start bc my dad raised me that if it don't fit make it fit, I know he used the wrong tranny in a 65 biscayne and only two bolt holes in the bell housing lined up with the motor but he drove it like that, and I lost the key to my dads old wrecker once so I ran a wire from the battery to the cab under the column then another to the coil so when I put them together I had ignition then since its a ford and the sylonoid is on the fender and easy to reach I jumped it off with a screw driver still set up that way lol
Also used 3 sets of jumper cables hooked together because I couldn't get close enough to my truck to jump it
darush01 is offline   Reply With Quote
Old 05-09-2014, 08:03 AM   #35
volksworld
jeff foxworthy referred to that as the long jump in the redneck olympics
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 05-09-2014, 10:12 AM   #36
SeniorVerde
SeniorVerde's Avatar
I lost/broke my jeep's throttle return spring on I405 just before rush hour.
I was able to shut it off and coast to the shoulder before the thing blew itself up at 7000 rpm, but I didn't have another throttle return spring...
This is the spring from between the handles of some cheap wire strippers and a section of coat hanger to reach the rest of the way. One end was held on with 2 very tiny plastic zip-ties. I made it to the parts store this way (bought two springs!) but I was very nervous about those plastic wire ties failing and starting the adventure all over.
SeniorVerde is offline   Reply With Quote
Old 05-09-2014, 10:22 AM   #37
chevy72blu
chevy72blu's Avatar
Converted my trucks alternator when I was in high school, but I didnt really understand how the "exciter" worked. Decided I could just rig it to a push button... Found this bad boy at the parts store for $5 and mounted it to the dash
Every time I started the truck I had to push in this button to get the alternator started. I always considered it an extra anti-theft device! Worked for years
RIP EastSideLowLife
'72 C20 SWB convert. 5 lug, LS1/4l60e
chevy72blu is offline   Reply With Quote
Old 05-09-2014, 10:52 AM   #38
Hawghauler
Hawghauler's Avatar
Back when I was a kid, I was haulin ass on back country roads to Monroe one night in my trusty old '68 chevelle. I was in a hurry to get to the track before the races started. Anyway, I hit this curve at about 55 MPH, Should have been 25-30 MPH corner. It was all good, then I punched it just as I hit the straight, I heard a "clang". I saw a flash of red at the bottom of my vision, and just as I was about to look down at the gauges, something went shooting by, just out of the corner of my eye. It made me look there instead, and I saw my harmonic balancer and pulleys rolling down the road about 10 MPH faster than me. I punched it to catch up, (the dash was all red lights), then slowed with it in sight until it stopped. I shut off the car, got out, retrieved the balancer and proceeded to scratch my head. I popped the hood, and saw my belts dangling from the alt. and waterpump. I had never messed with this balancer before, and didn't even think it would do something like this. I slid the balancer back onto the shaft, (For some reason the crank didn't have a bolt holding it on) and It would slide right back off without resistance. What to do? I dug a pop can out of the back seat, (It may have had some strategically placed holes) cut a strip of it off the side. wrapped it around the crank, then used a BFH I had in the trunk, and drove that b*tch back on. It lasted until I sold the car about five years later.
If I have to be on 4 wheels, It has to be a classic Chevy
1967 c10 Longbed (Hawghauler/Icy weather transport)
2003 BMW K1200GT (Rain bike)
2007 Softail Deuce (Sun bike)
2009 Ultra Classic Electra Glide (Everything else bike)
Hawghauler is offline   Reply With Quote
Old 05-09-2014, 11:34 AM   #39
AirSpeed
AirSpeed's Avatar
Originally Posted by Wizo View Post
say um air speed;are you sure it was a sig? just wondering
It was cigarette shaped!
AirSpeed is offline   Reply With Quote
Old 05-09-2014, 11:52 AM   #40
chopnchaneled
chopnchaneled's Avatar
Few years back I was on my way to work in my old S10 pickup and the clutch master cylinder went out in atlanta traffic causing a traffic jam, only thing i could come up with at the moment was pouring my coffee into the master cyl. Got me the way to work.
I don't think we get smarter as we get older. We just run out of Stupid things to do.
chopnchaneled is offline   Reply With Quote
Old 05-09-2014, 01:55 PM   #41
dmartin1
dmartin1's Avatar
my dad tells me all the time of breaking down in an old dodge ramcharger with a 318, and it snapped a pushrod a feww miles from the nearest tiny town, and used a bolt that hi and his buddys ground down at a small garage there and used it for a pushrod. to get it home.
or using a hollowed pen tube in place of his old clogged fuel filter.
or a cereal box for gaskets on a quad. lol
1969 Shortbed in progress
1982 short step, few suspension and motor upgrades.getting a 468
1978 Shortbed fleet side bonanza fully loaded
1978 k20 Silverado loaded.currently engine-less
1989 k10 suburban 9" lift
65 nova
And more
dmartin1 is offline   Reply With Quote
Old 05-11-2014, 05:02 PM   #42
Wizo
Wizo's Avatar
Roger that. got it
Wizo is offline   Reply With Quote
Old 05-11-2014, 05:35 PM   #43
leftybass209
leftybass209's Avatar
Swapped my cab with 2 chains and an engine hoist. One chain popped off just as the junk cab was a few inches from the dolly. The reverse was much more secure but used my weight in the cab while suspended to level the cab to clear the frame rails. Not safe and I'd never recommend it but functional none-the-less.
leftybass209 is offline   Reply With Quote
Old 05-11-2014, 10:39 PM   #44
derotoreut
Roto Reuter thats the name...
derotoreut's Avatar
When I was just a kid I fixed a pin hole gas tank leak with a sheet metal screw and roof coating.
First engine rebuild ever was a 289 to put in a Comet. Knew nothing about tearing an engine apart. Had no idea how to get pistons out. Never heard of a ridge reamer. Just pounded out the pistons out until the rings broke. It was all down hill from there. Believe it or not we got that engine rebuilt and running.
~ Dan
My 70 K10 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=782232
My 71 SWB build:http://67-72chevytrucks.com/vboard/s...d.php?t=651394
1970 SWB Fleet K10 4X4, 5.3L LM7, 4L60E, Dakota Digital RTX, Vintage Air, Ididit tilt
1971 SWB Fleet C10 - Original SWB Arizona truck, new custom restoration project
"Kick out your motor and drive while you're still alive - kick it out!" - Heart 1977
derotoreut is offline   Reply With Quote
Old 05-11-2014, 11:18 PM   #45
67_C-30
I have a radical idea!
67_C-30's Avatar
I pulled up huge, old holly bushes with my '67 C-50 wrecker once. I almost messed up and let the boom go through the living window! -lol
'67 C-30 Dually Pickup 6.2 Turbo Diesel, NP435
‘72 C-10 SWB , 350 4bbl, TH350
'69 C-10 SWB , 250 L6, 3 OTT
'69 GMC C3500, dump truck, 351 V6, NP435
'84 M1009 CUCV Military Blazer
67 C-30 Turbodiesel build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=254096
My trucks
http://s226.photobucket.com/albums/d...ediafilter=all
Member of the 1-Ton Club!
67_C-30 is offline   Reply With Quote
Old 05-11-2014, 11:23 PM   #46
desertnick69
desertnick69's Avatar
"I used toliet paper rolls as a jack stand..." Boeing has a coating you could put on them and they would work great
Maybe that's way I do not fly?
desertnick69 is offline   Reply With Quote
Old 05-12-2014, 10:35 AM   #47
Fatherof3
Fatherof3's Avatar
Living in the Seattle area you meet a lot of Boeing employees but come to think of it I have never met one on a flight
Just saying
65 C20 292 4spd 4:56 Eaton HO52
Fatherof3 is offline   Reply With Quote
Old 05-13-2014, 08:52 PM   #48
70STOVEBOLT
70STOVEBOLT's Avatar
Fuel pump failed just down the street from home on a 72 Catalna that I had in high school. I walked to the house and got a can of gas, walked back to the car, had my girlfriend drive it with the hood up whole I sat on the fender pouring gas into the carb. Got a fuel pump the next day.
70 C/10 SWB 402/TH400/3.73 "The Needy Beast"
200,000 Mile Club
Disc Brake Club
Owner installed options:
Front Sway Bar
Power Steering
Power Brakes
Cigar Lighter
Courtesy Lights
Deluxe Side Markers
Wiper Delay
Sliding Rear Window
Power Windows
Power Locks
Sniper EFI
2015 Silverado 1500 LS 4.3/6L80/3.23 lowered 2" front & rear
70STOVEBOLT is offline   Reply With Quote
Old 05-14-2014, 01:58 AM   #49
dajn
I have so much respect for that time. My grandpa and my dad could keep anything running. We have internet forums and youtube and google. They learned as they went. I faintly remember my grandpa blowing out a stump with sticks a dynamite. Now that i'm older it makes me wonder where he learned how to rig dynamite. I wish i could ask him
dajn is offline   Reply With Quote
Old 05-14-2014, 02:44 AM   #50
dajn
I'm not proud of this one but this is my story. After drinks at the bar, i ended up at a local party in my 1986 k-10 which i still own (poor thing). I had a liter of captain morgan in my hand. We took it out in field's and through the trees and gods what else happened that night.. When i woke up, i have never been so thirsty for water in my entire life. This it like 6:00 a..m. everyone else that stayed is still passed out. Go to start my pickup to head home and there's nothing. I managed to crawl out of the cab and lift the hood. My battery was laying next to the frame and it had melted off the positive cable. It wad a side post battery with top post. I had a clamp visegrip in the cab and clamped the cable to the top post and drove home with the hood part way. Still drunk. Don't drink and drive kids. I learned the hard way.
