#26 | |
![]() Join Date: Oct 2009
Re: LS Engine bay pics
Motor looks great. |
#27 |
![]() Join Date: Oct 2012
kool
69 SWB 780hp Hellcat powered, manual 6 speed, currie 9 |
#28 |
What radiator did you guys use? pics, are good too...
#29 |
I may not be doin ls lol hard to find parts that fit my student budget lol. Local 6.0s are around 4k or1.5k for 185k pullouts without harnesses or comps.
Jack Personal Fleet: Family Fleet: 1955.5 Panel 1959 Apache 1968 ShortWide 1969 ShortStep |
#30 |
Old member
Another update to my engine bay! Got the new Booster and master cylinder mounted.
1971 LWB Custom, 6.0LS & 4L80E, Speedhut.com GPS speedometer & gauges with A/C. 20" Boss 338's Grey wheels 4 wheel disc brakes. My Driver Seeing the USA in a 71 ![]() Upstate SC GM Truck Club 2013,14 and 2016 Hot Rod Pour Tour http://upstategmtrucks.com/ Get out and drive the truck this summer and have some fun! It sucks not being able to hear! LWB trucks rule, if you don't think so measure your SWB! After talking to tech support at Air Lift I have found out that the kit I need is 60811. Per the measurements I gave them. Ride height of truck inside spring and inside diameter of springs. |
#31 |
I used this one: ![]() Bought it from Summit Racing http://www.summitracing.com/parts/gri-8-00013-ls I used the lower radiator from my previous radiator and bent a coat hanger and took it to the local auto parts and matched it up to what I needed. |
#32 |
Stock 3 core with Camaro dual fans.
#33 |
Old member
I used my old one. Had dual Camaro fans installed and did away with the clutch fan.
I maybe swapping it over to the Summit one though. Mine is leaking a little. ![]()
#34 |
you guys make this stuff look easy. Im thinking about doing a swap. It will be my first time doing any major mechanical work.
#35 |
I thought it looked easy too, and i had a lot of "while im in there" moments. 2 years later I am "only" a few months from having a truck again. Moral of the story, have a solid plan and get your parts ready before you tear it down, if you stay motivated it can be a reasonably quick job.
1967 c10 build finally in progress! ![]() http://67-72chevytrucks.com/vboard/s...d.php?t=575626 |
#36 |
Here is mine, and I used the my stock radiator.
Dave 1968 Custom Chevy with turbo charged 5.3 gen III 4l80e swap 1967-71 GMC 3/4 ton long step 4x4 (not sure what year exactly?) "A good friend will bail you out of jail...but a true friend will be sitting next to you saying "that was frekin awesome". "If it doesn't fit force it...If it breaks then it needed to be replaced anyway!" |
#37 |
![]() Join Date: Apr 2005
Rob - https://www.instagram.com/hart_rod_c10 As Iron Sharpens Iron, So One Man Sharpens Another. Proverbs 27:17 FOR SALE: DBW pedal bracket - http://67-72chevytrucks.com/vboard/s...d.php?t=651123 FOR SALE: Hood Brackets http://67-72chevytrucks.com/vboard/s...d.php?t=679945 1987 Silverado SWB - 34.5K original miles http://67-72chevytrucks.com/vboard/s...d.php?t=801834 1969 SuperBurb - http://67-72chevytrucks.com/vboard/s...d.php?t=200387 1968 Farm truck - http://67-72chevytrucks.com/vboard/s...d.php?t=358692 1968 SWB - http://67-72chevytrucks.com/vboard/s...d.php?t=551258 1948 Chevy - http://67-72chevytrucks.com/vboard/s...=122164&page=3 |
#38 |
![]() Join Date: Nov 2012
Hey LEES68GMC,
Can you share any specifics on that orange 71/72? Drop, wheel brand/size, maybe even paint color. It looks metallic. More pictures would be great. That is a beautiful truck. Thanks, Mike |
#39 |
![]() Join Date: Sep 2013
#40 |
Beautiful wagon! I'd stick a 409 or somethin weird in it and make a cruiser
#41 |
