#26 |
![]() Join Date: Jul 2014
Re: 1974 Stepside Project
Yes!! Nice big pics and hard work. Subscribed!!!
#27 |
#28 |
Man your on a ball.
http://67-72chevytrucks.com/vboard/s...d.php?t=581873 The low buck build threads. Check'em out! http://67-72chevytrucks.com/vboard/s...d.php?t=666022 My build thread Crossmembers CC |
#29 |
Thanks! Really like reading the story behind your build.
Rick 1974 Chevy Stepside SWB http://67-72chevytrucks.com/vboard/s...d.php?t=639462 1970 Chevy Camaro http://www.nastyz28.com/forum/showthread.php?t=256150 |
#30 |
Been busy working on getting the right side metal work done. I was able to get the outer rocker mounted as well as the cab corner. I've definitely learned that doing butt welds is a real pain! It takes a lot of patience.
This is some finish welding of the floor pan and under seat patch. ![]() ![]() ![]() Outer rocker and cab corner going on. ![]() ![]() ![]() ![]() ![]() ![]() I definitely had the gaps too wide for the butt welds and caused tons of blow through. Had to really work at getting my welder set up right and got a little better as I progressed. I'll have some updated pics later.
#31 |
This is where I am currently. Still have some finish welding and plenty of grinding to do.
![]() ![]() ![]() ![]() ![]() Not sure why the new pan had this kick-up on the corner but I'll need to relief cut it to fit properly. ![]()
#32 |
Love the detailed pics of rust repair. I need to do it myself one of these days.
#33 |
Boy I wish I could say I've gotten stuff done. But honestly life has been in the way here lately. Great work on the patching. It looks great.
#34 |
Yeah, I was wondering the same thing myself. Seems odd to come that way...
--Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...d.php?t=655783 --Project BABA YAGA!... http://67-72chevytrucks.com/vboard/s...ghlight=Belair "Life is tough - wear a cup!" "Old Enough to Know Better - Too Young to Resist" "Junk is something you will need three weeks after you throw it away." |
#35 |
I'm in the middle of all this myself, have any update's? It's nice to find someone who didn't just drop it off at a shop, AND who took pics lol.
J.R. Link to Daryl's build, http://67-72chevytrucks.com/vboard/s...10#post8443010 Link to my Youtube channel with build info, https://www.youtube.com/thedrivewayengineer |
#36 |
Hey guys, it has been a little while since I've posted any updates. Just like a lot of you, other things get in the way of working on the project so it's been slow recently.
I did get the frame all stripped down, rust proofed and painted. Not sure why I didn't take pictures of the finished product but I'll get some when I get the garage organized better. Currently working on the driver's side rust repair. Just like the other side I'm replacing floor, inner rocker, outer rocker, cab support and kick panel. This side isn't as bad but I decided to go ahead and replace everything since I already had the replacement panels. I turned the cab over with the floor up for starters just to have easier access to the cab support. Added some casters to a pallet and laid the cab on it so I can still move it around. ![]() A look at the bottom of the passenger side repairs. Not finished yet. I still have some welding and clean up to do. ![]() Driver's side before cutting things out. ![]() ![]() New support welded in. ![]()
#37 |
Thanks Jr! You motivated me to post an update!!
#38 |
I am in the middle of the same rust repair myself. A couple things I have learned about but welds....I find it works best to cut through the new steel and through the old steel at the same time with a .040" cut off wheel. This gives you a perfect and consistent gap. I also bought some but weld clamps from Harbor Freight. This made my work much cleaner.
85 K30 crew cab dually - Project http://67-72chevytrucks.com/vboard/s...d.php?t=694939 87 Wrangler Rock Crawler - Reason for the project http://www.wranglerforum.com/f330/da...ld-122601.html 04 1500 crew cab http://67-72chevytrucks.com/vboard/s...d.php?t=786514 |
#39 | |
I like your truck build. Looking to get a crew cab myself after I get a little further on this one.
#40 |
And I appreciate it! The pics are really helpful, I'm going to be working on mine this weekend.
#41 |
Got the cab back on all fours, finished cutting out the driver's side rockers and rough fit the new inner and outer rockers. Pretty productive weekend even though I was also building some planters for my wife.
#42 |
Man that is sooooo much work!
David Used parts build: http://67-72chevytrucks.com/vboard/s...d.php?t=638991 My brother's Nova: http://www.67-72chevytrucks.com/vboa...d.php?t=727985 Rear suspension rework: http://www.67-72chevytrucks.com/vboa...d.php?t=750557 Instagram: myfabguy |
#43 |
Did you have to cut the door pillar up past where the nut plate is inside? Because I'm fitting mine and it really seems like it has to go that high, and yours looks like it does also.
#44 |
Cut the new rocker as high as necessary to get to good metal that you can weld to. It would be way more work than necessary to deal with that plate if you don't have to. I think I cut about an inch or so off my new rocker in that area.
#45 |
Ah I see, you trimmed both to fit. My new outer from Classic Parts is far larger than what I need. Now I'll have to be very careful lol.
#46 |
Mine goes up to the point where the brace your referring to is located. I only went to the bottom of it. I agree that trimming yours is the best bet.
#47 |
