Old 09-16-2014, 09:48 PM   #26
bigblock73
yeller
bigblock73's Avatar
Re: 48-54 (55) speaker brackets
Right cab corner
bigblock73 is offline   Reply With Quote
Old 09-16-2014, 09:52 PM   #27
bigblock73
yeller
bigblock73's Avatar
Left cab corner
Old 09-16-2014, 09:53 PM   #28
bigblock73
yeller
bigblock73's Avatar
Photo of optional trim area
Old 09-17-2014, 01:37 AM   #29
Donaldo
What are the chances that the stock windlace will cover that space between the doorjamb and the speaker bracket ?
Thanks, Don
http://www.donsbirds.com/pick-up
Donaldo is offline   Reply With Quote
Old 09-17-2014, 07:33 AM   #30
bigblock73
yeller
bigblock73's Avatar
I don't think it will, but cannot say for sure. I do know that if that lower portion of the b pillar is trimmed, the gap is virtually eliminated. This area of the cab has a compound curve, making it extremely difficult to design, and impossible to match without the use of making a mold and pressing these brackets (waaaay to expensive to produce as a result)
I sold this prototype set to a local member, he will be installing these in his cab, and will have better pictures to post when he does. I am hoping this will be done shortly.
Old 09-17-2014, 12:11 PM   #31
Donaldo
I am very interested to see the installed pics - looks really good so far.
Thanks, Don
Old 09-29-2014, 08:52 PM   #32
bigblock73
yeller
bigblock73's Avatar
Ok, Forum member Torchlight purchased the prototype set, and has his shop install them in his truck. As mentioned earlier, he had the lower tab on the cab cut straight, resulting in the brackets sitting perfectly flush to the b-pillar. Here is the pic of the drivers side installed. Please ignore the lower floor bracket, as it is temporarily mounted to the front since the speaker opening is not cut...blocking access to the backside of the bracket when installed.
Old 09-29-2014, 09:19 PM   #33
bigblock73
yeller
bigblock73's Avatar
Here you can see the cut tab on the bottom of the B pillar
Thanks Brad for purchasing these and taking the photos!
Old 10-09-2014, 08:56 AM   #34
bigblock73
yeller
bigblock73's Avatar
These are now officially up for sale now. I currently have 10 pair in stock, ready to ship.
http://67-72chevytrucks.com/vboard/s...d.php?t=645857
Pm me if you are interested.
Old 10-09-2014, 08:59 AM   #35
bigblock73
yeller
bigblock73's Avatar
Pm sent Donaldo, thanks.
Old 10-11-2014, 06:55 PM   #36
Donaldo
Hi Jeff, thanks for keeping me in mind, can't wait to get the brackets. Like I mentioned I am going to be using the belt retractors from a '96 GM pickup, might have to cope some of the bottom mount space out for them to work.
I'll be sure to share descriptions and pics how that happens - looking forward to receiving the brackets.
Thanks, Don
Old 10-13-2014, 07:09 PM   #37
bigblock73
yeller
bigblock73's Avatar
Thanks Don. Your brackets went out last week, you should have them the end of this week I suspect, as long as the holiday today didn't delay that some.
Again, thanks for your purchase.
Old 10-14-2014, 01:27 PM   #38
torchlight
torchlight's Avatar
I was lucky enough to get my hands on a set of brackets for my 53 3100. These things fit wonderfully and are nicely built. I didn't install them personally, but the guys at the shop were thrilled with the parts - thick steel and easy to work with. They really are a custom fit for these cabs. I didn't want to cut holes in my doors or install kick panels for speakers, so these brackets are exactly what I was needing. Highly recommend these if anyone else is in the same situation. Thanks, Jeff!
Build Thread: "Marvin" (1953 3100)
torchlight is offline   Reply With Quote
Old 10-15-2014, 06:37 PM   #39
Donaldo
Hi Jeff, the speaker brackets just arrived. I am impressed, the fit up is perfect, I will trim a tab on the lower column and it looks like the seatbelt retractor will work as I planned - thank you !
A question - does anyone think a body panel assembly adhesive would hold these in place, she'll be a 'driver' not a 'grover'.... ?
Thanks, Don
Old 10-16-2014, 01:48 PM   #40
lowrodderchev
lowrodderchev's Avatar
so when you doing these 55-59?
my 57 chevy truck build
http://67-72chevytrucks.com/vboard/s...d.php?t=601554
lowrodderchev is offline   Reply With Quote
Old 10-16-2014, 05:54 PM   #41
bigblock73
yeller
bigblock73's Avatar
I really need to find a cab to mock them up on, same for 60-66. There is a house near me, they have a 55-59 cab in their driveway...was going to stop by and se what the deal was. I have tomorrow off...just might do that, you never know what they will say.
Old 10-16-2014, 05:55 PM   #42
bigblock73
yeller
bigblock73's Avatar
Thanks for the feedback guys, much appreciated!
Old 11-26-2014, 06:37 PM   #43
Donaldo
Hi Jeff, Here is a pic of the pass side speaker bracket in my '51 - I modified the corner brackets a bit - because of clearance issues I switched the sides - r to L etc. I trimmed for the jamb and latches and for the curve at the cab rear. I covered the backs with "rattle trap" sound deadener and tucked them in as far as I could and welded them in place. GM seam sealer around the edges. This leaves plenty of room for the 60/40 GM seat and the belts.
Thanks, Don
Old 11-28-2014, 04:47 PM   #44
MARTINSR
MARTINSR's Avatar
I have another idea that may work for someone who isn't so good at metal fab. I had a piece of vinyl across the bottom of my cab, all the way from each door jamb across the back. This is a very bad picture of it being it looks all wrinkly but it's when I was tearing the truck apart so it's screwed up.
But it ran all the way wrapping around each side perfectly. A piece of metal could be made to hold the speaker that would be screwed to the structure back behind that vinyl and then the speaker grill on the vinyl with trapping the vinyl between the grill and the speaker. It could suck in a little bit stretching the vinyl and I think it would look pretty good.
Brian
1948 Chevy pickup
Chopped, Sectioned, 1953 Corvette 235 powered. Once was even 401 Buick mid engined with the carburetor right between the seats!
Bought with paper route money in 1973 when I was 15.
"Fan of most anything that moves human beings"
MARTINSR is offline   Reply With Quote
