Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 08-16-2014, 11:00 AM   #26
hotrod 80
mini truck racer
hotrod 80's Avatar
Re: Got 2.1 runs in with new setup
Looking good
1949 5-window
1969 Camaro
1976 Chevy Luv yellow
1978 Chevy Luv Blue
1976 Chevy Luv Black
1979 Firebird Flooded in Harvey
1999 F350 Dually
2005 GMC Sierra 4.8 RCSB
2014 Explorer (wifes)
My build :http://67-72chevytrucks.com/vboard/s...d.php?t=399148
Build #2: http://67-72chevytrucks.com/vboard/s...d.php?t=653583
hotrod 80 is offline   Reply With Quote
Old 08-16-2014, 11:17 AM   #27
Marv D
Registered Truck Offender
Marv D's Avatar
If and 'when' you do the antiroll,, don't make the mistake I made (over and over) buying the cheep Jeggs and Comp Engineering units. I tore up no less than 4 of them (@ $180 each) before I wised up.
http://markwilliams.com/detail.aspx?ID=1525
That Roger rule is no more evident than in chassis compinents that take aboue...
Roger Rule #1
only a rich man can afford to buy cheap parts,,, because only a rich man can afford to replace them over and over again
Whatever you buy,, if it's not a splined end,, you don't want it!
Still playin with trucks, even at my age!
When you're dead, it's only a problem for the people around you, because you don't know you're dead.
.....It's kinda the same when your STUPID.
I just did my taxes and reviewed my SS statement. Thanks to the current administration it looks like I will only have to work till noon on the day of my funeral.
Marv D is offline   Reply With Quote
Old 08-16-2014, 11:46 AM   #28
71Dragtruck
71Dragtruck's Avatar
Was looking at one of these Marv, it looks like you have to weld the ends, splined likely is a better idea, was thinking of mounting it to my shock tower, or would a separate crossover tube for it be better?
http://bearsperformance.com/canada/i...roducts_id=267
Speed is just a matter of money, question is how fast can you afford to go?
8.95@148.97mph all motor haven't tried bottle yet
Sponsored by:
Getz Oilfield Consulting
Hard Candy Customs
71Dragtruck is offline   Reply With Quote
Old 08-16-2014, 11:55 AM   #29
71Dragtruck
Actually they do have a splined one too, this one looks way better,
http://bearsperformance.com/canada/i...roducts_id=264
Sponsored by:
Hard Candy Customs
Old 08-16-2014, 07:10 PM   #30
Super73
Super73's Avatar
If I remember right we put a Jerry Bickel in mine, but it is a full welded deal; no splines, no bolts through the tube.
http://www.jerrybickel.com/rear-susp...brc1038hd.html
------Motor---------------Bottle
60'---1.53---------------1.41
1/8---6.58 @ 105.92----5.87 @ 118.41
1/4---10.38 @ 126.97----9.24 @ 142.49
Super73 is offline   Reply With Quote
Old 08-16-2014, 07:54 PM   #31
moggey01
I used the Bickel extreme anti roll. It is 2'' and used bigger bearings obviously. Mine is 24'' wide. It is overkill for the power level that I should have currently , but I dont have hardly any room for tire clearance on either side of the tire. I will probably have some power at some point down the road.I just cant have any body roll lol. The wishbone is a Bickel also. I can give you deminsions if you need them for a stock frame. The anti roll is splined with a groove to mount the arms. It was done with the tubing for the anti roll bracing the upper shock mount like you are talking about.
moggey01 is offline   Reply With Quote
Old 08-16-2014, 10:02 PM   #32
71Dragtruck
Can I get some pics of how the main mounts, and a side picture please.
Sponsored by:
Hard Candy Customs
Old 08-16-2014, 11:00 PM   #33
moggey01
ok these are a little cleaner with no tires or radiator. This is the kit as it comes from Bickel, the bearing mounts are welded directlly to the frame. Cut the bolt holes off and weld it in . Thats the only change made from the way it comes. Let me know if this is what you need . I can take more tommorow.
Old 08-17-2014, 01:08 AM   #34
71Dragtruck
Thanks.
That looks like the same design as the one I was looking at, I'll have to put my truck up on stands an do some measuring and visualizing.
Sponsored by:
Hard Candy Customs
Old 08-17-2014, 01:17 AM   #35
moggey01
Just curious what driveline combination your running? I remember it was 3700 plus lbs.
Old 08-17-2014, 01:39 AM   #36
71Dragtruck
Right now, built turbo 350, and a fab 9" with Moser parts, when I go to my new motor I'm planning I'll be going to a glide.
Sponsored by:
Hard Candy Customs
Old 08-20-2014, 07:02 AM   #37
djracer
djracer's Avatar
http://www.appliedracing.com/anti-ro...ional-kit.html
This is the new one on my junk!
Kevin
Special Thanks to All who have helped on the TRUCK!
My Pass Time Show http://s129.photobucket.com/albums/p...Chapter1-0.mp4
So Far my best Times are:
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
5.785 1/8 @ 118.65 with a 1.336 60ft
9.168 1/4 @ 142.58 with a 250 shot dead out of the hole!
djracer is offline   Reply With Quote
Old 08-20-2014, 07:05 AM   #38
djracer
djracer's Avatar
Unless you can get the truck down below 3500lbs I would do the turbo 400 instead of the glide!
Kevin
Motor only:
6.44 1/8 @ 104.13
10.39 1/4 @ 125.83
Nitrous Times:
