Old 05-08-2016, 12:04 AM   #26
99 to Life
99 to Life's Avatar
Re: 1951 3100 Patina Build
Step kids are a huge handful, having your own kid will change your life, its great but also more stress too. Going static drop on first build is a good idea. Bags add a lot more knowledge and money to the equation.
51' 99toLife finished 2011,355 sbc,5speed, patina, redoing whole truck, inter, bags, etc
http://67-72chevytrucks.com/vboard/s...d.php?t=382481
49Hardtimes s/10 susp- bagged, vortec sbc, 5 speed, patina, sold
http://67-72chevytrucks.com/vboard/s...d.php?t=594874
VIDEOS https://youtu.be/E8zHhjgS_lA
Geronimo 54' LS engine, static drop IFS, Client build, just about done
http://67-72chevytrucks.com/vboard/s...62#post7399162
52' 3100 Slowly in progress, will be painted two toned, have 235 with a t-5, lowered OG frame
Other projects, 49' farmuse 3100, killer Patina, will be slammed, LS engine, full done interior up next!
www.coffeeandcustoms.com
99 to Life is offline   Reply With Quote
Old 05-26-2016, 06:28 AM   #27
73kay
Hey man, I'm a bit north of Austin, but if you ever need to use any tools, I got a sandblaster, welder, big ass compressor. I have 2 53s that I am working on. I'm keeping mine stock, but I'm looking forward to seeing your progress. It is motivating me to update my build thread, haha
Andrew
1953 3100 292 T5
1985 K5 Blazer 350 700R4 208
73kay is offline   Reply With Quote
Old 05-26-2016, 04:26 PM   #28
51Chevy3100
Awesome! Thanks for that offer! I've been slowly gathering the tools I think I'll need. Been working on it but don't have enough progress for any kind of visual pleasure. HA Good luck with yours!
1951 3100 Patina "Under Construction"
Build Thread: http://67-72chevytrucks.com/vboard/s...d.php?t=636116
87 V30 1 ton Mud Truck
51Chevy3100 is offline   Reply With Quote
Old 08-25-2016, 11:54 PM   #29
51Chevy3100
I just had 7 weeks off work to welcome my first child into the world....of course it didn't take long to get stir crazy so I took the opportunity to get quite some things done on the project.
Finished getting the frame stripped of unnecessary hardware, removed front and rear suspension.
I don't have funds to buy new suspension so I brought the bed in from the backyard and started metal work on it. All 4 corners were cracked (failed to take before pictures) going to the stake pockets. Made repairs as shown below as well as a few minor tailgate repairs and then patina'd everything to make it match.
Also took the leaf springs off and slid the rear axle back under so I can temporarily mount the bed and mark my rear axle centerline. Looks like I will need to notch the frame and have a raised bed floor to get the ride height I'm looking for. I'm not real sure how much clearance is necessary between the axle tube and the frame.
Filled the stake pocket holes and fabbed bed rail end caps:
Finished driver side rear fender damage repair:
Cut out the bottom rusted section of the front bed panel and replaced:
Some general pictures...I probably want it even lower than it's sitting here:
Old 08-26-2016, 12:00 AM   #30
Flysocal
Congrats on your new family member!
Project looks good man I wish I had that much space in my garage
Flysocal is offline   Reply With Quote
Old 08-26-2016, 12:07 AM   #31
51Chevy3100
Thank you! I pull my car out every day that I plan on working but yes it's nice. Hoping to have a bigger garage by the end of next year.
Old 08-26-2016, 02:52 AM   #32
big_moss
big_moss's Avatar
Hey 51 welcome to the the forumn man. I'm on Pasadena my parents live in lc. I've got 51 Im building but been on hold cuz we all know life happens man. Lmk of you ever need a hand maybe we can bounce some ideas off each other. Definitely following the progress man good luck
big_moss bagged 51 3100 build
big_moss is offline   Reply With Quote
Old 08-26-2016, 03:14 AM   #33
51Chevy3100
Thanks!
Old 08-26-2016, 02:12 PM   #34
99 to Life
99 to Life's Avatar
nice patina and patches. I'v done alot of patch work when money was low. So its a win win there. Just keep chipping away. You can buy IFS kits in pieces. Get the xmember and a arms, then spindles and rotors and boom you can have a roller. Make some moch up shocks (you can see on my geronimo thread). You can get the xmembers and hats for under $300 all over the place, speedway, ebay, cpp etc. arms are affordable too. as for your rear, again, on my geronimo thread I did a leaf spring conversion. much cheaper than getting the TCI leaf spring conversion kit. Get yourself a blazer 4x4 rearend 1-200 bucks, snag the springs if you can. You just gotta chip away, but getting a roller is a big step.
Old 08-26-2016, 08:23 PM   #35
51Chevy3100
You're right, there are plenty of things I can do without forking out hardly any money. Lots of metal work to do on the cab too. I was thinking about getting a xmember since some kits you have to buy them separately anyways.
I was thinking of coilovers only because I'm afraid I won't get the ride height I really want and coilovers would give me at least a little adjustment...but if I can do leaf springs and still get it sitting right I would definitely like to save the money and do that. I've been trying to research what parts I can use to get that because I have no clue really.
Is the blazer 4x4 rearend an 8.5? Is that stout enough for a slightly modded (cam, tune) 5.3 ls? I don't have a drivetrain yet but I'm thinking I'll pull a 5.3/4L60E from a junkyard when the time comes.
I need to figure out how to determine what rear end was on the truck when I bought it because it may work....Thanks for your words of wisdom, always appreciated!
Old 08-29-2016, 01:40 PM   #36
99 to Life
99 to Life's Avatar
the rear end would be plenty for your combo. as for the rear, here are some codes
just make sure to get 4x4 because they are wider. zr2 rears are wider even and hard to come by. I like the 3.42 gears. but 3.73 would be good too, posi are nice to find but you can live without it.
RPO codes:
GT4-3.73 gear ratio
GT5-4.10 gear ratio
GU4-3.08 gear ratio
GU6-3.42 gear ratio
G80- Positraction, Limited Slip
LB4- 4.3 V6 TBI
LN2- 2.2l 4cyl MFI
LU3- 4.3 V6
L35- 4.3 V6 CPI
M30- Auto 4 SPD trans
M50- Man 5 SPD trans
S10 Pickups
1995 s10 2wd 8.5 rear, (LB4,L35,M30,GU6)
1995-1997 s10 2wd 8.5 rear, (LN2,M30,GT5)
1996-1999 s10 2wd 8.5 rear, (L35,M50,GU4,G80)
2000-2002 s10 2wd 8.5 rear, (M50,GU4,G80)
2003 s10 2wd 8.5 rear, (LU3,M50,GU4,G80)
S10 Blazers
1995-1997 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
1998-1999 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2000-2001 s10 blazer 2wd 8.5 rear, (L35,M50,GU6,G80)
2001-2004 s10 blazer 2wd 8.5 rear, (M50,GU6,G80)
2003-2005 s10 blazer 2wd 8.5 rear, (M50,GU6)
Old 08-29-2016, 08:01 PM   #37
51Chevy3100
RPO codes:
GT4-3.73 gear ratio
GT5-4.10 gear ratio
GU4-3.08 gear ratio
GU6-3.42 gear ratio
LB4- 4.3 V6 TBI
LN2- 2.2l 4cyl MFI
LU3- 4.3 V6
L35- 4.3 V6 CPI
S10 Pickups
S10 Blazers
Thanks for all the codes, that will be useful if I have to go out and search for one!
Old 08-29-2016, 11:53 PM   #38
joedoh
joedoh's Avatar
just a note on your list 99, the 8.5 rears only came on V6 5 spd trucks and blazers from 1994 to 03, all s10 ss, and all zr2. otherwise its a 7.625 10 bolt.
the mass of men live lives of quiet desperation
if there is a problem, I can have it.
new project WAYNE http://67-72chevytrucks.com/vboard/s...d.php?t=844393
joedoh is offline   Reply With Quote
Old 08-30-2016, 12:04 AM   #39
51Chevy3100
Is it true that the 7.625 10 bolt housing essentially looks the same as the 8.5 housing? I want to determine which ring gear size I have without opening it up if possible. I'll use it if it's an 8.5 but not if it's a 7.625. Thanks.
Old 08-30-2016, 12:46 AM   #40
joedoh
joedoh's Avatar
no, the 7.625 cover is squared off and the 8.5 is round. you can also tell the 8.5 on an s10 because the axle tubes have a step-down next to the cast center. there are so few 8.5 s10 rears that the likelihood you have one is pretty small, only came on very specific models.
here is a picture of the cover differences I found online
you shouldnt be scared to use a 7.625, you likely wont ever have the traction and the hp to break it. they came in fullsize trucks and even v8 camaros. I bet for every 100 stories you hear of them breaking there is one guy who did it (usually being stupid like doing a burnout and then catching traction) and 99 who tell the story.
Old 08-30-2016, 12:56 AM   #41
51Chevy3100
I'll have to check it out when I get home to identify it once and for all. I would definitely like to use the rear end I already have so thanks for your help!
Old 08-30-2016, 08:52 AM   #42
99 to Life
99 to Life's Avatar
I agree, I wouldn't look too much into the rear end "holding up" it most definitely will. I'd shoot for disc brake blazer 4x4 rears. Grab anything you see cause when you really need it, yah know it won't be around for months. I always buy ahead of time, trust me don't depend on used parts when you actual "need them".
Old 08-30-2016, 08:20 PM   #43
51Chevy3100
Good point, thanks
Old 12-16-2016, 04:29 AM   #44
51Chevy3100
Not much progress but at least it's something. Got this patch piece cut out of a new stake pocket and welded in so now I can mount my tail gate with the new hinges.
Old 12-16-2016, 01:47 PM   #45
99 to Life
99 to Life's Avatar
been there done that, harder than it looks to line up the hinge and get it bolted in. If I remember correctly one of the bolts for the hinge is extremely hard to get to. I ended up just drilling a hole in the front of the stake pocket, so I could get a socket in there on the backside of the bolt.
Old 12-16-2016, 09:31 PM   #46
51Chevy3100
I was afraid of that. I may weld one side on and only bolt one side so it's not as difficult and that way I can still get the tail gate on and off if needed.
Old 12-17-2016, 01:49 PM   #47
kameltoes2015
Looks like your heading in the right direction
kameltoes2015 is offline   Reply With Quote
Old 12-17-2016, 04:53 PM   #48
Dan in Pasadena
Dan in Pasadena's Avatar
Sorry I missed your thread until now. Looks like you're making great progress.
I used a Mustang 8.8 rearend (but had the axles re-drilled to the 5x4.75 Chevy pattern) in my 55.2 TF because i wanted four wheel discs, even though I won't really NEED them. Plus I gained limited slip. My truck had a 10 bolt in it which would have held up fine because i don't intend to pound the truck hard but even if i did they're so light in the rear you're probably never gonna hook up hard enough to break one. I think your S-10 rear will work fine.
Enjoying watching your progress, Merry Christmas and Happy Holidays! - Dan
'55 Big Window Shortbed,
Drive-It-&-Work-On-It slid down the "slippery slope" to a Frame-Off Rodstoration! LQ4/4l85e/C4 IFS/Mustang 8.8 rearend w/3.73's
Dan's '55 Big Window "Build" - Well, Kinda!
Dan in Pasadena is offline   Reply With Quote
Old 12-17-2016, 09:42 PM   #49
51Chevy3100
Thanks for lookin!
Happy Holidays to you too Dan! Thanks for the input on the rear diff, I plan to keep it so we'll see how it goes.
