Old 06-21-2014, 08:17 AM   #26
volksworld
Re: How long will it last??? 3 speed saginaw and new 383!!!!
when i put in the 454 and was trying to jet the bog out of the edelbrock i rolled off a stopsign and floored it and took all the teeth off first gear in my muncie 4 speed...due to lack of money the 3 speeds been back in it since...
1970 short step c10 leaf spring 454
volksworld is offline   Reply With Quote
Old 06-21-2014, 09:44 AM   #27
steveo3318
steveo3318's Avatar
Oh it's not a big block. It's just a 4 bolt main stroked and bored to a 385. Sorry if I said big block somewhere
steveo3318 is offline   Reply With Quote
Old 06-21-2014, 09:46 AM   #28
steveo3318
steveo3318's Avatar
3 speed Saginaw??? How longs it been in. What kind of hp numbers. And how do you honestly treat it!
Old 06-21-2014, 12:24 PM   #29
19673ontree
CAN'T FIX NOTHIN
19673ontree's Avatar
I had a 67 camaro in the 90s it had a strong 327 with a 373 rear and a sagi 3 speed it would burns the tires off and I beat the crap out of it never had a problem !
1967 C10 Shortbed Fleetside Small back glass
6 cyl 3spd on the tree 3.08 gears
underdash AC
19673ontree is offline   Reply With Quote
Old 06-22-2014, 08:35 AM   #30
volksworld
assume its a saginaw...the original 3 on the tree the truck came with as a 6 cyl...bought it with a blown engine,immediately converted to 350 horse 350 and beat the heck out of it for a couple years before i got the muncie (as a homemade half ton tow truck)...guess i drove it a year or 2 behind the big block (ls6 crate motor de-tuned to 9 to 1 ,put the big valves out of the square port heads into a set of ovals...i wanted torque and i guess my tranny explosion proves i succeeded) before the unfinished resto started....but i was afraid to really hammer it after what it did to the muncie
Old 06-22-2014, 10:40 AM   #31
slow-1
slow-1's Avatar
In 1985 (guided by the engine guy at the garage where I worked) I built the 350 in my truck to an estimated 450 hp (his estimate). I drove it with the Saginaw 3 speed (3 OTT) until around 2002 when I switched to the 700r4.
I drove it like a yougster with 450 hp (smoking all the Mustang GT's) for many years, never any hint of it breaking...it was working fine when I took it out. I think the U joints protected it cause I went through a lot of them.
1972 Cheyene C-10 "Ole Green"
My Grandfathers truck (early 70's to 1983)
My first vehicle (1983)
Original 350 (3 rebuilds)
700R4 from Bowtie Overdrives
slow-1 is offline   Reply With Quote
Old 10-30-2015, 01:07 PM   #32
DangerDan
Can anyone tell me what rear transmission mount will fit the Saginaw manual 3 speed. The bolt hole pattern is 3 5/8 on the transmission. I have a custom cross member for the body side.
DangerDan is offline   Reply With Quote
Old 10-30-2015, 01:34 PM   #33
leftybass209
leftybass209's Avatar
The horsepower numbers are a little different, but the 327 in the Chevy II Novas( l76-365hp and l82-375hp) were ran hard in the drags, on modified motors at that. Those can and we're ran with both saginaw and Muncie 3-4 speeds. The trans outlasted the engines. Also, the 3 speed ran a faster 1/4 than the 4 speed (same driver) in some instances.
leftybass209 is offline   Reply With Quote
Old 10-30-2015, 02:16 PM   #34
steveo3318
steveo3318's Avatar
They didn't have cross members in trucks. Only in cars etc. I actually built one for mine. The bell housing was the mount and the saginaw just hangs off. Reason for many cracked ears in my opinion I will post a picture of mine later
1967 c10 3OTT with R10 overdrive.
385 Stroker, 373 posi
FITECH EFI, Vintage air, York 210 OBA,
4/6 drop with riddler 20x8 and 20x10
1957 S5T Leslie Supertyfon train horns and EMD bell
"No bolt left unturned"
Old 10-30-2015, 02:19 PM   #35
Fitz
Originally Posted by steveo3318 View Post
Found a m22 locally. Might get it and convert the 3 on the tree to 4 on the tree with a pull handle for reverse. Anyone ever seen that?
You have the right trans because the 1965-70 Chevelle equipped with the M22 used the floor shift linkage with a 'T' handle for reverse. No one ever made one for column shift.
It's this one:
Fitz is offline   Reply With Quote
Old 10-31-2015, 09:27 PM   #36
volksworld
think that chevy mount is a real generic one that fits damn near everything including automatics...just look up any 70's chevy car with a 3 spd
