Old 08-09-2014, 05:06 PM   #26
davepl
davepl's Avatar
Re: 68 c10 L6 engine vibration problems
Originally Posted by Shaky View Post
You're sure that the outer ring didn't spin relative to the inner? I'm just asking because it has happened to me on a 6.
Wouldn't this show up on a timing light pretty quickly? I suppose it could slip only a couple of degrees and that'd be hard to diagnose, but anything more than about 20 degrees would put you so far out of whack that if you set your timing based on the timing mark you'd have really incorrect timing, your rotor would be out of phase, and the engine would shake bad. Just like this guy's truck :-)
1970 GMC Sierra Grande Custom Camper - Built, not Bought
1969 Pontiac 2+2 427/390 4-speed Coupe
1969 Pontiac 2+2 427/390 4-speed Convertible
davepl is offline   Reply With Quote
Old 08-09-2014, 05:09 PM   #27
davepl
davepl's Avatar
Originally Posted by mechanicalman View Post
Use trial and error on your volt-meter by putting red wire on positive side of battery and black wire on ground side then play with it till you get an approximate 12 volt reading. Then, check the wire going from the firewall to the coil and see if you get 12 volts. If you don't, go to the fuse-box and check the spades "ign unfused" for 12 volts.
Nope. You cannot diagnose resistance with a volt meter unless there's a load. You'll measure 12V on a resistance wire just the same as you would a superconducting liquid-helium-cooled monster cable.
I don't know if, with the engine running, the coil would put enough load to show up on a DVM at the coil with a resistance wire. I suspect it would not, but actually have never tried it.
Old 08-09-2014, 05:23 PM   #28
mechanicalman
Well, that's nice, but but WE are only checking for voltage. Don't know where you came up with us checking resistance.
NOPE we NEVER said we were checking resistance. FYI: We would be using a ohm meter, not a volt meter. Ohm meter NEVER came up in the conversation, nor did "digital".
I WILL, however, contact YOU when diagnosing "superconducting liquid-helium-cooled monster cable". LOL
mechanicalman is offline   Reply With Quote
Old 08-10-2014, 03:02 PM   #29
kcsa75
kcsa75's Avatar
Let's stay on task here. We have a member needing some help. We don't need the extracurricular activity.
Willie
Swamp Angel Truckers
'72 C10 Highlander
People who blindly follow a GPS end up on television programs on The Weather Channel. Some survive, some don't.
kcsa75 is offline   Reply With Quote
Old 08-10-2014, 03:17 PM   #30
Codez67Chevy
Codez67Chevy's Avatar
I don't live near this guy. Does anyone? Sounds like he really needs someone to come give him a hand.
" Dead Pumpkin" 67 Chevy short bed, 292 I6, 4spd manual. Fan of the "Slant Noses".
93' Toyota pickup 2WD 2dr and 32mpg. Daily driver. 300k+
Members I've met...
Mister-B
Codez67Chevy is offline   Reply With Quote
Old 08-10-2014, 03:35 PM   #31
Alex V.
Alex V.'s Avatar
Dittos to that!
Alex V.
1967 C10 Suburban, 350/NP435, Green/Green, PS, PB, HD cooling, charging, shocks, and springs.
1985 GMC C3500 SRW, Sierra Classic, 454/TH400, white/blue.
Alex V. is offline   Reply With Quote
Old 08-11-2014, 10:34 AM   #32
sambudo
sambudo's Avatar
That would be cool! I'm buying HEI Distributor today, hoping this helps me with the charge and starting issues. As for the shaking not sure, I'll have to reset the timing and see if this helps correct the problem. Thank you all for the help. I'm determined to get it running better.
1968 C10, 250, L6 4spd OTF, Fleetside
Upgrades: Power Steering
.......................____
.........________//__{\_____
,,,,,,,/__(O)___//___/__(O)_/
sambudo is offline   Reply With Quote
