Old 09-02-2014, 09:14 PM   #26
Ski-me
Ski-me's Avatar
Re: SEM interior paint/dye
Originally Posted by hatzie View Post
You won't go to Wal Mart or AutoZone to buy this kind of stuff.
A buddy had the Smyth Automotive paint store in Cincinnati mix a color in SEM dye. He needed to color match some replacement interior parts, on his project '88 Supra, to the originals. They were a really dark red and the rattle cans just didn't match well enough. He sprayed it through a regular paint gun.
You should be able to do the same at any large automotive paint store.
I brought in my old dash and found a spot that was mot faded....had the paint shop color match with vinyl paint. Cleaning the pad beforehand is the most critical! It must be super clean to stick properly.
- Jeff
89' K5 Blazer, 2.5" lift, 35" tires
04' GMC Yukon XL, 3/4 ton, 8.1L
Ski-me is offline   Reply With Quote
Old 09-02-2014, 09:26 PM   #27
dfrank
dfrank's Avatar
Make sure if using the sem to prep very well. There are 4 different sem products including the paint you need to use to make it perfect and last. It worked very well for my door panels.
dfrank is offline   Reply With Quote
Old 09-02-2014, 09:32 PM   #28
Ski-me
Ski-me's Avatar
- Jeff
Old 09-02-2014, 09:45 PM   #29
LostMy65
But Found Her 25yrs Later!
LostMy65's Avatar
I ordered the SEM Shadow Blue last night.
I knew there was some other SEM things I needed like cleaner and prep, but I didn't know exactly what they were called, so I only ordered the paint/dye.
Anybody want to post what all we need?
N2TRUX posted a 'how to' here, but I might have missed if he posted each product he used:
http://67-72chevytrucks.com/vboard/s...d.php?t=169470
66 C20 Service Truck:
Old 09-02-2014, 11:34 PM   #30
LostMy65
LostMy65's Avatar
I did find this recent thread.
http://67-72chevytrucks.com/vboard/s...d.php?t=627507
Old 09-03-2014, 02:51 AM   #31
y5mgisi
Second Chance Program
y5mgisi's Avatar
Subscribed. Debating on if i should convert my mandarin interior to tan.
90 Chevy Suburban 2500 5.3 swap/th400/np241/14bltSF/10blt.
77 C20 crew cab Silverado. 396/th400. In work.
y5mgisi is offline   Reply With Quote
Old 09-03-2014, 10:56 PM   #32
LostMy65
LostMy65's Avatar
Here's a page with some good 'how to' info:
http://www.vinylprosem.com/page/1291223
Old 09-04-2014, 12:08 AM   #33
LostMy65
LostMy65's Avatar
Post from another forum;
Clean the
part with Dawn and warm water
and dry well, wipe with a good
grease and wax remover with a
clean lint-free cloth, spray and
wipe with the SEM vinyl and
plastic prep spray, spray liberally
with adhesion promoter and then
apply one LIGHT coat of SEM paint
while the adhesion promoter is still
wet. Wait fifteen minutes between
coats and apply up to four coats.
You can also wipe the part with a
tack cloth to remove any lint or
particles between steps of the prep
phase stated above. Follow these
steps and you'll have great results.
Also, DO NOT touch the part with
your bare fingers during any of the
prep phases or you're asking for
poor results and adhesion
problems. Good luck!
And;
The SEM part number for the Sand
Free Adhesion Promoter is 38363. The
SEM part number for the plastic and
vinyl prep spray is 38353. I use Prep-
All Grease and Wax Remover part
number GSW362 as well.
Old 09-05-2014, 01:54 AM   #34
LostMy65
LostMy65's Avatar
I bought one can of shadow blue so I could see it in person. I really like the color.
I didn't want it to be as bright a blue as I saw in some pics I saw of it online.
I did a test piece on some black vinyl.
It is interesting how it sure looks different with pictures taken with my flash on and off.
I still want to see it in daylight to be totally sold.
These are with Flash Off:
And these are with Flash On;
Old 09-06-2014, 08:26 PM   #35
LostMy65
LostMy65's Avatar
Here's a shot outside in daylight.
I'm sold. Great color.
Old 09-06-2014, 08:32 PM   #36
dfrank
dfrank's Avatar
To properly prep the sem you need
- SM scuff and clean and gray scuff pads
- SEM plastic prep
- SEM plastic adhesion promoter
- SEM paint/dye
You need to use it in that order as well. Each product has directions for proper use as well. You DO NOT use wax and grease remover you need to use the SEM scuff and clean with a gray scuff pad.
Old 09-06-2014, 08:42 PM   #37
LostMy65
LostMy65's Avatar
Thanks, dfrank.
My middle buddy seat is original vinyl from a 67 truck, so for it I'll be doing a thorough step by step clean and prep.
However, my two other seats are new black vinyl like in my pics that I want to make shadow blue. I figured since it's brand new vinyl that I'd just use the vinyl prep and then shadow blue.
Do you see any issue with that plan?
Old 09-11-2014, 06:26 PM   #38
LostMy65
LostMy65's Avatar
I've read a couple places to use windex for new vinyl. There's a dash replacement company that suggests wiping the new dash down with windex before spraying SEM.
Old 09-12-2014, 10:19 PM   #39
LostMy65
LostMy65's Avatar
I ended buying these for some of my old vinyl pieces.
Old 09-15-2014, 09:23 PM   #40
1968vetL-71
Junior Member
1968vetL-71's Avatar
I've used SEM several times, love the product. I just finished redoing the interior in my 91 crew and got rid of the dingy white crap and went with all new blue! The Shadow Blue goes great with with the new ACC full carpet, door carpet kit and new headliner. Love it!
1969 impala conv 427 #s loaded. dad bought new
1969 "Judge" RA-3, rare warwick blue/white, #'s
1968 vet convertible #s 427/435 tripower (sold)
1968 belair 2door post #s 427/385
1936 ford 5w coupe dads 1st car
1969 camaro ss (17,xxx) miles
Wanted: 69-72 suburban project, 69 camaro convertible. also any big block cars. 69-70 gto judge project.
1968vetL-71 is offline   Reply With Quote
Old 09-15-2014, 09:32 PM   #41
MTCK
MTCK's Avatar
Good info throughout the thread - thanks guys.
We need a build thread for this truck!!
-Marcus
1991 V3500 L29 454 4L80E NP205 D60/14 Bolt 4.56's
1984 K30 292 TH400 NP205 D60/14 Bolt 4.56's flat bed 7'6" Meyer Plow
2022 Silverado 3500 L8T
Project Daily Driver
Project Heavy Hauler
Project Plow Truck
MTCK is offline   Reply With Quote
Old 09-15-2014, 09:40 PM   #42
LostMy65
LostMy65's Avatar
Shadow Blue still looks lighter in pics outside than what it looks like in person.
Love the color.
Came out great.
Old 07-16-2015, 01:52 AM   #43
IdahoMan
Bump.
Having the same problem. I can't find a matching paint anywhere for the interior of my 81 Silverado (blue).
I went to the hardware store and also to the local KC paint and looked at their PPG books.
I have to paint the metal molding pieces that hold the headliner up. Here:
Thread
IM
IdahoMan is offline   Reply With Quote
Old 07-16-2015, 12:35 PM   #44
y5mgisi
y5mgisi's Avatar
I really want to see someone do a full interior in plastidip! It seems like the finish would be about right and should flake off.
