Old 08-21-2014, 07:05 PM   #26
Chevy addict
Re: 1958 3200 Long Bed 5.3l/Jag IFS
I just picked up an xj12 sub for my 58.
Chevy addict is offline   Reply With Quote
Old 08-21-2014, 11:12 PM   #27
NoClassic
Stock wheelbase but we shortened the bed and frame after the rear fenders.
NoClassic is offline   Reply With Quote
Old 08-22-2014, 10:59 PM   #28
Chevy addict
How low will it be from stock height with the jag stuff mounted under the frame?
Old 08-23-2014, 12:01 AM   #29
NoClassic
It's hard for me to say. I did not measure the height with the beam axle and we have already removed a coil from the jag springs.
Old 10-20-2014, 01:09 AM   #30
NoClassic
We decided to go ahead and paint the interior. It was the first time I have done a larger scale paint project so it took longer than expected. It is not perfect, but I am happy for a first go at it. The color is subaru ice silver. I wanted something with a bit more black than the factory silver and I think it works. I also went ahead and used some black epoxy on the fender liners, and will be doing the same to the firewall once we figure out what holes need to be filled.
I finished the exhaust with 2.5" mandrel bends and 22" magnaflow mufflers. I wish it could be symmetrically spaced, but just does not make sense with the trans servo and driveshaft angle for the offset diff on the ford 8.8. I may add a crossover if there is alot of rasp once its running.
Old 10-20-2014, 08:30 AM   #31
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
http://67-72chevytrucks.com/vboard/s...d.php?t=283107
Kim57 is offline   Reply With Quote
Old 10-20-2014, 07:26 PM   #32
Mr.Jones
Originally Posted by NoClassic View Post
I painted the wheels this morning. I think the cap looks alright on them, maybe paint the bowtie white.
Outstanding job on the rims.
Mr.Jones is offline   Reply With Quote
Old 10-20-2014, 07:44 PM   #33
NoClassic
I helped my dad with the weather stripping on the doors this evening. He is going to install the seals, glass, lock/glass mechanisms this week. I need to get the transmission rebuilt so it and the motor can go back in one last time.
Old 10-31-2014, 05:28 PM   #34
NoClassic
The transmission came back from getting rebuilt so we began the final powertrain install. My dad also finished building out the doors. The cab should be going on next week some time so we can begin the wiring.
Old 10-31-2014, 07:27 PM   #35
RockinKees
RockinKees's Avatar
Good looking project!
Nice to see that there are more people uses Jag stuff!
Cheers!! Kees.
1959 Chevy Fleetside Longbed
My build: http://67-72chevytrucks.com/vboard/s...d.php?t=643426
Kool Guyz CC
Instagram: _King_Kustom_
RockinKees is offline   Reply With Quote
Old 10-31-2014, 07:27 PM   #36
RockinKees
RockinKees's Avatar
Cheers!! Kees.
Kool Guyz CC
Old 10-31-2014, 08:33 PM   #37
NoClassic
I welded in the O2 bungs and finished painting the exhaust this evening. It is now back on the chassis for the final time.
Old 10-31-2014, 08:51 PM   #38
Daze57
Daze57's Avatar
good lookin stuff !!!!
Daze57 is offline   Reply With Quote
Old 10-31-2014, 09:33 PM   #39
ChuckDriver
A320 Pilot/USAF Retired
ChuckDriver's Avatar
Wow, this is one nice build!
ChuckDriver is offline   Reply With Quote
Old 11-01-2014, 02:13 AM   #40
Kim57
Kim57's Avatar
Very nice.
Kim
My build thread
Old 11-01-2014, 07:07 AM   #41
Patina.au
Going along nicely. Thanks for sharing.
Patina.au is offline   Reply With Quote
Old 11-01-2014, 12:25 PM   #42
NoClassic
I decided to go ahead and fill some holes in the firewall before painting it and dropping the cab on the chassis.
Old 11-03-2014, 05:28 PM   #43
NoClassic
Firewall is done along with some other small interior pieces that needed to be black.
I also pushed the chassis out to clean it off and get an image before the cab goes back on.
Old 11-03-2014, 08:38 PM   #44
Kim57
Kim57's Avatar
Looking good.
Chassis came out real nice.
Kim
My build thread
Old 11-14-2014, 05:48 PM   #45
NoClassic
My dad painted the seat frame and installed the cover. He said the fit was not that great with the brand of cover we used, but I think it turned out alright. He also picked up some new hardware for the door cards and installed those.
We also got the chassis and engine harness fuse panels mounted under the dash and figured out the pass through for the chassis harness. Once some trans cooler line fittings show up we can bend those then drop on the cab finish up the external wiring.
Old 11-14-2014, 06:49 PM   #46
RockinKees
RockinKees's Avatar
Looking good!!
Is that a stock benchseat??
Cheers!! Kees.
Kool Guyz CC
Old 11-14-2014, 07:45 PM   #47
NoClassic
Yes, it is the stock seat.
Old 11-15-2014, 12:55 AM   #48
Kim57
Kim57's Avatar
Looks real nice.
Kim
My build thread
Old 11-15-2014, 05:11 PM   #49
OneOffStroker
I put a Jag under my '57, and the Jag springs were way too stiff. Even with the motor and front sheetmvetal, it was on the upper bumpstops. I pulled it from an '87 XJ6, and the XJ12 is supposed to have even stiffer springs, so I don't know how it will end up for you.
I just decided that the best thing for mine would be to airbag it, since I have always wanted bags anyway.
1972 C10 "Shop Truck" Build - EFI, 5-speed, Posi, and Patina http://67-72chevytrucks.com/vboard/s...d.php?t=834292
1957 Chevy pickup - Twin Turbo 5.3/NV3500, Jag IFS & IRS, AirRide http://67-72chevytrucks.com/vboard/s...d.php?t=606987
Check me out on YouTube - "Tiny Garage Fabrication" http://www.youtube.com/oneoffstroker
OneOffStroker is offline   Reply With Quote
Old 11-15-2014, 07:49 PM   #50
NoClassic
The cooler fittings showed up this afternoon and I just finished bending the hard lines up to the cooler. Tomorrow I will get some heat sleeve on the cooler lines near the exhaust and then we can drop the cab on.
My dad also installed some of the adhesive sound insulation and got the cowl vent doors and cables in.
We had the same issue on a 55 f100 we put one of the aluminum block LS motors in. It was on the top bump stops like yours so we ended up bagging it.
