Old 08-10-2003, 07:39 PM   #26
MOTHERTRUCKERS
Most good rearend shops can redrill your axles and brake druns to 5 x 5 at a reasonable cost.
Rest in Peace Ed. Thanks for all the good times.
MOTHERTRUCKERS is offline   Reply With Quote
Old 08-10-2003, 10:04 PM   #27
crazy longhorn
Fabricate till you "puke"
Originally posted by MOTHERTRUCKERS
Yes 5 lug rotors available at any parts store, 6 from custom part suppliers. Not sure how rubber or screw in control arm bushings got into this but we do not sell rubber control arm bushings because the rubber is inferior to the screw in and it's harder to keep it aligned due to flex in the bushing. Most 67-72 trucks with proper greasing and maintenience are still running the same control arm bushings they had from the factory 30 years ago.
2nd that..... the steel bushings in the 67 -72s were good for about a 1/4 Million miles if properly greased.....they might ride a tad harsher that rubber, but im from the theory that if it works, dont screw with it My longhorn got a new set of shafts & bushings about 18-20 K ago.......the 1st set had 240,000 on them! crazyL
69 longhorn,4" chop,3/5 drop, 1/2 ton suspension/disc brakes,1 1/2" body drop,steel tilt clip, 5.3/Edelbrock rpm intake/600 carb, Hooker streetrod shorties,2 1/2" exhaust/ H pipe/50's Flows , 6 spd Richmond trans,12 bolt/ 3.40 gears....
crazy longhorn is offline   Reply With Quote
Old 08-10-2003, 10:32 PM   #28
raggedjim
raggedjim's Avatar
GMC69, by far the easiest option for the rear is to get the rear end from a 71 or 72. Its already 5 lug and will fit right in. This is if you have rear coils. If you do this try to get the panhard bar also, I seem to remember I had some trouble with that. (been awhile since I did this)
If you have rear leaf springs it's even easier to find a rear end to fit as the newer 73-84 should fit.
Mothertruckers is right about redrilling, I had my axles redrilled on a 68, bought new rear drums for a 72 and had to have the center hole enlarged to fit the axles. I drove out the old studs and bought new ones for the 5 lug setup, they're a different thread size. It worked fine but was more of a hassle than swapping rear ends.
I also put a 77 rear end in a 64 by cutting off the brackets and swapping them, gotta be careful and get everything straight.
Good luck, Roger
Roger
'68 Short step - https://67-72chevytrucks.com/vboard/...d.php?t=849675
'69 ('70?) 2wd Blazer
'70 GMC Jimmy 2wd
'73 Firebird - https://67-72chevytrucks.com/vboard/...d.php?t=853203
raggedjim is offline   Reply With Quote
Old 08-10-2003, 10:39 PM   #29
GMC69
GMC69's Avatar
Good luck, Roger
I know that the 73-87 rear end is 3/4' longer than mine. But from what you are saying the 71-72 is the same width???
And the panhard bar, I will have to get an adjustable one anyhow since I am dropping 4" ( I know mothertruckers carries those too).
So then I can get the drop spindles from mothertruckers, keep my suspension as is ( maybe refresh it a bit) upgrade the front brakes at the same time, then get a rear end from a 71-72 with a five bolt made for coil springs, get my lowered springs and adjustable panhard bar and voila I am in business??
I think I got that straight
Mike
Email: Click here to email me
2019 Silvedrado 4x4
1970 Chevy 3/4 ton, 396BB, on air bags
GMC69 is offline   Reply With Quote
Old 08-10-2003, 11:36 PM   #30
raggedjim
raggedjim's Avatar
Viola may not be the words you'll be shouting! I know I used a 6 foot cheater bar and busted my 1/2 drive rachet (NO SH!T...) to get the nuts off of my rear end when I swapped it out, But it does work. I'm getting ready to do this to my blazer and bought a 72 rolling chassis to swap the parts.
Roger
Roger
'70 GMC Jimmy 2wd
Old 08-10-2003, 11:46 PM   #31
GMC69
GMC69's Avatar
Roger
Well I am expecting that, this is not the first time I had to work on it. Besides the rust and maybe a few broken things, it is the best way to go. As long as I don't need to torch some bolts off I will make due with what I have.
Thanks for the info, looks like things got a bit easier for me.
Mike
2019 Silvedrado 4x4
Old 08-11-2003, 12:27 AM   #32
crazy4chevs
crazy4chevs's Avatar
EARLY CLASSIC has axles, try this. http://www.earlyclassic.com/axles.html
70 chev c10 swb fleet
72 grill, sb 400, 2/4 drop.
68 chev c10 swb fleet
Early classic 4/6 drop with 4wheel disc brakes 9"rear 67-8 buckets tilt and A/C
Classic GM Truck Club of Washington
crazy4chevs is offline   Reply With Quote
Old 08-11-2003, 12:40 AM   #33
GMC69
GMC69's Avatar
Thanks, but by the time I pay for shipping, duty and the exchange rate I am looking at about 600$, I can definetly find a rearend for cheaper than that.
Mike
2019 Silvedrado 4x4
Old 08-11-2003, 02:49 AM   #34
chevy69er
What is the difference between 73-87 3/4ton and 1/2ton ball joints.I want to get some new a-arms but they only make them for 1/2tons.If at all possible i would like to use the 3/4ton ball joints on the 1/2ton a-arms.Any info is appreciated.
1969 C-20,383 stroker,sm465,custom long travel front suspension,4 wheel disc brakes,35" pro comps...mods under way include: 4x4 conversion,and custom bumpers.future mods include: gear vendors od unit,and relocation of fuel cell.
chevy69er is offline   Reply With Quote
