Go Back   The 1947 - Present Chevrolet & GMC Truck Message Board Network > General Truck Forums > Racing and high performance (trucks haulin more than hay)
Old 07-12-2014, 07:37 PM   #26
TheBlueBomber
TheBlueBomber's Avatar
Re: Just another twin turbo 4.8L build. Project "Short stroke"
Started pulling it apart today.
Here are some of the bearings. #1
#5 they all are wearing like this
Of course the cylinder was rusty enough that I had to put a little force behind tapping it out... and then I dropped it... glad I'm not reusing the stock pistons!
Passenger side
Driver side
Cylinder #1
Got the pistons out and my buddy got the harmonic balancer off. Looks like he used a bolt to press against the crank shaft and now it's stuck in there my girlfriend came over to hang out so I didn't want to get too involved tonight. I'll look it over in the morning and finish taking the engine apart.
Austin
1996 Chevrolet K1500 Silverado
1979 Chevrolet K10 Scottsdale - Carolina K10 -
My 4.8L Twin turbo build - Project Short Stroke -
Instagram - TheBlueBomber1996
TheBlueBomber is offline   Reply With Quote
Old 07-12-2014, 11:01 PM   #27
Hankster
Hankster's Avatar
Following this... Love the k10, Austin.
Current Build
89 s10 ecsb 2wd 4.3/700r4 50k OG Miles
Instagram- shaggin_s10
'86 Chevrolet C10 Custom Deluxe - Gen V 454 - 4l80e - welded 12 bolt
(Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=611611 ) SOLD
Hankster is offline   Reply With Quote
Old 07-13-2014, 03:09 PM   #28
TheBlueBomber
Thanks. I'm really enjoying this truck. Even if I've had it parked longer than I've had it driving lol. How is the big block swap going?
Got the bottom end taken apart. Last thing that needs to be done are the freeze plugs/cam bearings but I'll let the machine shop take care of that.
Nice and grimy. Still has the junkyard markings
Debating where or not to keep stock crank or go with a scat crankshaft.
Not a bad block... just dirty
I'll end up buying a stand for this... dropped a 327 crank on my foot last year and I was limping for 2 weeks... my buddy had it leaning on a pole and when we were cleaning out the shop it landed dead on my 2nd toe knuckle.... I've never hit the ground so fast in my life... not even while being shot at haha.
That's what I was mentioning last night. It went in a few theads... might just have the machine shop take it out if I plan on using this crank
Stock cam I'll throw on ebay dirt cheap.
Austin
Old 07-13-2014, 10:22 PM   #29
Hankster
Hankster's Avatar
It's going pretty good, If you follow my thread, then I'm sure you know I got all the wiring done. Only big things now are mounting the radiator and the exhaust manifolds or headers.. what ever I find first. Oh, and thanks for asking! means alot!
Current Build
Old 07-13-2014, 10:28 PM   #30
TheBlueBomber
Yeah I've been watching it. I really like that blue. There was a time I was thinking on doing my truck that color but I've decided to stick with the red...
Between you and my buddy Jon (1963c-10) I've been really thinking of doing a big block build soon. I've always thought they were cool especially the 454.
Austin
Old 07-13-2014, 10:34 PM   #31
Hankster
Hankster's Avatar
Yeah I like the blue to, but my choice would be the red.. I LOVE red GM trucks, Because i was raised around one.. I thought about painting my truck red at one point.. lol then decided black like the 454ss trucks, then found someone doing that already, so I'm staying blue for now! BBC are great, I haven't even drove mine yet and I love it! Do a Build man! Just build this LS.. put it in, and sell your 5.3 you got to fund a 454 build!
Current Build
Old 07-17-2014, 11:53 AM   #32
Wasted Income
Boosted Member
Wasted Income's Avatar
Originally Posted by BR3W CITY View Post
I know Wasted Income runs pump gas, but uses methanol injection instead of an intercooler on his blazer. Not sure how his lag is tho.
Lag? What lag?
This was just foot-braked, no 2-step, converter barely loaded without being up on it making boost.
That's a 2900 lb turbo LS1 RX7 to my left, and the chase car is a full bolt-on/tune C6Z
I will agree with the others and say that you may want to re-think your turbo selection. Twin 70s on a 4.8/5.3 might not give you the overall performance you're after. It might make hero dyno numbers, but the drivability might not be there. If you want to stick with a cheap ebay turbo, look into the twin GT35s.
I would also like to add that after buying somewhere in the neighborhood of 12 junkyard LS engines, that has to be BY FAR the grossest one I've seen. lol.
1972 2wd K/5 Blazer Turbocharged 370 LSx - 941 rwhp / 1093 rwtq
1969 Chevy K-10 L33 5.3 / 4L80E / NP241 / 4" lift
1964 Buick Skylark Twin TURBO 383 LS pro-touring project
2014 VW Passat TDI - Daily Driver
Turbo diesel
2015 Sierra Denali HD Duramax Turbo diesel
2023 Ford Explorer ST - Twin Turbskis
2023 Ford F150 RCSB - Whipple Supercharged
2017 Polaris RZR Turbo
2014 Nor-Tech Center Console - Twin Supercharged Outboards
TURBO ALL THE THINGS!!
Wasted Income is offline   Reply With Quote
Old 07-17-2014, 12:01 PM   #33
tinydb84
tinydb84's Avatar
Hey Wasted how much meth do you end up using (i.e. 1 gallon per tan)? What boost level does yours kick on?
David
Instagram: myfabguy
Old 07-17-2014, 02:34 PM   #34
Wasted Income
Boosted Member
Doesn't really use as much as you might think. I have dual 1000 cc nozzles, and i only have to top it off about once a week or so (1 gallon reservoir). It lasts way longer than a tank of fuel. lol. I am running straight VP Racing meth from a 55 gallon drum.
I have it set to turn on about 1 psi of boost, but it's barely "on" at that point, since the meth is progressively controlled as a percentage of total fuel flow through the Holley Dominator.
Turbo diesel
Old 07-28-2014, 02:17 AM   #35
BigDan3131
BigDan3131's Avatar
So when you switch to the turbo setup your switching transmissions too right? Then upgrading your axles front and rear? Transfer case too? Nothing cooler than seeing a 4 wheel burnout with 35" tires no less. A guy in Cali I knew would do that with huge big block chevy.
Custom Painter/Restoration Specialist
1965 GMC 3/4 Ton LB SOLD?
1964 Chevy El Camino in full restoration
1991 Chevy S10 288K+ miles 2nd Owner SOLD
2020 RAM 1500 Warlock
BigDan3131 is offline   Reply With Quote
Old 07-28-2014, 09:10 AM   #36
TheBlueBomber
Definitely. Havent decided on what trans I want to go to but I definitely want manual. Being that I don't plan on doing serious off roading I might just take them to east coast gear and have them build the axles.
That big block was probably all motor too wasn't it? Must've been a fun truck.
Austin
Old 01-13-2015, 11:26 AM   #37
aggie91
I'm just glad to be here!
aggie91's Avatar
I am thinking of a twin turbo for my '65 since it will be a fun vehicle and not a DD, even though I might drive it to work when the weather is nice...
I'll have to watch and see what you end up with. BTW, that is the nastiest engine I have ever seen...lol...
Karl
1965 Chevy Stepside(Grandpa's Old Blue) and (July 2015 Shop Build!)(2020, the Saga Continues)
http://67-72chevytrucks.com/vboard/s...d.php?t=372424
The LST Challenge:
http://67-72chevytrucks.com/vboard/s...=1#post7812257
Korbin's 1st Square: "Sunburn"
http://67-72chevytrucks.com/vboard/s...d.php?t=418618
1985 GMC Sierra: "White Trash", Korbin's 2nd now...
http://67-72chevytrucks.com/vboard/s...d.php?t=632305
Henry - 1984 Chevrolet, Owen's 1st Square
aggie91 is offline   Reply With Quote
Old 01-13-2015, 07:04 PM   #38
TheBlueBomber
Yeah it was. Its definitely going to be a fun project and I can't wait to dive right in. Currently my goals right now for my projects are:
Get the K10 running under the stock 5.3 for now, Get the '63 up to safety and daily driver status, and possibly swap a crate motor in the '96. Too cold to do any work outside for me so I am counting down the days until warmer weather comes by.
Austin
Old 03-15-2015, 05:14 PM   #39
Hankster
Hankster's Avatar
How's It coming?
Current Build
Old 03-20-2015, 10:34 AM   #40
TheBlueBomber
How's It coming?
Brought up the heads, valve covers, and other misc. stuff up to work. Threw it all in the parts washer do I don't have a bunch of dirty parts laying around the shop. I'm planning on bringing the block and heads to a local machine shop in the next couple of weeks.
Heading down to Jon's house this weekend and will be working on the 63. Should have some updates for that build soon. I'll post some pictures of the heads once they get out of the parts washer.
Austin
Old 03-25-2015, 09:25 PM   #41
Hankster
Hankster's Avatar
Cool! So do you have a build thread for the 63?
Current Build
Old 03-26-2015, 10:41 PM   #42
TheBlueBomber
Yeah. I guess I never incorporated it into my signature yet. Going to turn my attention to it for the month of April. Going to do my best to get it ready for good guys this year... only have about 5 potential days to work on it. 2 of which will be hunting days I'll have to give up
http://67-72chevytrucks.com/vboard/s...d.php?t=637404
Austin
