06-08-2014, 10:52 PM | #26 |
Re: tryin to decide...20's or 22's
I fought with the same decision your trying to make. I ended up going with 20's but now wish I went with 22's or at least in the rear. My next set for sure will be 22's. I say if you have 22's in your head at all you might as well pull the trigger on them, if not you will probably regret it like I do.
Also in my opinion I don't think you need to be bagged to pull off 22's. Look at Hectors, you can't tell me his truck doesn't look ridiculous. A nice 4.5/6 or even a 5/7 drop and your good to go. Here's a pic of mine with the 20's.
Keith 66 Suburban Burb Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=751361 IG: bennett68c10 |
06-09-2014, 12:29 AM | #27 |
20x10 Zero offset. I like the larger sidewalls with the 20's (275x45x20) All around. Mine's on bags so I can change the stance.
1967 Red, C10 Short Bed 6.0L T5 5 speed 1967 Orange and Black C50 6.2 Detroit Diesel NV4500, 2 Ton Pickup 1972 White, Chevy Blazer 2WD 67 Dog house 5.3 4L65 2016 Power Tour LH 1955 Red-Cream, Chevrolet Nomad, restoration on hold 2004 Black, Corvette Z06 LS6 convertible (Rock solid Fun) 2011/2018 Power Tour |
06-09-2014, 12:42 AM | #28 |
Here is mine on 20x8.5/20x10 and bagged.
Just made the upgrade from 15" moons.
Best Regards, Leon M. Instagram: @TheDirtyDianah
Bagged | 6.0L LS | T-56 (6-Speed Manual) | Turbo Burnout/Rolling Video: Chevy C10 Stepside 6.0L LSx & 6-Speed Manual |
06-09-2014, 10:23 AM | #29 |
///Relaxed Atmosphere
i had a decent looking lip on my 20's with a 5.5 backspace but like mentioned before you can narrow rear end some to give you more backspace which allows more lip you also have to consider a rolled/soft lip vs step lip which a rolled/soft looks deeper in IMO. iam guessing with a 70 you have a 6 lug truck which also means not many wheels are out there with a deep backspace unless you go custom but then again i could be wrong.
71-Cheyenne Super (E.C.E Static Drop 4.5/7". Intro Rally's 20X8.5 5" B.S 255/35/20 (F) 20X10 5.25 B.S 275/35/20 (R) 87-Silverado Static Drop 5/7" Raceline Explosion 5 22X8.5 (F) 22X10 (R) hector _________________________________ 1971 Chevrolet Cheyenne Super 1987 Chevrolet Silverado 2006 Ford Mustang GT 2012 Toyota 4-Runner 2014 Dodge Ram 1500 Sport Crew Cab |
06-09-2014, 11:11 AM | #30 | |
That's the exact look I'm looking for on mine. |
06-09-2014, 12:00 PM | #31 | |
06-09-2014, 12:09 PM | #32 |
Thank you! I have a small C notch to install on mine. Plan on doing a 4/6 static drop or close to that. Beautiful truck. Love both your wheel choices. Sorry for the hijack on thread.
06-09-2014, 02:33 PM | #33 |
If your keeping track of the 20's or 22's debate...?
I say 20's
My Trucks: 1967 Chevrolet Short Wide Box 327 TH350 9" w/3.90 gears paint will be White - Current Project 1967 Chevrolet Custom LWB 283 TH400 3.73 Posi, no-AC, no-PS, no-PB, bench-seat, small-window - mostly orig driver 1967 Chevrolet CST LWB originally a 327 TH400 3.73 Posi AC PS PB, had Buddy Buckets, Small Window - parts truck 1967 Chevrolet CST LWB, 283 MT 3.73 had Buddy Buckets, Panoramic Window - parts truck 2001 Chevrolet 3500 2WD Crew Cab Dually 8.1L Allison White |
06-09-2014, 02:56 PM | #34 |
x2
65 C20 292 4spd 4:56 Eaton HO52 |
06-09-2014, 07:01 PM | #35 |
Ive narrowed it down to 20's because I know they will give me the look im goin for with the 4 6 drop thats already on the truck. Now I need to find out what works and what doesnt as far as extra modification and fitment. saw a thread that says the 338's have some fitment issues in the front? I really like the 338, coy, torque thrust 2 look alot, especially with a nice deep lip in the rear. wouldnt you know I see a pic of some 20's that I fell in love with, and they wound up being billet specialties hiboys which are a pretty penny lol cant afford them but something to look forward too maybe
06-09-2014, 07:02 PM | #36 |
also, my truck has a 4 6 drop, but the back sits a little higher than the front, and I want to get it to sit totally flat, like Original-71's truck. how do i get the back of the truck down a little?
06-09-2014, 09:18 PM | #37 |
You can add a drop block to the rear to bring it down some. I'm pretty sure you can get them anywhere from 1/2" to 2". You can get the 338's to fit with some grinding of the hubs but if your looking for a big lip in the rear the 338's won't really get what you want. The Coys do have a nice lip and but their customer service is left to be desired. The TT II's are a classic for a reason, they look awesome on everything and you can order them in any backspacing you want. Just another option Billet Specialties makes a wheel called the Mag. They look similar to TT II's but have a rolled lip instead of a step lip. They are priced cheaper then Billets because they have a cast center. I included a pic of the Mag. Good luck with the search.
06-09-2014, 10:22 PM | #38 |
not the best pics right now but my 20's
06-09-2014, 10:46 PM | #39 |
FYI, I have the new 338s, and they fixed that problem. That is what is on my truck now. See above pics
06-10-2014, 10:06 AM | #40 |
Project 7dos
20x8.5/20x10. If I went 22 I'd have to lay frame, for my own personal preference.
7DOS - 1972 C-10 350/350 Porterbuilt/Accuair 20x8.5/20x10 Ride Low or Die PSSST - Yes it's bagged. 7dos build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=610290 |
06-10-2014, 10:29 PM | #41 |
I don't. I should have done one while I built it, but never did. Thank you for the complement tho! Right now she is in the garage with a blown wheel bearing, awaiting a set of bigger brakes and modular spindles. It completely trashed the spindle, and rotor when it went, and I'm lucky I didn't have the wheel come off in the process. So if I have to replace stuff, may as we'll go big right?
06-11-2014, 10:15 AM | #42 |
22's...8's and 10's. Fit perfect! Mild drop for now. Going lower eventually.
06-12-2014, 12:30 AM | #43 |
1969 C10 SWB -- LS 5.3 4L60E , CC LT HEADERS, 2.5" X-PIPE ,P&P THROTTLE BODY, CAI, ELECTRIC FANS, 3:73 GEARS, TRAC LOCK, 22" BOYDS , VINTAGE AIR, DAKOTA DIGITAL, 2013 LTZ LEATHER SEATS, PIONEER DD NAVI, 4.5˝ FIBERGLASS COWL HOOD, MCGAUGHYS DISK BRAKE CONVERSION 2.5 DROP SPINDLE 6/8 STATIC DROP . |
06-12-2014, 12:36 AM | #44 |
Do them both 20x8.5 front and 22x9.5 outback
06-12-2014, 09:35 AM | #45 |
http://s943.photobucket.com/user/tes...9fd2a.jpg.html
69lsxc10, Is your truck bagged, or static drop? If static can you give me some info on the drop. Very nice by the way |
06-12-2014, 09:38 AM | #46 |
I'm so untechnically savvy, I copy and pasted the picture but all that appeared was the link. Can someone explain how to do that.
Thanks, wade |
06-12-2014, 05:22 PM | #47 |
The 22's look great 69lsxc10, nice stance.. What size tires are you running? I've been tossing around which way to go myself (22's or 24's). The 22's look great but not too many wide rear tire sizes and the 24's when tucked correctly can't be beat. It's hard not to stare at rwade's truck and not drool... Lol
06-12-2014, 05:28 PM | #48 |
use2bnlp - nice stance on your truck also, are you bagged or static dropped? Also looks like you chopped one down from long to short. Awesome job.
06-12-2014, 05:40 PM | #49 |
yes bagged and yes cut down thanks for the complement
06-12-2014, 06:37 PM | #50 |
well....deffinetly SHOULD NOT have gone on the Billet Specialties website......I might be in trouble now, I got a hinckerin for some stilletos
