Old 07-16-2014, 09:47 PM   #26
mooseknuckles
mooseknuckles's Avatar
Re: Owen's C10
Originally Posted by Slammed66 View Post
I'm in, your square body is rad, this will be even better!
thanks.
mooseknuckles is offline   Reply With Quote
Old 07-17-2014, 08:26 PM   #27
mooseknuckles
Re: Owen's C10
me and buddy went and picked up the doors tonight....$200 I didn't think it was too bad a deal...
Old 07-20-2014, 04:51 PM   #28
mooseknuckles
Re: Owen's C10
I'm so sick of grinding rivets!....10,000 later and the rear end and all the other crap is gone..
Old 07-20-2014, 05:04 PM   #29
mooseknuckles
Re: Owen's C10
I had to go and take the 10 bolt out of the Camaro, cut all the brackets off, then find the gears, bearing races and shims, and get them and the axles back in. I cut the mounts off the eaton rear end so I could mock up the Camaro 10 bolt and tack it in place. I want to run porterbuilt tubular drop arms later down the road....just jammed the wheels on it for now.
Old 07-20-2014, 05:07 PM   #30
mooseknuckles
Re: Owen's C10
....started cutting the drip rails off, not fun, but well worth the effort!
Old 07-20-2014, 05:10 PM   #31
mooseknuckles
Re: Owen's C10
...just need to finish the drivers side then it's done.
Old 07-21-2014, 05:43 PM   #32
mooseknuckles
Re: Owen's C10
I ordered some new rotor's and bearings today, so this weekend it will be a rolling chassis....it would be awesome if that step notch showed up by Friday!
Old 07-27-2014, 06:09 PM   #33
mooseknuckles
Re: Owen's C10
...new rotors on, wheels bolted up.
Old 07-27-2014, 06:11 PM   #34
mooseknuckles
Re: Owen's C10
front sway bar, and pie cut the uppers...
Old 07-27-2014, 06:15 PM   #35
mooseknuckles
Re: Owen's C10
set the cab back on for looks...
Old 07-27-2014, 06:23 PM   #36
mooseknuckles
Re: Owen's C10
I didn't like the look of the way the drip rails turned out, so I did it over.
Old 07-27-2014, 06:29 PM   #37
mooseknuckles
Re: Owen's C10
painted the bottom of the door to see what that would look like...
Old 07-27-2014, 06:39 PM   #38
mooseknuckles
Re: Owen's C10
today I made some axle mounts to replace the rusted out ones...made them out of some scrap 2x4, and with an extra 2" of drop built in..I still have to finish them, but that's another day...
Old 08-04-2014, 03:49 PM   #39
mooseknuckles
Re: Owen's C10
I spent the weekend welding, made some fillers for the firewall and welded in all the holes that I wouldn't be needing...
Old 08-04-2014, 03:52 PM   #40
mooseknuckles
Re: Owen's C10
a few more..
Old 08-04-2014, 03:53 PM   #41
mooseknuckles
Re: Owen's C10
gas filler hole....
Old 08-04-2014, 03:57 PM   #42
mooseknuckles
Re: Owen's C10
fixed the rust in the dash and the corner of the windshield....
Old 08-04-2014, 03:58 PM   #43
mooseknuckles
Re: Owen's C10
Old 08-04-2014, 04:00 PM   #44
mooseknuckles
Re: Owen's C10
welded the cab seam.
Old 08-04-2014, 04:04 PM   #45
mooseknuckles
Re: Owen's C10
Old 08-10-2014, 06:16 PM   #46
mooseknuckles
Re: Owen's C10
not a very productive weekend, but we still managed to do a few little things...like shave the defrost vents and speaker grill in the dash...
Old 08-10-2014, 06:27 PM   #47
mooseknuckles
Re: Owen's C10
...thought I'd practice on the old bed side instead of ruining a good one. definitely made a few mistakes, but now I know what "not" to do next time!
Old 08-10-2014, 06:31 PM   #48
mooseknuckles
Re: Owen's C10
the results...
Old 08-17-2014, 06:56 PM   #49
mooseknuckles
Re: Owen's C10
road trip!...took the day off Friday to go pick up the cab floor.
Old 08-17-2014, 06:58 PM   #50
mooseknuckles
Re: Owen's C10
a few of the trucks sitting at bill's truck shop...
