Old 07-24-2014, 12:07 PM   #26
Keith Seymore
Keith Seymore's Avatar
Re: Another A833 question
Originally Posted by Rubble View Post
They were offered in a 3/4. 4x4 version as well,My 82 6.2 is that combo & I remember seeing a brand new 83 same combo as mine.
You are correct, according to the GM archives.
I couldn't find any references in the '82 info packet but the '83 version confirms what you are saying. By 1987 it was 1/2 ton only.
MM7 is the "merchandised" option of interest here.
K
Chevrolet Flint Assembly
1979-1986
1986 - 2019
Keith Seymore is online now   Reply With Quote
Old 07-24-2014, 02:17 PM   #27
D13
D13's Avatar
Wow. Learn something new. Good thing I didn't bet on not appearing in 3/4 tons. Bet that had a very low take rate.
Notice applicability is diesels and 4.3 / 5.0 gas, low torque / hp values.
Also I suspect most, if not all the 4wd applications were iron case. Then the only issue would be the shaft strength which behind those engines shouldn't be an issue.
1987 2 ton
1982 250/TH350 beater in progress
Dad's 1981 3/4 L6 3 on tree posi and no options, awaiting restoration or scrapping
Plus a mess o' tractors
D13 is offline   Reply With Quote
Old 07-24-2014, 08:43 PM   #28
Rubble
Yes,the 4wd version is a cast iron case....At least the ones I have are.
1977 Chev C30 454/465/14ff DRW
1974 Chev C20.350/465/14ff
" Rock n Roll ain't noise pollution"
Rubble is offline   Reply With Quote
Old 04-14-2016, 11:27 AM   #29
Flathead Smith
Flathead Smith's Avatar
I recently purchased a MY6/A833 that came out of a C-20 with a 6.2 Diesel, it had a cast iron case with an aluminum tail shaft.
Another unit that I purchased that came out of a 4x4 had a cast iron case also.
Flathead Smith is offline   Reply With Quote
