#26 |
Re: Led replacements for dash cluster
Got a little crazy on amazon this morning and orderd white blue green and amber and some for the dame lamp
#27 |
Got my bulbs today so I had to stay up and let it get dark to try them all out
Blue good green good yellow don't waste your time |
#28 |
Blue
#29 |
Green
#30 |
Yellow
#31 |
New some lamp granted I don't have a lens
#32 |
Again
#33 |
Once I get a lens that will tell the tale but I am sold
#34 |
Most frustrating part was almost every bulb I put in wound up being backwards so had to pul it back out and reverse it.
#35 |
70+ ( Old Skool Club )
![]() Join Date: Nov 2003
subscribed
1972 C10 Custom/Deluxe 613 Highlander 406/700R4 1999 White Tahoe LS 4x2 with Z56 Police Package 1992 K1500 GMC Suburban Members I have personally met: MusicMan70 - HeavyD - ChewyChevy67 - StingRay -71SWB4x4 - 67 Burb - DeadheadNM - too much stuff - bc65 - das601 " Circumsatances Do Not Change Responsibility " " The Sky is not the Limit, Your Mind is." Marilyn Monroe .. RIP Charlie Watts 1941 - 2021 |
#36 |
I like the blue ones. Think I'll do the same when I tear my dash out.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses". ![]() 93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+ Members I've met... Mister-B |
#37 |
Cluster King
![]() Join Date: Nov 2012
Nitis, Thank you for posting your cluster with the different color LED's. It helps a lot of people make a decision they might have been questioning.
Is the inside of your tin still the correct factory jade green color? If not, what color did you paint it? It will effect the way the LED's look. Thank you, Tom
Contact me on all of your gauge cluster needs. I specialize in restoration, repair and parts sales for 67-72 Chevy and GMC trucks. email me at tbonegarris@yahoo.com I am also a dealer for Counterpart for gauge cluster parts only. Also see my facebook page, CG&C |
#38 |
No it's original which is probably why the green looks so good
I wish I had got red just to try for you guys but I knew I wasn't going that route Nephew is going to use the blues |
#39 |
The blue looks good, but I'm a big fan of that color for lights. Did blue LEDs throughout my boat and it turned out great.
I also did the dome light but feels it really needs a clear lens.
Ryan 1967 Red Stepside..."Laymond" http://67-72chevytrucks.com/vboard/s...40#post6441840 1972 Medium Olive SWB-Chester http://67-72chevytrucks.com/vboard/s...d.php?t=759628 1967/71 Blue SWB C10..SOLD 1977 SWB K10..my grandpa's.....never should have sold |
#40 |
![]() Join Date: Aug 2011
I found you can't get the shift indicator fibre optic cable to light up with the LED lights but I do like the color of the LED's though, I used just white but with the stock tins it gives a greenish blue hue
'72 K10 '94 K2500 |
#41 |
Ok, isn't is time to figure out some middle ground? Rumor has it too much LED keeps you awake.
#42 |
Nitis, what are the part numbers you found for the blue and green leds, for the dash and dome light?
The gauges look good.
1968 Chevrolet Fleetside C-10 1971 Chevrolet Fleetside C-10 |
#43 |
![]() ![]() Those are what I bought. |
#44 |
![]() Join Date: Mar 2014
rx78nt1alex, You will need the 194 wedge base style bulbs for the instrument panel lights but the lights in the A/C Heater controls take a BA9 style buld. You will need 2 bulbs for the controls.
#45 |
Thank you Nitis and Big Kev-O! Now I think I will see what I can order before the wife stops me.
#46 | |
Cluster King
#47 |
Hey guys I tried this sweet upgrade today. I bought the bulbs in the amazon link. I just wanted to test it out real quick so I plugged one in, but it wont light up. I tried a couple different sockets and I tried messing with the dimmer. Anyone know why it wont work? Do I need to change all of them to led for it to work?
#48 |
Firs was it far enough for you to see?
Also of the 7 I switched I only got the polarity right once so if it don't light up remove the bulb and rotate it 180 and it should light up Another way to try if it is daylight is you can try them in a turn signal slot or hibeam slot |
#49 |
In a pinch you can test them with a 9V battery. It's enough to light them, at least what I have on hand.
The better ones must include a diode-rectifier-something such that they'll work in either polarity, or I've been extremely lucky.
#50 | |
Cluster King
Turn them around 180 and if that does not work, turn the socket around 180. I have never had a bad one yet but it is possible.
