Old 08-31-2014, 10:21 AM   #26
Houston Ben
Houston Ben's Avatar
Re: Water pump wobble and question for Hart Rod and Br3w 6L80E
I just checked, they seem to be fine but it has no be where it is comeing from. I will have to put it on again and see what happens.
Thanks Br3w!
Houston Ben is offline   Reply With Quote
Old 08-31-2014, 10:46 AM   #27
Hart_Rod
Hart_Rod's Avatar
Thanks Br3w!
You need to video it running so we can see what it is doing. Make your video longer than the last one and try to hold the camera still. Also, video it from the opposite side. My guess is something with the idler or misalignment of the pulleys causing the belt to be off. A video would go a long way in helping to diagnosing it...
Hart_Rod is offline   Reply With Quote
Old 08-31-2014, 10:46 AM   #28
nsb29
nsb29's Avatar
Hey all,
2011 5.3/6L80 combo. While driving today I noticed a slight vibration under normal driving. It appears about half way through the rev range when doing some easy driving. It almost feels like a break draggin but goes away. This happens in every gear and when cruising I can feel it when slight pedal input is applied, when I let off the pedal it goes away. I checked fluid and it is good, any ideas???
Also, while looking under the hood for this I noticed my water pump and balancer wobble a little, is this normal??
https://www.youtube.com/watch?v=zNye...ature=youtu.be
are you using a one or two piece driveshaft if you don't have enough
angel on your u joint could cause this also check your pinion bearing
nsb29 is offline   Reply With Quote
Old 08-31-2014, 11:03 AM   #29
Houston Ben
Will do Hart Rod, I should be able to do that today. NSB, I have a 1 piece driveshaft. I don't have an angle indicator bit the problem is gone when I put the original tensioner and serpentine on
Old 08-31-2014, 06:21 PM   #30
Houston Ben
Angry Re: Water pump wobble and question for Hart Rod and Br3w 6L80E
Video is up
This one is of it just idling
https://www.youtube.com/watch?v=lMF3M6_LSXI
This is me reving it up and you can see the damn DD mount moving
https://www.youtube.com/watch?v=DIRBhnUhDBg
I followed the directions, torqued it, everything, I'm not happy with this!!
Old 08-31-2014, 06:32 PM   #31
BR3W CITY
meowMEOWmeowMEOW
BR3W CITY's Avatar
wow that moves more than I thought.
'66 Short Step / SD Tuned / Big Cam LQ4 / Backhalfed /Built 4l80e / #REBUILDEVERYTHING
MY BUILD THE H8RDCPTR //\\ MY YOUTUBE CHANNEL REV J HD
BR3W CITY is offline   Reply With Quote
Old 08-31-2014, 06:47 PM   #32
Houston Ben
So should I send this to DD and ask for my money back? I was going to try to attach a small turnbuckle to the back of the compressor to help keep it tight but I shouldn't have to do that. What are y'all's thoughts?
Old 09-02-2014, 01:36 PM   #33
boostedc10
boostedc10's Avatar
Ben at the least I would send them the video and see what input they have for you.
With the number of people running this mount I would expect this is not the first time they have heard this and may be able to get you fixed up.
After that if they throw you some bull**** try to get your money back.
Brandon
Instagram: DRVFSTR
Current Project: Beatrix - 1967 SWB LQ4/78mm Turbo/4L80e/ on bags
Build thread: http://67-72chevytrucks.com/vboard/s...d.php?t=634691
boostedc10 is offline   Reply With Quote
Old 09-02-2014, 02:14 PM   #34
Houston Ben
I sent them an email, I will have to send him the link as well. Should have done that in the first place.
Old 09-09-2014, 08:25 PM   #35
Houston Ben
Problem solved
Thanks for everyone's help on this. I got in touch with DD and their recommendation worked but cost me another $45 bones which I wasn't happy about but the vibration is gone.
I went to the store and picked up a Gates 38164 spring tensioner which fits the mount and I was able to use same size belt.
Thanks again!
Old 09-09-2014, 08:26 PM   #36
boostedc10
boostedc10's Avatar
What did they tell you the issue was? Can you give any additional detail?
Brandon
Instagram: DRVFSTR
Old 09-09-2014, 08:30 PM   #37
Houston Ben
This is the first response
Holy cow that moves. This is not a normal issue. My first guess is the bracket is loose maybe? The back bracket is tight to the head? As in the bolt holes in the head are clean? We have just updated that bracket using counter sunk holes on the back bracket but this was to get it to fit a VVT application. We also have started running larger, thicker diameter spacers on all of our a/c brackets.
Then he sent he this
You can also mount a spring loaded tensioner on this bracket- Gates 38164
Old 09-09-2014, 08:31 PM   #38
Houston Ben
It seems to take care of the problem, just bummed I had to spend an additional $45.
Old 09-09-2014, 08:34 PM   #39
boostedc10
boostedc10's Avatar
Ya that sucks. They must know the issue though to suggest that tensioner! Good info for anyone else that may run into the issue though! Glad you got it sorted out.
Brandon
Instagram: DRVFSTR
Old 09-09-2014, 08:58 PM   #40
Hart_Rod
Hart_Rod's Avatar
I didn't realize that you didn't have a spring loaded tensioner.....that's a bad design, no wonder they changed it. At least you have it figured out.
