06-30-2014, 12:52 AM | #26 |
Re: Need Your Opinion - What Would You Have Paid?
Agreed, that's a good price for that truck.
Be very aware, however, that all the rubber parts on the truck have "age hardened". The rubber gives off elastomers -- that's what makes it smell like rubber -- which are what keep the rubber soft. BTDT. So belts, hoses, fuel filler hoses, fuel and vent lines, door seals, window seals, cab shock mounts, shackle bushings, spring bushings, engine seals, transmission seals, power steering seals, front steering gear bushings, the rubber cup on the piston of the master cylinder, etcetcetc have all hardened over time. Now as they wear, they will not be supple enough to close up, where 30 years ago, they would have been. Couple things you can do. Get three bottles of this stuff, and put one in the engine oil, one in the trans fluid, and 1/3 bottle in the power steering fluid. It will restore elastomers to the rubber and close up leaks (which you probably don't have yet) and allow the seals to stay closed when the seals wear, preventing leaks from developing. Lots of people claim it, but this stuff actually works. http://www.amazon.com/gp/product/B00...?ie=UTF8&psc=1 For the exposed rubber and vinyl parts, use 303 Aerospace Protectant. It will restore the look and feel of the exposed rubber and vinyl. I'm thinking here of the cab mounts, the spring and shock bushings, the door and window seals, the vinyl seats, the dash pad, etc. The cup on the end of the master cylinder piston is tougher. You will know you have the problem when the brake pedal slowly starts sinking when you are holding it down. If you lift your foot and pump it, the pedal will come back up, but slowly sink again as you hold it down. You can replace the master cylinder, or if you want to keep the original one on there, you can rebuild it.
Rich Weyand 1978 K10 RCSB DD. |
06-30-2014, 01:06 AM | #27 | |
I would keep the wheels and all just as it is, myself. It looks great to me! Here's another product you may want to know about. The aviation boys use this to keep oxidation from occurring in airframes. You spray it into voids, and it creeps into everything and keeps it from rusting. This stuff will walk 12" up a vertical surface. I spray it into the doors, the rocker panels and the tailgate very liberally -- enough to have it pool in there, and some will run out on the floor. It will coat the inside and keep it from rusting. The aviation boys re-apply it annually during annual inspections. As the sheet metal on 1978 trucks left much to be desired for resisting oxidation, and was not galvanized as modern body panels are, you need to take preventative measures. http://www.skygeek.com/10013.html
06-30-2014, 08:35 AM | #28 |
78K & 79C Jimmys
thats a score for sure.
easily X2 that, maybe more up here...
John 1978 GMCJimmy4X4-350/203 1979 GMCJimmy4X2-305/350 |
06-30-2014, 07:52 PM | #29 |
The Reseal is a really good product that actually works, have been using it for about 10 years.
1987 Green n Green machine. 5.0 4spd std. 7" lift w 35's. |
07-01-2014, 12:20 AM | #30 | |
Slots go on anything!
1974 Jimmy- 5.3/4L80e/NP241 |
07-01-2014, 03:08 AM | #31 |
Thanks for all the replies, positive comments and suggestions!! I will look at all of them. I kinda figured on having to replace the hoses on the engine etc due to their age. But I will be keeping everything I take off and not throwing it away. Thanks again everyone!!
Bomber78 Kenmore, Wash. 78 Scottsdale - SWB One Owner C10 Until June 2014 |
