#26 |
Re: 1967 power steering gear box
No, they are not. My 67 frame is dimpled for the steering box as can be clearly seen in the photo's below. Before you say the frame can't be a 67 with a dimple, the partial vin stamped on the upper side of the frame rail on the drivers side, just behind the steering gear matches the full VIN on the B pillar which decodes as a 1967 C10 six cylinder 1/2 ton built in the Atlanta assembly plant. My truck was #1294 of the first production run which means it was likely shipped in October or November of 1967.
#27 | |
![]() Join Date: May 2014
#28 |
Construction of the truck was completed in 2006 and I am not going to tear down the front end just to make a point on a message board. The dimple is there.
#29 |
If it's there you can see it just looking in from above when the hood is open. But I'll take your word for it because you've got one sweet engine between those frame rails and I could care less about the steering box LOL
#30 |
no kidding, damn that thing is tight.
Figure out what you want--then figure out what you are willing to give up to get it. |
#31 |
#32 | |
1967 C10 Suburban 454/TH400/3.07's An Average Joe and His 'Burb: http://67-72chevytrucks.com/vboard/s...d.php?t=775843 |
#33 | |
Hey, Fitz I was wondering what year truck the box you have came from or refrenced it from or supplier you got it from Or did it come on the truck? Just asking cause I got one from an 85 or 87 and the box hits on the body support and on the frame between the mounting holes were the dimple is or should be. I just had my frame powder coated and don't want to mess with welders and cutting. My truck is a 1967 c10 second owner. Last edited by poledust; 10-21-2017 at 09:36 PM. Reason: added year of truck |
#34 | ||
"I ain't nobody, dork."
LOL... 2 to 3 year old thread and Fitz has had a suspended account for awhile now.
![]() Gary
'cuz chicks dig scars... My 1972 GMC 1500 Super Custom (Creeping Death) "long term" build thread. The Rebuild of Creeping Death after the wreck Quote:
#35 |
Scrapper 1
If no one has pointed it out that is a not a true 1967 frame.None of the early 1967 crames had bumps in the frame for the box of that dent in the frame you have a 1968 and new farm if you had a 1967 frame you have a Power assist with a manual gear box
#36 | |
Scrapper 1
You have a late 1967 frame Remember June or July is where they stop waking the last year frame then they make the newer year.Just like OBD1 an OBD2 when it comes to smog if you have a truck that is made in 1995 But it was made after June or July it makes it a OBD2 .So now you have to find out production date its matters a LOT.Just like the 1964 mustang they made is 5 short months.The collectors look at production date.That will show you if you have a early 1968 truck.Dose your Vin match the one on the frame |
#37 | |
![]() Join Date: Feb 2002
I finally spread some JB Weld on the crack on my manual steering sector and went back to the old Armstrong system. Still steered funky, since I had cut up the original drag link. The K trucks had a steering sector that moves front to back, the 2wd trucks went left/right. Big time problems. Look for ram assist power steering on corvette forums. That's compatible but way expensive. Or do curls and build up your forearms. Wow. I just answered a ''ghost post''. Never met Fitz either, although he was in Tucson when he was active on this board.
Every 25 years I like to rebuild that 292, whether it needs it or not. Last edited by '68OrangeSunshine; 10-21-2017 at 11:56 PM. Reason: ghost post |
#38 | |
Thanks for any help and the quick response! |
#39 |
>>does anyone know if I can space the PB off the frame just enough so doesn't hit in the bump.<<
Yes. If you measure from the flange ear mounting surfaces to the centerline of the pitman shaft, you will find that the manual box is actually wider. Set the old manual box on your bench and measure up to the pitman shaft center. In order to measure the power box, you will have to set the power box on spacers under the mounting flanges. If you use 1/2" spacers, then subtract 1/2" from the pitman measurement. If I recall the manual box has the pitman shaft about 3/32" farther away from the mounting surface. In my case, 3/32" washers wasn't enough to clear the bulge. The power box had a lot of casting flash which I ground off. I applied line chalk to the box and installed it. The chalk revealed one high spot, so I ground a little from the box and also from the side of the frame. It then fit. The hard part was keeping the washers in place, so I tack welded them to the frame.
'67 GMC 2500, 292, 4spd, AC |
#40 |
![]() Join Date: Dec 1999
![]() My 68 has the same frame as your truck. I used spacers. I think I ordered 1/2 inch spacers but couldn't get ones that had a 7/16 through hole so I ordered smaller and drilled them out. I then put the box the truck and determined that the 1/2 inch thickness too big for my liking and i milled them down so the box is only about 1/16 from the frame. |
#41 | |
#42 | |
#43 |
No need to dimple with this CPP steering box. No spacers needed either.
http://67-72chevytrucks.com/vboard/s...d.php?t=729738 |
