#26 |
Re: 1972 C30 Longhorn for parts
What's the story on the seat belts? Are they in good shape and have middle belt?
#27 |
Simple? What's simple?
![]() Join Date: Apr 2007
Pics of the aux battery tray and harness?? Interested, pending condition.
That arrangement is correct for a 133" 1 ton, I had a 100% bone stock DRW truck that was the same way.
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) Last edited by JJorgensen52; 08-22-2014 at 02:35 PM. |
#28 |
Carpe manana
![]() ![]() Join Date: Dec 2010
Tom still interested in the aux tank send unit and valve lever if available...also need alt bracket for a SB, the lower bracket that bolts to the head correct for 72. Thanks, Pete
1972 K5 CST Highlander Blazer: http://67-72chevytrucks.com/vboard/s...d.php?t=708547 1972 K20 Cheyenne Super: http://67-72chevytrucks.com/vboard/s...d.php?t=528308 ![]() |
#29 |
Truckin' Krazy
![]() Join Date: May 2000
Pete, still have not had time to check the sending unit,I'll try & do it monday.
I do have the floor valve $15 & the alternator bracket $15. jjorgenson, tray is in good shape, not rusted out anywhere, heres a pic of the wiring still in the truck. Haven't had a chance to get at the seatbelts.
Dealer for: American Auto Wire Precision weatherstripping Dakota Digital Trim parts Carpets Truck World seat covers & Many others Chevy Parts locator in Mesa AZ! |
#30 |
Carpe manana
Thanks Tom - I'll take those parts. Let me know re: send unit when poss. Pete
#31 |
How much for the shifter handle? driver wing window? windshield wipers assembly
Thanks |
#32 |
Will take it. PM sent RE: payment info
CURRENT '50 GMC 100 shortbed Gen IV 4.8 LS - 4L65E (Secret truck, Shhh!!!) Build '63 Buick Wildcat Coupe 401ci Nailhead (Very much in pieces) Photos '66 Impala SS convertible 327-QJet-glide (4 speed swap one of these days...) Photos '69 CST/10 4x4 SWB Stepper 350 2bbl - NV4500/NP241C (Broken Truck!) '72 Sierra Grande 2WD LWB fleetside 350-TH350 Refresh '99 K2500 Silverado RCLB 5.7 Vortec - NV4500/NP241C (Daily) '99 K2500 Suburban 7.4 Vortec - NV4500/NP246 (still working out the bugs) SOLD '71 Custom/10 2WD LWB fleetside - '72 GMC K/3500 Dually (Sold to redryder) |
#33 |
im looking for the driverside rear floating Hub..is it in good shape? can i get a pic. Cost shiped to 98439.
And.. will it work on a HO52 3/4 ton..? |
#34 |
How about the throttle cable and pedal assembly?
#35 |
Truckin' Krazy
ideaman $50 shipped for the pedal assy & the throttle cable.
72campspecial, I'll look at what we have apart already, have at least 2 other ho 52s jjorgenson, parts in the mail gotztofly wing window assy $50, tilt handle $15, wiper assy $15-50 depending on how much of it you want. You should drive over & see what we have, your only 5 or 10 miles away. seat belts are cheesy aftermarket.
#36 |
Thanks! Standing by...
#37 |
![]() Join Date: Jul 2009
Interested in the C30 emblems. What condition are they in and price?
#38 |
![]() Join Date: Jan 2012
Tom you still have the passanger side front fender?
#39 |
I'll take them. Tell me how to pay.
#40 | |
#41 |
Tom looking for the passanger side front fender. From the pics it looks ok? Is it still avalible? and where are you located. Been there once.
Thanks Nick |
#42 |
interested in the lower alternator bracket, crank and waterpump pulleys and air cleaner riser (between carb and filter)
Could you tell me how many grooves on the upper and lower pulleys? THanks |
#43 |
Truckin' Krazy
desertnick, fender is pretty good shape, located ellsworth & university east Mesa
white whale, I'll check the pulleys, they should be 2 groove upper & 3 groove 2 pulley set up on the lower. 72Camp Special, All the hubs are gone from the HO 52s I have apart already, so no luck, Sorry to keep you waiting. Contact Member tll74 He is closer to you (Oregon) & has a lot of those rear end parts. deadhead, pulled the sender out, its in rough shape, you can have it with the other parts, I think if you took the time you could probably rebuild /refurbish it. I took pics just have to get them loaded. ideaman Pm sent Douglas the emblems were already spoken for Thanks, Tom
#44 |
Carpe manana
Thanks Tom - when poss PM total shipped to 59901 and I'll square up via Paypal. Best, Pete
#45 | |
08-17-2014, 11:15 PM
Any luck on the firewall to rear lights wire harness?
1971 Bone Stock C10 project "Jake" 1997 Sierra SLT factory short bed "Silver Bullet" |
#46 |
Truckin' Krazy
jake 1971 harness is there , it has had some splices etc done to it $10 shipped if you want it.
A few more pics of the factory auxiliary parts that are available, including: 2 of the bolts & strange washer /nut that are in nice shape that hold the aux. tank in place, Wiring set & switch, in bed fuel neck cover, fuel neck, & a plate mounted to the bottom of the cab that blocks the floor switch from getting damaged. desertnick, fender may have been sold today.
#47 |
Truckin' Krazy
more pics
#48 |
Thank you for the pics, I will pass. I was hoping for an unmolested harness.
#49 |
are the center rear bumper brackets available?
#50 |
Truckin' Krazy
Rear bumper was not a sport bumper, the brackets were all welded to the bumper.
