Old 06-12-2014, 11:06 AM   #26
Wasted Income
Boosted Member
Wasted Income's Avatar
Re: Lsx376 2.9l whipple?
The whipple guy thinks it takes a 4.0L blower to make 700 whp? LOL.
Guys with a "little" Magnuson TVS2300 (2.3L/rev) making 900+ whp...
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2016 Ford Explorer Sport - Twin Turbskis
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 06-12-2014, 01:41 PM   #27
Parishchief1
Parishchief1's Avatar
With the drivetrain listed, you would need to be at about 875-900 fly wheel HP to make the 700rwhp. With this motor and the 2.9L, it will be difficult to do this on pump 93. You would need about 18psi which on this motor, is spinning the 2.9L pretty good which will also create hotter IAT's. For the 376-B15 motor to make the power you are looking for with ease on 93 octane, I would suggest the W245AX (4.0L) kit we offer. The larger blower does not have to spin nearly as hard to make the boost/power therefor the IAT's will stay lower.
Thanks,
Mike Malicoat
Whipple Superchargers
Ph. 559-442-1261
Fax. 559-442-4153
67' C-10 PBFAB suspension,Accuair, Baer Pro+ 14" big brake kit F&R, Narrowed moser 12 bolt,Boyd Slayer 24x9's & 24x15's. 405 GANG500HP Ls "Da Green Beast"
Parishchief1 is offline   Reply With Quote
Old 06-12-2014, 02:00 PM   #28
Hart_Rod
Hart_Rod's Avatar
Thanks,
Mike Malicoat
Ph. 559-442-1261
Fax. 559-442-4153
http://forums.corvetteforum.com/c6-t...ss-a-myth.html
http://forums.corvetteforum.com/c6-z...engine-hp.html
Hart_Rod is offline   Reply With Quote
Old 06-12-2014, 02:03 PM   #29
Parishchief1
What harness and ECM are you running HART ROD
Old 06-12-2014, 02:06 PM   #30
Hart_Rod
Hart_Rod's Avatar
Speartech EFI harness. E38 ECM, T43 TCM, both factory units.
Old 06-12-2014, 02:11 PM   #31
Parishchief1
Anybody running an ls with a 2.9 whipple how much room between top on SC and hood? Whipple says the 2.9 is 10.5" from valley tray to top of SC and 4.0 is 13"
Old 06-12-2014, 02:22 PM   #32
Hart_Rod
Hart_Rod's Avatar
Old 06-12-2014, 03:10 PM   #33
Wasted Income
Boosted Member
It will depend on where the porterbuilt setup puts the engine in the frame rails. I have a No-Limit front end/motor mounts on a 4x4 to 2wd conversion (puts the engine about 1" higher in chassis), and my Hi-Ram is almost touching the hood, at 12.3" tall
Turbo diesel
Old 06-12-2014, 08:29 PM   #34
c10seconds
c10seconds's Avatar
I think i remember seeing about an inch between the hood and the top of the blower. I on a mild dropmember. I don't think it would clear with an extreme DM
1967 C10 SWB 6.8L/4L80
c10seconds is offline   Reply With Quote
Old 06-12-2014, 10:09 PM   #35
Hart_Rod
Hart_Rod's Avatar
Forgot you were running the extreme drop member. Here are some pictures the setup in my 68 and a measurement of my son's 68 with a extreme dropmember.
