Old 07-03-2017, 01:37 PM   #26
RADustin
Re: Windshield wiper: 2 speed to intermittent
another question to toss out here-
I'm late model engine swapping my truck('76 GMC) and adding cruise control and what not.
My current thought is to use a later model column that has a stalk for cruise control and I guess wipers.
Does anyone know when cruise control came out?
So basically I'm looking at-
84+ wiper motor with fender mounted washer pump/tank
78-83 wiper motor linkage arm and nut
84+(or when cruise came out) wiper switch(column) and module.
I am assuming the 84+ still had a separate module for wipers?
What yall think?
RADustin is offline   Reply With Quote
Old 07-04-2017, 06:46 AM   #27
bluex
bluex's Avatar
Originally Posted by gmachinz View Post
The 78-83 trucks had the 2-speed wiper switch as standard-the pulse/delay was optional. I'm out of goodnused ones so I have only NOS modules left for now. On used modules I update to newer style Panasonic capacitors in place of thebold ones on thebcircuit board and then test each one.
If you have a 73-77 truck and wish to use the 78-83 style pulse wiper switch you will need:
78-83 wiper motor
78-83 wiper switch and module
Underdash and underhood wire harness extensions.
For wiring you can follow the basic diagram for the 78-83 trucks and adapt this to your truck-keep in mind 1978 was the first year for the mini fuse panel vs older glass type so the wiring changed colors also from 77 to 78-this is why I offer a control harness which is correctly color coded for the 78-83 setup since that is the desired upgrade anyway. I keep it all factory appearing. Here is a complete kit I have on hand (several are in storage at the moment) to give you an idea of a typical "kit" I've offered up before. But if you want to source some salvage yards/Ebay and parts stores you can also prolly gather up everything you need.
How much for the replacement harness section pictured? I think I have a wiring issue with mine and thats the reason it isnt working. PM me if thats available seperately.
Paul
bluex is offline   Reply With Quote
Old 07-04-2017, 08:40 AM   #28
buffydores
buffydores's Avatar
As a note, I did figure mine out. It works perfectly fine. I was just expecting the variability on the high setting, not the low setting. I never even tried it.
Old 07-05-2017, 09:27 AM   #29
RADustin
are the later 78+ 2 speed AND intermittent linkage the same?
I found some linkage local but it's on a 2-speed truck.
Old 07-05-2017, 11:52 AM   #30
bluex
bluex's Avatar
You're refering the the parts in the cowl that connect the motor to the wiper posts right? That is the same on all 73-80s as far as I know. The difference is the motor, switch and delay box like pictured earlier.
Old 07-05-2017, 12:56 PM   #31
gmachinz
You must use 78-up linkage arm-the motor stud on 73-77 trucks are not the same as 78-up.
gmachinz is offline   Reply With Quote
