Old 08-27-2014, 03:16 AM   #26
Ozzy2013
Ozzy2013's Avatar
Re: Mechanical clutch and header clearance?
I am going big block and nv4500 i bored the center of a lakewood blow proof out to fit drilled new mounting holes .I want to run mechanical clutch i guess ill need center dump headers?68 GMC1500 2wd
Ozzy2013 is offline   Reply With Quote
Old 08-27-2014, 11:14 PM   #27
crazy longhorn
Fabricate till you "puke"
You should start another post on this, but here goes....if you run a mechanical linkage setup, I would bet that there are many long tube headers to fit your app. The deal on the LS swaps/stick shift, is that all off the headers(other than the streetrod shorties listed) are designed for the hyd clutch, & intrude on the space for the bell crank & linkage? I have not done your trans swap, so I can not give you the best advice I suggest, that you start a new post, for your app....not to be an azz who, but you may find a guy that has been there, for the "proper" help Longhorn
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-28-2014, 01:30 AM   #28
Ozzy2013
Ozzy2013's Avatar
I was just thinking out loud no more and no less just speaking in generalities .I have a plasma and a welder .
Old 01-09-2015, 12:56 AM   #29
Gooker928
I used 2000 camaro manifolds on a chevelle with a M20.
Gooker928 is offline   Reply With Quote
Old 01-09-2015, 07:57 PM   #30
Ozzy2013
Ozzy2013's Avatar
Thanks for the info.
