Old 07-05-2014, 01:06 PM   #26
aotte1
Re: A833 Rebuild
I got the suggestion from a transmission shop in PA that works on them, max HP level for power shifting is around 300, granny shifting is good for lots more power.
Les
aotte1 is offline   Reply With Quote
Old 07-05-2014, 03:41 PM   #27
MalibuSSwagon
Re: A833 Rebuild
Originally Posted by hatzie View Post
The 1969 Plymouth Fury factory manual states... SAE 140. If you experience hard shifting in cold weather SAE80, SAE90, & ATF. ATF is not suitable for summer use.
That being said. Modern synthetic oils are much different from their 40+ year old ancestors. I've run modern synthetic ATF in my 1969 Dodge Polara and my 1969 Monaco 500 all year. I've also run Synthetic multi-weight GL-5 gear oils more recently.
Here's a thread from the Dodge Charger guys. I've read similar on the C-Body Drydock.
http://www.dodgecharger.com/forum/in...?topic=82080.0
Good reading. I was just going to run what GM recommended for fluid, but if there is something better out there I'll run that.
As far as clutch linkage, I was looking at using a hydraulic throw out bearing.
http://www.speedwaymotors.com/GM-Sto...ring,1945.html
Question, how exactly does this mount up to the transmission? Does it more or less float on the input retainer?
MalibuSSwagon is offline   Reply With Quote
Old 07-06-2014, 06:47 AM   #28
D13
D13's Avatar
Re: A833 Rebuild
Again I remind you this is NOT the same A-833 as in a Dodge B-body. The aluminum case and no bushing and the gear flip greatly reduce the torque capability of this trans. If you power shift this at 300HP there will be pieces on the floor pretty quick. In the GM application there are no 350 or big block uses for a reason. About 200HP or 300 lb-ft seems to be the limit.
I believe the later model trans uses ATF. The synchro material and tolerances may have changed. I would be tempted to use whatever GM calls for, in a synthetic flavor. Unfortunately the owners manule in the 87 is long gone, but I bet Keith still has his.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-06-2014, 02:39 PM   #29
hatzie
Moderator
hatzie's Avatar
Re: A833 Rebuild
The GM MY6 would be very similar to the Aluminum case 70's & 80's Dodge Ram A833 OD they put behind the 318 & Slant 6. The bigger V8 engines like the 360 got you a NP435 Cast Iron top loader similar to the SM465. I had an 81 Dodge D100 with the leaning tower of power and an OD Aluminum case A833. Dodge always leaned toward the lighter weight gear oils rather than ATF till the early 80's. I believe it was changed to meet CAFE standards not for longevity of the transmission. The internals didn't change.
BTW I only posted the B body board info because it was easy to find. My 383 Monaco 500 is a fuselage C-Body just like the 1969 Fury, Polara, Newport, New Yorker, and 300.... She's a land yacht. The 383 & 440 equipped 69 Fury and Monaco 500 were the only C-Bodies that had an Iron Case A833 4 speed stock. I grafted a Fury setup into a Polara when I was in high school RIP old buddy.
1959 M35A2 LDT465-1D SOLD
1967 Dodge W200 B383, NP420/NP201 SOLD
1969 Dodge Polara 500 B383, A833 SOLD
1972 Ford F250 FE390, NP435/NP205 SOLD
1976 Chevy K20, 6.5L, NV4500/NP208 SOLD
1986 M1008 CUCV SOLD
2000 GMC C2500, TD6.5L, NV4500
2005 Chevy Silverado LS 2500HD 6.0L 4L80E/NP263
2009 Impala SS LS4 V8
RTFM... GM Parts Books, GM Schematics, GM service manuals, and GM training materials...Please include at least the year and model in your threads. It'll be easier to answer your questions.
And please let us know if and how your repairs were successful.
Old 07-07-2014, 05:50 PM   #30
hatzie
Moderator
hatzie's Avatar
Re: A833 Rebuild
That's my understanding of those. Granted I've never held one in my hand.
Old 07-07-2014, 10:36 PM   #31
MalibuSSwagon
Re: A833 Rebuild
Well I ditched the hydro throwout bearing idea. Going with the AA bracket and a factory slave cylinder. Cheaper too, plus if I have a failure out on the road its an easily available part and I don't have to pull the trans to replace.
Old 07-08-2014, 03:28 AM   #32
v30crewcab
v30crewcab's Avatar
Re: A833 Rebuild
you dont need the aa bracket if you find an 85-87 bellhousing, from a factory hydro clutch truck. it has the dual pattern to fit either transmission on it from the factory, so it will bolt on.
88 military v30 crewcab shortbed 5.9 cummins, nv4500, 205
86 k30, 89 diesel burb, 76 gmc pathfinder
71 longbed 5.3 4l80
http://67-72chevytrucks.com/vboard/s...d.php?t=522535
v30crewcab is offline   Reply With Quote
Old 07-08-2014, 07:04 AM   #33
Keith Seymore
Keith Seymore's Avatar
Re: A833 Rebuild
Keith, is ATF the factory fill for the GM A833? I read some differing opinions on the subject in my research.
Yes - it was for mine. It specifically calls it out in the owner manual (RPO MY6).
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Old 05-16-2015, 12:02 PM   #34
Gregski
Post Whore
Gregski's Avatar
Re: A833 Rebuild
Eric did you ever complete this rebuild, and got the transmission installed?
Gregski is offline   Reply With Quote
Old 05-17-2015, 12:26 AM   #35
MalibuSSwagon
Re: A833 Rebuild
Well life happened. I did get a shifter and replacement gearset, it's all in a crate and sitting in my garage now. Yes I have a garage! Bought a house last October and been moving and fixing other cars that have broken since. I'll finish the rebuild and likely put it up for sale at some point.
