#26 |
Re: Door seal issue?
It's my understanding these seals are supposed to have a notch cut in the adjoining section when installed to release air that is trapped, so if you got one big air bubble filling the seal up and it's not releasing then this could be causing your issue as well....
Kev's-C-10 ![]() |
#27 | ||
Project Junkie! Fishing Poor!!
![]() Join Date: Dec 1999
On-line catolog Classic Heartbeat Pickup Parts WEHEPP@comcast.net Call us Toll Free (888) 338-2502 Like Us on Facebook No appointment necessary. 72 BB Chevy Custom Deluxe / Custom Camper 67 I-6 (Soon to be 5.7 LS1) Panel 68 BB Chevy Short Bed 72 6.0 LQ9 Short Bed Chevy 4X4 Olympia's fastest growing truck parts supplier. Olympia's home for Wayward Chevys |
#28 |
Mine are not push on type, they are the old fashion glue on type. My point being, we didn't have any trouble putting original style seals on and they were Precision brand. No pre/post-installation special treatment needed.
project: "my happy mess" |
#29 |
Took off the push on ones because even after heating I could not get my door to shut. Got the Metro Superseal (glue on) and the door now shuts perfectly! I suspect the original factory rubber was softer and a different formulation than the modern seals.
Vancouver Bob |
#30 |
Glad you got her figured out!
It had to be done. |
#31 |
![]() Join Date: Apr 2011
I bought two sets of seals, one of which was the Precision brand press on and the other were glue on. I had terrible luck with both, especially the press on. My doors wouldn't close. Then I spent the big bucks for the nos ones and yes there is a big difference! The nos ones WORK!
#32 |
okay guys im ready to put my seals in my rig and have a few questions.
ive got the glue on type. do you need to glue on both sides of the the metal flange? or just one? and which side if? or is it just easier to put the glue in the rubber channel then install and the glue will spread all around the flange? also do you glue a constant bead all around or just do spots along the way? thanks g |
#33 |
Here is what I did:
I applied sealer to the inside of the seal AND to the metal part of the door. I waited a few minutes so it was tacky and then pressed the seal onto the door. I have been told to put the sealer on the seal and then use clips to hold it while it dries but the way I did it did not require them since the two stuck together immediately (I could still move the seal if needed). I would also read the manufacturers directions first just in case they say otherwise. I also used this method with gluing the headliner in. I was told to put a lot of adhesive on and then use a 2 X 4 to hold the headliner up to the roof until dry. By just spraying contact cement to the roof and headliner and letting them get tacky to the touch they formed a bond right away when pushed together and no force was needed to keep them together after that. Does anyone else have a method that works?
Vancouver Bob |
#34 |
![]() Join Date: Apr 2010
Who carries the Metro super seal, I am having the same problem you were having! They really worked huh?
#35 |
I got mine at the place down the street from me, Chevy Metal:
chevymetalrick@aol.com You can also go to the Metro website and they will list their distributors.
Vancouver Bob |
