06-22-2014, 04:22 PM | #26 | |
Re: Wood Type for new bed
06-22-2014, 05:57 PM | #27 | |
08-15-2014, 03:12 PM | #28 |
I've picked up black locust, it looks like ash and tough as nails. It's also known as ironwood if it was told to me correctly. Black locust is traditionally used for fence posts and exterior projects. After 60-80 years with no finish it is pulled from the ground and maybe 1" of rot and still useable. A fellow i met told me this, when the lumber is green you can nail it, but once dry you need to drill first. I visit my father in southern minnesota and found a dealer that had a complete pallet of ironwood so we selected more than enough to do the bed and a couple of Adirondack chair projects. The real beauty was all of the lumber came from the same tree (flitch) so i can bookmatch the boards during installation. Boards cost around $3.25 a board foot rough sawn 1" thick. Honey locust is a similar species but no where near the durability and didn't care for the pink hue.
08-15-2014, 07:30 PM | #29 |
Personally, I'd probably try hickory. The grain is amazing.
08-15-2014, 07:49 PM | #30 |
Oak. I also recommend semi-gloss as gloss really only looks good if you're going to color sand it.
Even the semi-gloss I sanded out to 1000 (or 1500) before final coat. Probably not required but this is the first woodworking I've ever done (well, the bottom side was technically first, that's where I practiced).
08-15-2014, 07:51 PM | #31 |
While I'm at it, if I had to do it over again I probably would have had my original bed strips chromed. While you can imagine I won't be hauling a ton of debris in there it's still going to be work to maintain stainless.
And I should have tubbed it and put in dualies :-) Probably $500 bucks at least though. I forget what the stainless ones cost. Another tip: the ends are where the boards will rot and fail. Don't be shy about putting extra coats on the ends.
