09-15-2014, 03:10 PM | #26 |
Re: Jason's 1965 Daily Driver Build
Finally Back Home!!!!! Hopefully if I deploy again its to a better place than Kuwait!
Parts are rolling in, still waiting on my Porter Built stuff but hopefully I'll be tearing it down soon! CPP Big Brake Kit Front Rear ECE 2" drop front springs and 5" drop rear springs Rear wheels came in, 18x9.5 5 lug conversion axles from ECE
1965 SBFS BBW Soon to be Restomod Daily Driver 1972 Chevy Nova-Pro Touring |
09-17-2014, 07:25 PM | #27 |
Great looking parts, welcome back!
1966 C10 Short Fleetside 1988 Sportster, 2008 Street Glide Ken's 1966 C10 build "Red Ale" Follow on Instgram: @cv_performance https://instagram.com/cv_performance Harley Performance Parts: CV Performance (Harley related) Enjoying the ride! |
12-02-2014, 10:49 PM | #28 |
Well my dad and I finally cleared out a shed to put the truck in for me to work in. I've been so busy with my new pup that I haven't been able to get to the truck so I had a few hours free today so I was able to swing by and start on some tear down. So far the only salvageable sheetmetal is the front panel behind the grill, the cowl panels and the passenger side fender doesn't need too much work, but the driver fender is trash, the radiator support is trash and the cab has been smashed at some point as well as having more silicone than even bondo holding the floorboards and inner fenders together.
12-11-2014, 08:33 PM | #29 |
Christmas came early!!! Well about a month and a half behind when it was supposed to get here but its finally all here, all of my Porter Built goodies. Now I just need to test fit it all and get it powdercoated.
12-11-2014, 10:58 PM | #30 |
I really like your choice of wheels, sweet
Craig 1966 Chevrolet C10 - Supercharged LS3 1968 Chevrolet Camaro 1957 Chevrolet 2dr Hardtop "It makes sence if you don't think about it" Mesquite 1966 C10 - LS3 W/ Air Ride http://67-72chevytrucks.com/vboard/s...=1#post4989763 |
12-13-2014, 06:35 PM | #31 |
I got a little more done today, got the inner fenders and radiator support off, the radiator support was completely rotted off the frame and just being held on by the surrounding sheet metal.
01-08-2015, 10:48 PM | #32 |
I took a trip to New Jersey last night and picked an engine and transmission. I was planning on sticking with a 5.3/4l60 set up but I got a killer deal on a complete top to bottom lq4/4l80e setup, I'm also getting the radiator setup which i'm going to see if there's a way to retrofit that and get it to work. I'm going to replace the seals and maybe step the cam up a bit and then just clean it up I think.
01-18-2015, 08:34 PM | #33 |
It's been a busy weekend, I got the cab and bed off. The rear cab bolts came out with no problems but the fronts were a different story. The previous owner welded in home brew floor pan patches and welded them right over the front cab bolts. I had to cut an access hole just so I could get to the bolt heads, but overall it went better than I planned.
02-11-2015, 04:14 PM | #34 |
Progress has been slow but steady, I'm only able to get to it about one night a week but its getting there. Got the drivetrain out and got all of the rear suspension out, just need to borrow a set of spring compressors to remove the front crossmember and then I can start cleaning up the frame. I also purchased a KBS Chassis paint kit in gloss black that I'll go over everything with.
02-17-2015, 10:08 AM | #35 |
Got some more work done this weekend, all the front suspension is off and the frame is ready to start being cleaned up.
02-26-2015, 06:54 PM | #36 |
It was too cold to work in the shop that has the frame so I messed with the motor a little the other night, pulled all the wiring off, all the accessories and the exhaust manifolds. I also did a compression check and all seems well. I'm going to swap the cam out and I figure I'll just have the heads rebuilt at the same time, maybe have them ported and polished and if I go that far I may go with a FAST truck intake and throttle body, that will be determined by funds when I get to that point. for now it needs a gasket kit to get rid of all the leaking ones...which is pretty much all of them.
04-19-2015, 07:25 PM | #37 |
After much grinding, drilling, chiseling and pounding with a bfh I've got the frame down as far as I can before paint, the only brackets remaining are the cab, bed, and core support brackets and the rear most cross brace and the radiator support cross brace just to hold the frame together.
I'm planning on having the frame blasted before I start with the KBS frame system. Before I have it blasted I'm going to go ahead and cut out for the c-notch, just ran out of time that night.
